1. crickie's Avatar
    I found a juicy thread in XDA Devs forums (in the Moto Triumph section) that has alot of info
    listed there. It had a LG download ( to POSSIBLY fix the slow GPS issues?) listed on the page.
    The list at the bottom of the page gives info on the tested phones so far, but no LG phones on that list. You can download a flashable zip for LG phones, but would it work for the OV's running ZV4 or ZV5 radios and didn't load the official update cause it would BRICK their phones. Would ANY of this help all those OV's that could use a GPS booster shot?!? Does any of it work?
    Does anyone know?
    Found it on XDA Developers Forums-Motorola Triumph Development : AGPS Patch Triumph
    3.1 & 2.2 | Get Back To Rapid GPS Lock.
    05-22-2012 11:31 AM
  2. mrg666's Avatar
    I have a very weak GPS with very high inaccuracy and frequently lost satellite connection. I haven't tried the patch in that thread, but the following is the gps.conf I found to be making my GPS work better by trial and error while checking the gps.conf options in similar threads in multiple forums. You can give it a try if you want.
    Code:
    NTP_SERVER=us.pool.ntp.org
    XTRA_SERVER_1=http://xtra1.gpsonextra.net/xtra.bin
    XTRA_SERVER_2=http://xtra2.gpsonextra.net/xtra.bin
    XTRA_SERVER_3=http://xtra3.gpsonextra.net/xtra.bin
    DEFAULT_AGPS_ENABLE=TRUE
    DEFAULT_USER_PLANE=TRUE
    DEFAULT_SSL_ENABLE=FALSE
    INTERMEDIATE_POS=1
    REPORT_POSITION_USE_SUPL_REFLOC=1
    DEBUG_LEVEL=0
    ACCURACY_THRES=3000
    ENABLE_WIPER=1
    CURRENT_CARRIER=common
    SUPL_NO_SECURE_PORT=7276
    SUPL_SECURE_PORT=7276
    SUPL_PORT=7276
    SUPL_HOST=supl.google.com
    05-22-2012 11:54 AM
  3. Badboytoast's Avatar
    Could we get a flashable.zip for us noob! Mrg666 thanks!
    05-22-2012 01:38 PM
  4. crickie's Avatar
    They had flashable zips. I was just wondering if any worked on the OV. My old man's OV is for business and I don't want to risk bricking it with bad flashable zips. I was just wondering what everybody elses results or info was on this. I already am running GPS_Libraries_v2.0_RPC for
    HD2_Gingerbread_update.zip found on Android Forums on my Moto Triumph (it's a good forum for MT stuff). I rely on the info here for the OV upkeep. I flashed a poorly written rom once in his
    Samsung Intercept and BRICKED IT beyond repair, hence the OV. Since then, it's research first! Thanks for any 411 here.
    05-22-2012 02:13 PM
  5. mrg666's Avatar
    I recommend using FasterGPS. First, make a backup copy of /system/etc/gps.conf to your sdcard using your favorite file manager (I use ES File Explorer). Then, add the values I have given above (or different ones as you wish) using FasterGPS. If you want to go back, just copy your backup copy of gps.conf to /system/etc and reboot.
    If you are still insisting on the flashable zip file, it is below.
    VM670_agps_patch .zip
    05-22-2012 03:31 PM
  6. crickie's Avatar
    Thanks a bunch Mrg666! FasterGPS works on my Moto Triumph too. (even with HD Gingerbread GPS Fix already in my rom, CM7.2 g60 style.)
    Finally, something that works for both phones. My old man's OV really needed this. I owe you much for this tidbit! Many Thanks again!
    05-23-2012 05:01 AM
  7. Buddlespit's Avatar
    check my sig. It's flashable
    05-29-2012 05:06 PM
  8. demoport's Avatar
    I've been using this patch with Bobzhome's CM7 latest build and my gps performance has been flawless. My phone would restart itself randomly when I used the gps function without this patch,
    More people need to know about this patch if they are having GPS problems like I did.
    Badboytoast likes this.
    07-10-2012 10:35 PM
  9. Badboytoast's Avatar
    +1 this is a good bump!
    07-10-2012 10:43 PM
  10. BLUE95's Avatar
    So does this work on any OV?
    07-11-2012 10:37 AM
  11. daffy_duck_nj's Avatar
    It certainly does for me. I use mrg's patch, and nothing more. Comes on lightning fast for me, whether I'm on 3g or WiFi.
    07-11-2012 10:52 AM
  12. r00t's Avatar
    I recommend using FasterGPS If you are still insisting on the flashable zip file, it is below.
    It's amazingly accurate now. You should include this in your ROM.
    07-11-2012 11:30 AM
  13. mrg666's Avatar
    Originally Posted by mrg666<br />
    I recommend using FasterGPS If you are still insisting on the flashable zip file, it is below. <br />
    <br />
    <br />
    Yes, it is included actually To clarify, it does not make much difference for an OV with a nicely working GPS. But it helps my phone with a very weak GPS receiver.
    07-11-2012 02:25 PM
  14. EarthnFire78's Avatar
    mrg666 that patch I use and man did it help with my gps.
    mrg666 likes this.
    07-11-2012 04:02 PM
