Results 1 to 15 of 15
- 05-07-2012, 07:18 PM
Thread Author #1
Help!! No emergency mode, no recovery. Am I screwed?
I recently was stuck in CWM boot loops, so I tried flashing a different recovery using the following:
~ # flash_image recovery /sdcard/flash_image.img
flashing recovery from /sdcard/flash_image.img
mtd: successfully wrote block at fffffd5800000000
~ # reboot
reboot
when it rebooted, though, it stuck at the LG logo. Blank when attempting recovery mode, blank when attempting emergency mode.
Computer doesn't detect it, adb doesn't detect it.
I'm pretty sure I'm screwed unless someone has an idea...?
- 05-07-2012, 07:45 PM #2
So you tried pulling the battery then holding back - volume down - power?
Sent from my VM670 using Tapatalk 2Last edited by thewraith420; 05-07-2012 at 08:04 PM.
- 05-07-2012, 08:22 PM
Thread Author #3
- 05-07-2012, 08:34 PM #4
- 05-07-2012, 08:51 PM
Thread Author #5
- 05-07-2012, 09:00 PM #6
- 05-07-2012, 09:47 PM #7
- 05-08-2012, 05:34 AM
Thread Author #8
Re: Help!! No emergency mode, no recovery. Am I screwed?
So, after several battery pulls, i am now able to get emergency mode to come up. Of course, now I'm stuck at work all day at a computer with no admin rights, so I can't attempt anything further until tonight
What are my best options to recover through emergency mode? - 05-08-2012, 06:35 AM #9
http://forums.androidcentral.com/sho....php?p=1707315
Sent from my VM670 using Tapatalk - 05-08-2012, 06:52 AM
Thread Author #10
- 05-08-2012, 06:56 AM #11
- 05-12-2012, 08:23 AM
Thread Author #12
- 05-12-2012, 12:42 PM #13
This recently happened to me, but don't worry it can be fixed. First use this guide, http://forums.androidcentral.com/opt...-firmware.html , but only the first 3 sections (1. ---Flashing the S firmware---, 2. ---Getting MSL code---, and 3. ---Root and recovery---). Make sure you flash the update.zip twice to get the radio. ( Once from the recovery you flashed, to install the update, then again before you root with the stock recovery to ensure you replace the sprint radio)
Then Follow only the second section of this guide; [FIX] No data/wrong SW version after VM ROM flash from Sprint ROM ( only do the second section entitled Getting data back working on your phone )Last edited by Ph1Man; 05-12-2012 at 12:48 PM.
Thanked by: - 05-12-2012, 12:52 PM
Thread Author #14
- 05-13-2012, 07:00 AM
Thread Author #15
Reply
