Results 1 to 19 of 19
- 05-10-2012, 03:20 AM
Thread Author #1
- 05-10-2012, 04:01 AM #2
Well tdm you never cease to amaze me. You show up out of nowhere and offline charging on iho gets fixed. Then you pull a working ics build out of your hat, and now this... Thanks for all your hard work to make our low budget phones not feel inferior.
Sent from my LG-VM670 using Tapatalk 2 - 05-10-2012, 04:24 AM #3
Re: [RECOVERY] irecovery: wireless accessible recovery
@tdm--- and for keeping those of us that are currently low/no budget up to date with the jones'... i cannot express how much respect i have for you, jerry, bob, leslie, tua, tvall, gannon, and all the other devs that i cant name off the top of my head that have made and continue to make great strides in the advancement of our little ov's... i am thoroughly impressed with all of you and your generous contributions to the community... :-)
Last edited by clodfelterac; 05-10-2012 at 04:27 AM. Reason: enjoy---> http://www.youtube.com/watch?v=CJQU22Ttpwc&oref=http%3A%2F%2Fwww.youtube.com%2Fresults%3Fsearch_query%3Dreggie%2Bwa
- 05-10-2012, 01:08 PM #4
:rolleyes: wow first cm9 now this recovery, you got mad skill! Thanks
IF I Help You In Any Way Please Push The Thanks Button [HL]It Feels Good To Know You Helped!![/HL]
- 05-10-2012, 03:31 PM #5
Thanks TDM. I would be one of those that would like to use this recovery but do not have, nor do I intend to set up, an sd-ext partition. Don't fix it up on my account, just throwing it out there.
Sent from my VM670 using Tapatalk 2--Chris [cole2kb]
"Any story about malware on any platform...without numbers is not giving you the full picture, and just might be more worried about getting your clicks than any real discussion."
Words to live by: there are always two sides to every story. - 05-11-2012, 12:55 AM
Thread Author #6
Switched to sdcard and added scp. Enjoy!
Thanked by 4: - 05-11-2012, 04:50 PM #7
So, when I went to flash the recovery after completing all the other steps, every other time I've flashed a recovery as soon as I hit enter on the flash_image command it lists all the blocks being written to and all that. This time, I got nothing. Not any errors, but just...nothing. I don't want to risk getting stuck in a bootloop or anything so I don't plan on rebooting until someone can chime in on this. (If someone is going to say it didn't work because I didn't mount system first, it was already mounted.)
I did read the first post, and only feel comfortable asking this question because I did understand the set-up process. This step is just not behaving like I expected it to and is throwing me for a loop. Apologies if this isn't okay to ask.--Chris [cole2kb]
Words to live by: there are always two sides to every story. - 05-11-2012, 06:41 PM #8
- 05-11-2012, 07:01 PM #9
Md5 is fine. I see no reason why using the GUI would yield different results but I'll give it a shot later on.
Words to live by: there are always two sides to every story. - 05-11-2012, 07:17 PM #10Guess whos coming back!
- 05-11-2012, 07:37 PM
Thread Author #11
Some flash_image binaries give output, some don't.
Thanked by 2: - 05-14-2012, 11:14 PM
Thread Author #12
I'll leave the image up as-is for now, but I switched back to using /sd-ext for the config (host keys and authorized_keys). This is because I want to share the files between recovery and the main ROM, and /sdcard is vfat and cannot put the proper permissions on the files.
- 05-14-2012, 11:31 PM #13
This is way cool, nice work tdm. I've been waiting for someone to get wifi working in recovery. Now I get to do the pain in the rear work of implementing ROM Manager-like functions in CWMT Recovery. Download ROMs, Kernels, etc from within recovery, anyone?
- 05-14-2012, 11:34 PM #14
Even if you do reboot into recovery it should only take you to fast boot which is a blue screen! If it does not work, all you have to do once in this fast boot just remove the battery and power on your phone! It should boot normal, now flash your old recovery!
- 05-14-2012, 11:35 PM #15my roms & kernels (based on iho)
If you'd like to donate to me, i accept litecoin, bitcoin, and hardware
LTC - LTVALL5gsjPvgeiBWD7c6DHNWidbpzVu3w
BTC - 1TVALLetFibDe8Zap5qPsqa4BAJWQYQ59 - 05-14-2012, 11:35 PM #16
I wouldent recomend flash image gui.
- 05-15-2012, 07:12 AM #17
my optimus v friends love this thanks
Hydro Rom
768 MHz
hydro kernel pre 4
amphetimine - 05-15-2012, 03:29 PM #18
- 05-15-2012, 04:49 PM #19
Reply
