[ROM][WIP]CM9.1.0-BobZ
BobZhome
296
627
ICS = Ice Cream Sandwich(Android 4.0.4)
Builder: BobZhome
Current Version: CM9.0.0-VM670-BobZhome (9-30-2012)
Description: Well, let's be honest. Unless you're living under a rock, you probably know what Android 4.0.4 (Ice Cream Sandwich) is. Furthermore, you should know what the CyanogenMod project is. However, if a rock is really your home and you'd like to learn more, please visit their site: CyanogenMod | Android Community Rom based on Ice Cream Sandwich
==== '''People worked with/owe thanks to:''' ====
CyanogenMOD - Do I need to state why we owe thanks to this guys?
IHO Team - Starting the IHO project
TDM & TheKraven - For all the work they have put into ICS
==== '''What is not working?''' ====
  • USB Tethering
==== '''What is particle working?''' ====
==== '''Changelog''' ====
9-30-12:
  1. Sync'd with CM9
  2. Trimmed Trebuchet: Removed all hdpi & xhdpi content
  3. Trimmed LatinIME: Removed all dictionaries except English & Spanish
  4. Changed Script: Now using A2SD++ thanks to Croniccorey over on XDA(see Q & A below for more info)
  5. Fixed Camera Panorama View: Thanks to TheKraven
9-1-12:
  1. Sync'd with CM9: We are now at 9.1.0
  2. Moved: Dalvik-Cache back to the Data partition(see Q & A below for more info)
  3. Fixed: Boot up..."Android is updating" is gone :'(
8-16-12:
  1. Sync'd with CM9: We are now at 9.0.0 Stable, more info here
  2. Kernel v4.1: Better deep sleep
7-27-12:
  1. Sync'd with CM9
  2. Fixed: USB storage...now working for windows also
  3. Fixed: Brightness...Thanks to danmogger for helping me find the problem!
  4. Fixed: Bluetooth...disconnecting no longer cause reboots
7-20-12:
  1. Sync'd with CM9: We are now at RC2(Release Candidate)
  2. Added: Spainish language back in Again
  3. Kernel v4: Upgraded from 2.6.35.8 to 2.6.35.14
7-3-12:
  1. Sync'd with CM9
  2. Fixed: Bluetooth Headset calling
  3. Fixed: Wired Headset Microphone
  4. Kernel v3 = Tweaked: 1) Hitachi screen drivers 2) Overclock GPU(but didn't see any difference) 3) Adjusted Proximity Sensor
6-29-12:
  1. Sync'd with CM9: We are now at RC1(Release Candidate)
  2. Fixed: Speaker Phone's low volume
  3. Added: More Asserts - Hopefully the other recoveries will play nice :-*
  4. Kernel v2.9 = Fixed: PPTP - VPN thanks to Blackhive
6-22-12:
  1. Sync'd with CM9: Fixed MMS on stock messaging app
  2. Fixed: Camcorder(you need to use Videocam Illusion from the market(play store) - Thanks to thekaven!
  3. Added: Spain language back in
  4. Added: Trebuchet back in
  5. Removed: Launcher Pro
6-16-12:
  1. Initial Release
  2. Added: Launcher Pro
  3. Removed: VideoEditor, foreign dictionaries, foreign keyboards, foreign fonts, large ringtones, Live Wallpaper, CM wallpaper, and CM ringtones
  4. BobZics Kernel v2.8
==== '''Download Links''' ====
NOTE: First Boot takes about eight minutes on my phone, be patient!
Build 9/30: cm-9.1.0.VM670.BobZhome.09302012.zip MD5checksum= 346c23bcb3a5776696b0c89449a250b8
Custom Gapps(smaller): gapps-ics-20120429-BobZ.zip MD5checksum= 971373a429db999b0b2fdf0ec1363956
Latest Gapps: gapps-ics-20120429-signed.zip MD5checksum= 7c524e1e078164f681e0aa6753180b2c
ClockworkMod Recovery: VM670NH_recovery.img MD5checksum= 4196aac89f95ee7b468c53b5ffacf9db
==== '''Helpful Tips''' ====
Overclocking is available in Settings --> Performance --> Processor. Tweak it as you like, but know this: not all OV's were created equally.
==== '''Q & A''' ====
Q: What Baseband will this work on?
A: It works with all current Baseband, you do NOT need to update your Baseband, I'm still on ZV4 :)
Q: Do I need the VM670NH recovery to install this ROM?
A: No, it's the one I use and recommend :-*
Q: Can I use an A2SD script with this ROM?
A: No need...the rom will move your apps and dalvik to the EXT partition on your SDcard, if you have an EXT partition!
Q: Do I need an SDcard with EXT partition to install this ROM?
A: No, but it is very recommend to have one.
Q: Why was so much removed from your ROM?
A: This OS is so big it leaves very little room on your phone for your stuff.
Q: What do you mean by "foreign"?
A: Anything other than English and Spanish.
Q: Why was Dalvik-Cache moved back to the Data partition?
A: Gapps did not like it being on the SD-EXT partition and you would get the "Optimizing app x of xx" with every boot up. NOTE: Dalvik does get really big, you may run out of room in Data if you have a lot of apps. NOTE 2: Apps are still in the SD-EXT partition, only Dalvik was moved.
Q: Why did you change scripts?
A: The A2SD++ script is written better, which allowed me to put Dalvik-Cache back on your SD-EXT partition without any issue. I did edit out parts of the A2SD++ because there is no easy way to erase the Apps-Private and Apps-Data info from the SD-EXT, so I wanted to keep the info on the phones DATA partition. Keeping the old info when flashing a new ROM creates issues, just like when you do a dirty flash. Also I found the ZipAlign did not work as well as the one I was using, so I removed that part of the code from the new script.
==== '''Resources''' ====
https://github.com/BobZhome
Enjoy!
curtis1973
King Of Pants
Aug 7, 2011
672
131
yeah the download link is saying g-t-r in mobile browser with broken link. check back on later. :thumbup:
kcls
901
307
63
Re: [ROM][WIP]CM9.0 RC0-BobZ
Sweet! Can't have enough CM9 :D Looking forward to see where you go with this Bob, I remember how excited I was when you first got ICS booting on the V.
Ryuk6666
489
88
Came across this thread cuz I normally just go through my favs on tapatalk and i decided "hey why not check out some new threads" and I was like SCORE!!! We now have a total of 4 ics roms :D
Sent from my Cybertronian QuattrOV using Tapatalk 2000 (Now With Teleka-Typing!!!!)
Reactions: inceyet
rukin5197
1,105
628
Finally decided to put all his hard work publicly.
Question: My little brother had a HORRIBLE bug with force (hot) reboots with your test build. Does this version have it as well?
Tejer
80
14
Oh yes, gonna give CM9 a try vs your CM7 ROM! I think I'll stick with your CM7 rom though until this gets working video recording, especially since CM7.2 should be going final I believe :)
kerokekerol
