I was surfing the play store and found this
https://forums.androidcentral.com/e...d=com.motioncoding.beats&hl=en&token=vl9m50aE
NOTE-
IVE ONLY TESTED ON A GINGERBREAD ROM IM NOT SURE IF ITS WORKING ON FROYO BUT IT SHOULD WORK ON ICS.
It has a list of supported phones and the OV isn't on there. I tested it anyway. Its an app that just copies a .zip file to your SD. The apk file is 13 MB that doesn't do much except give you the files. The newest update doesn't work for the ov. Its v0501 that doesn't work (for some reason) v0317 works great! Improves sound quality. THE ONLY PRPBLEM IS THAT IT BREAKS DSPMANAGER.
How to install -
VERSION 1:
1. Download the app
2. Go through the steps
3. Choose file 0317
4. Boot into recovery
5. BACKUP!
6. Advanced
7. Wipe dalvik cache
8. Install zip from SD
9. DISABLE SIGNATURE VERIFICATION
9. Find the 'Beats Audio.zip' file
10. Install
11. Reboot
12. Delete 'DSPManager' with 'No Bloat Free' if you want
VERSION 2: (saves you 13 MB of RAM)
1. Download the file at the bottom
2. Save it to the root of your SD
3. Reboot to recovery
NOW FOLLOW STEPS 5-12 FROM VERSION 1
Comment your results. Might take about 2-3 minutes longer to boot up.
Download-
http://www.MegaShare.com/4305188
OR
http://www.sendspace.com/file/gfcy4m
NOTE-
How to install -
VERSION 1:
1. Download the app
3. Choose file 0317
5. BACKUP!
6. Advanced
10. Install
11. Reboot
Download-
OR
