- 06-05-2012, 03:03 PM
Thread Author #26
- 06-05-2012, 09:14 PM #27
- 06-05-2012, 09:35 PM #28
- 06-06-2012, 03:47 AM #29
To answer the removal question, get root browser for free off the market. Navigate to system/app and long press dspmanager and hit delete. Reboot and you're good. I believe LeslieAnn put a complete list of Apps that can be deleted too, if you wanna remove stuff to replace (ie gallery for quikpic)
Sent from my LG-VM670 using Android Central Forums - 06-06-2012, 07:35 AM #30
I got a very good flashable zip from xda user d3hum4niz3d called MegaBassBeats that improved not only the sound quality, and bass depth, but also the volume. I have been thoroughly amazed as it made my $5 headphones sound like $40 headphones. It doesn't crash dsp either. Find it, try it, love it. Beats icon sold separately
[edit]
I should note that I'm running IHO MiRaGe cm7.
Sent from my LG-VM670 using Android Central Forums - 06-06-2012, 09:29 AM
Thread Author #31
- 06-06-2012, 09:54 AM #32
- 06-06-2012, 10:26 AM
Thread Author #33
- 06-06-2012, 10:27 AM
Thread Author #34
- 06-06-2012, 10:30 AM
Thread Author #35
- 06-06-2012, 11:14 AM #36
Re: [MOD] Beats Audio for LG Optimus
I don't care what anybody says, the zip is boss. I plug in my phone to my Logitech Speakers, and crank it up. The sound is crazy awesome. I plug it in to listen to my music while I play FPS's on the 360, and it's amazing, the quality. I love it.
I think the word should be spread on this mod.
ilikechicken123, do you have an Android Forums? I'm on No-Posting Probation on there right now, lol, but once I get off, if you're cool with it, I'd be more than happy to share this there.
- 06-06-2012, 12:33 PM
Thread Author #37
- 06-06-2012, 01:06 PM #38
No need to get upset
some of us prefer chocolate over vanilla while other prefer vanilla over chocolate!
- 06-06-2012, 01:35 PM #39
Which recovery are you guys using?
iam using VM670NH.recovery! - 06-06-2012, 01:49 PM #40
- 06-06-2012, 02:43 PM #41
Just tested and it flash successfully, the only way i could get the zip to flash from the OP was to download the app from Google play, open it and select. Other 0317 and after that exist the app, boot into recovery and install the zip like a rom! But ONLY WIPING CACHE AND DELIVIC CACHE then install beatsAudio.zip, reboot and listen to music
- 06-06-2012, 04:08 PM #42
This is my favorite recovery app. You should try it out! It's not that much worse than 5.0.2.8 (only 0.0.0.1 lower).
[RECOVERY] CWMT Recovery 5.0.2.7-th7 (T is for TOUCH!) OV
Edit: An even better one is: http://forums.androidcentral.com/opt...012-a.html#anbLast edited by BuggerZ; 07-23-2012 at 11:15 AM.
- 06-06-2012, 04:17 PM #43
Thanks!!
- 06-06-2012, 04:30 PM #44
I use MegaBassBeats
Sent from futuristic optimus s - 06-06-2012, 04:36 PM
Thread Author #45
- 06-06-2012, 06:43 PM #46
- 06-06-2012, 07:16 PM #47
- 06-06-2012, 08:04 PM #48Thanked by 2:
- 06-06-2012, 10:55 PM #49
Let's calm down. O.P isn't forcing any one to use this MOD. if you haven't tried it then let's not judge, especially that way. Just saying. Any way , I noticed a slight crisp improvement..if it's a placebo ..it's fooling me. Plus the improvement is very noticeable when I plugged in my cheap 15$ full ear headphones..sound is nice
- 06-07-2012, 12:40 AM
Thread Author #50
Reply
