Results 1 to 19 of 19
Like Tree1Likes
  • 1 Post By diecastdonkey
    Encerspay45's Avatar
    Posts
    ROM
    MiRaGe/jawz101 kernel
    Default Quattrimus Restore Help
    Help!!!! I made a backup right before I flashed Quattrimus A10, and Titanium Backup isn't finding it to restore... help!!!! D:
  2. #2
    diecastdonkey's Avatar
    Posts
    ROM
    Different everyday.
    Default
    Does ur recovery find it?
    Posts
    ROM
    Default Re: Quattrimus Restore Help
    No, it can't. :/
  4. #4
    Posts
    ROM
    Different everyday.
    Default
    There might have been some little error(not enough space, etc). Download a file manager and look through ur SD in a folder called ClockworkMod(or whatever recovery u have) and see if its there
    Posts
    ROM
    It's not there
  6. #6
    Posts
    ROM
    Different everyday.
    Default
    Sorry to say but you'll have to wipe everything and reflash ur old rom or keep quattrimus, im running it and its great IMO. Always read everything in recovery. If this keeps happening try flashing a new recovery. I recommend Jerryscripts's CWM green.
    Posts
    ROM
    I'm actually using CWM Green... and what do you mean by "wipe everything and reflash ur old rom or keep quattrimus"?
  8. #8
    Posts
    ROM
    Different everyday.
    Default
    Okay well see how much space u free on ur SD. What i meant was if u want to get back to the rom u had before then you'll have to wipe everything in recovery(data,cache,dalvik) and install ur old rom in recovery. I was also stating u could keep quattrimus
    Posts
    ROM
    I have about 500 megs free after I put on the backup
  10. #10
    Posts
    ROM
    Different everyday.
    Default
    Idk what happened then but after u make a backup always make sure its there. I hope I at least helped a little
    Thanked by:
    Encerspay45 likes this.
  11. Thread Author  Thread Author    #11
    Posts
    ROM
    You answered, and that's more than enough.
  12. #12
    curtis1973's Avatar
    King Of Pants
    Posts
    ROM
    CM10/Sense
    Default
    don't panic,just use quattrimus to redownload a rom you want to use,then reboot to recovery and install it. then make a backup.
    edit for clarification : be sure to wipe data,cache,dalvik in recovery,then format boot,cache,data and system in mounts and storage,then install your newly downloaded rom. if you want google apps then you can flash that after the rom is flashed then reboot.
  13. Thread Author  Thread Author    #13
    Posts
    ROM
    Hey, everyone, sorry for any confusion. Whenever I encounter a little issue like this, I go absolutely crazy and post the same question on different forums on different websites and PM everyone, just desperate for an answer.
    Anyway, I was actually talking about just backing up/restoring the data from the ROM, not the actual ROM itself. My bad for not wording it right.
    I ended up fixing the issue and restoring the data, but Quattrimus can't go 3 minutes with rebooting itself, so I'm going to try other ROMs.
    But a huge thanks to everyone out there who was kind enough to help a little noob still trying to figure things out. You guys are the best!!
  14. #14
    Posts
    ROM
    Different everyday.
    Default
    Quote Originally Posted by Encerspay45 View Post
    I'm glad to help anyway I can. If ur still a noob try sticking with the iho roms for now. Read read read and u will learn! If u really want quattrimus, I recommend the cm9 build. Its working amazing for me
    Thanked by:
  15. Thread Author  Thread Author    #15
    Posts
    ROM
    Yeah, I just went back to BACKside now lol. And how did you get Quattrimus working amazingly? Mine was so unstable I was about to scream, haha.
  16. #16
    Posts
    ROM
    Different everyday.
    Default
    Well its amazing for an alpha. I'm having less freezes and reboots then I did with backside and mostly everything works
  17. Thread Author  Thread Author    #17
    Posts
    ROM
    :O BACKside is the most polished ROM I've ever flashed.... what version of Quattrimus are you using??
  18. #18
    cmerlyn's Avatar
    Posts
    ROM
    Godzilla
    Alpha 10 Final on mine. Somewhat overclocked, not as much as when I had IHO. It has been running fine, no reboots at all, relatively few F/Cs (mostly Play Store).
    Installed via CWM Green, standard gapps for ICS.
  19. #19
    Posts
    ROM
    Different everyday.
    Default
    Quote Originally Posted by cmerlyn View Post
    Basically same here. cm9 version is best IMO. Kang just seemed wierd
