Results 1 to 21 of 21
    Default Fool proof ......:D well easy way to get msl from Optimus v
    Check out the open source way to get the Msl from the optimus V
    Watch
    Then punch ubuntu 12.04 in the face
    Thanked by 4:
  2. #2
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    Quote Originally Posted by asadullah View Post
    Lolol I like it haha
    Sent from my VM670 using Tapatalk
    Default Re: Fool proof ......:D well easy way to get msl from Optimus v
    Mission accomplished
  4. #4
    Default
    Asadullah!
  5. #5
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    Niccceee
    Winning!!!! Lmao
  7. #7
    sammyz's Avatar
    Posts
    ROM
    OV:quattrimus OM:BACKside
    Default
    I love how all this stuff is being found as I'm getting an OV soon lol great stuff btw
    Sent from my LG-LW690 using Android Central Forums
  8. #8
    Revenant Ghost's Avatar
    Posts
    ROM
    Mobster/Buttered Toast
    I used CDMA Workshop to get my MSL, so I could change my PRL a couple of times.
  9. #9
    *hands Asadullah a cigar*
    Nice work you boss. I take it you didn't figure out how to make it work on Ubuntu though? Lol.
  10. #10
    sammyz's Avatar
    Posts
    ROM
    Default
    Quote Originally Posted by Revenant Ghost View Post
    That's what I'm gonna use, easiest way.
    Sent from my Optimus M
  11. #11
    inceyet's Avatar
    Posts
    ROM
    MIUIgb
    Default
    Watch
    Excuse the noobness msl?
  12. #12
    Posts
    ROM
    Quote Originally Posted by inceyet View Post
  13. #13
    andrewnelson23's Avatar
    Posts
    ROM
    Quattrimus
    I had seen this cdma tool once before but I couldn't get it to work! makes sense though about resetting w/ volume/power. BOSS!!!!
  14. #14
    Default
    Dumb question on my part, can this be done on Lucid Lynx 10.04? I refuse to use anything with "Unity" installed and have been sticking with the LTS version while I search for a Ubuntu replacement.
  15. Thread Author  Thread Author    #15
    Quote Originally Posted by bornagainpenguin View Post
    It's only for windows right now I believe. You may be able to use a virtualbox but it's gonna be a pain in the *** (like everything else in ubuntu ). If you don't know alot of virtualbox commands it would probably be alot faster to just go ahead and make a windows partition and do it from there. If you do it like that and need some help with something let me know via pm.
    On a whole different note. Did you know that in windows 7 if you right click the taskbar and uncheck,"lock taskbar" then right click again and choose properties you can select to have the taskbar on the left side of the screen just like unity.
    The more you know.
  16. #16
    bjzapp's Avatar
    Where did u hear tht word
    Posts
    ROM
    MiRaGe - IHO CM7.2
    Can you elaborate on this a bit more. Does the phone need to be USB connected or not ? Drivers already installed--Flashed back to stock ROM--ZV9--
    I select the LG platform and click connect and doesn't show me what it's doing....Basically force closes (not responding) and asked to send error report...?
    CDMA Version 3.07.12
    Windows XP
    Thx
    Sent via my ZV5 VMOV(ns)
  17. #17
    bjzapp's Avatar
    Posts
    ROM
    MiRaGe - IHO CM7.2
    Exclamation Re: Fool proof ......:D well easy way to get msl from Optimus v
    Bump:::::
    Still awaiting replies/answers
  18. #18
    cole2kb's Avatar
    Retired Moderator
    Posts
    Global Posts
    4,015 Global Posts
    ROM
    Stock
    Default
    If you're trying to use software on your computer to read the MSL, you must be connected via USB.
  19. #19
    bjzapp's Avatar
    Posts
    ROM
    MiRaGe - IHO CM7.2
    Quote Originally Posted by cole2kb View Post
    ok
    Still have the issue the CDMA program (no response)/ end now.
    Dosen't show anythihng happening or reads any OV data....
    IDK
    I was looking for the 6008 PRL as the latest and, i guess, recommended.
  20. #20
    Do I have to be running the stock rom in order for this to work? It read my spc code fine, but when I try to go to the service code screen ##7678# it doesn't show up.
  21. #21
    vB396530's Avatar
    Banned
    Posts
    ROM
    Quattrimus CM9
    Quote Originally Posted by bedrockhorror View Post
    Yes
