[ROM][WIP]CM9.1.0-BobZ
BuggerZ
139
40
Re: [ROM][WIP]CM9.0 RC0-BobZ
BobZhome: The asserts in your updater-script are failing in Drew's Cannibal recovery for VM670. It was happening to TDM as well, and he fixed it (and so can you) by changing his asserts to the following:
Code:
assert(getprop("ro.product.device") == "thunderc" || getprop("ro.build.product") == "thunderc" ||
       getprop("ro.product.device") == "VM670" || getprop("ro.build.product") == "VM670" ||
       getprop("ro.product.device") == "thunderc_VM670" || getprop("ro.build.product") == "thunderc_VM670");
Thanks!
Reactions: BobZhome
zoidberg_md
79
11
what are your oc settings? i had two reboots so far
I was using interactivex - 320/748 - with this governor, I purposely don't set it to high.
On a side note -
Does anyone know about apps2sd or links2sd ? I'd like to be able to move apps to the sd card, does this rom support it ?
mrg666
730
1,067
You and/or anyone else can build off my github and help fix the remaining issues.
I just finish a build with Linaro 4.7.1 toolchain and it booted :eek:
EDIT: Please PM me, if you have a LS670 with ZVD baseband and wish to test a build.
I don't have a LS670 but I will try to find another spare OV for ICS testing/development.
Reactions: Badboytoast
prime0025
83
4
Any app to replace dsp manager? Doesnt seem to make a difference in volume in ics.
Sent from my VM670 using Android Central Forums
curtis1973
King Of Pants
Aug 7, 2011
672
131
a few app related issues that could just be ics not being compatible with... skyfire wont display pages,just solid white,videos in skyfire (for one page that did load..) only plays sound,no video. and the hack flash player for the v doesn't seem to function in this version of stock browser. just shows plugin box where player should be. not sure if thats because this browser has no plugin option in settings or if its just ics related or rom. but these items dont appear to work. shoot...ill miss my "benny hinn" videos :( lol
rebel69ization
501
106
On a side note -
Use interactiveX 480min 825max i had no reboots with these settings, i use rom toolbox pro for app moving. It will even tell you what apps are safe to move to the sd.
ThatGuyLurkin
2,155
665
Code:
Thanks!
The point where you said " and so can you ".
Its not really a big deal, change recovery, don't flash, edit yourself.
sellers86
1,837
617
running smooth as always bob. I have not encountered any problems that arent know, and if i do i will be sure to let you know. as always, thanks for the great work!
rebel69ization
501
106
works like clockwork...for the most part. I've only experienced intermittent 3G loss,toggling data restored it promptly. also,can anyone suggest a top notch cm9 theme that actually works and isn't just crayon colored crap of the original ics theme? and no offense to cartoon colored crap,its just not for me lol :thumbup:
edit: I misread your post. I thought it said does this rom work ( I wear glasses,and I need to put them on now.. lol)
Nate modz xdhpi cm9
Reactions: curtis1973
Billzilla
Active member
Feb 19, 2011
44
i cant get my phone to charge on this or any ics rom using 4.xxxx any got any ideas how to get this to work. gb roms will let me charge the phone however
drm1992
267
45
I am currently having issues with MMS not working. Am I the only one or is someone else having the same problems. On another note can I grab apns.config file in the etc folder and swamp it out from another 4.0 rom that has it working?
Sent from my VM670 using Tapatalk
BuggerZ
139
40
I edited the package myself and fixed it. ;) But the problem will still be there until it's fixed and changed, hence me making the note. :)
BobZhome
296
627
On a side note -
You don't need any A2SD scripts...the rom already moves your apps to an ext partition, if you have an ext partition.
I should have said so in the OP...sorry :-[ I'll add it now!
Reactions: zoidberg_md
Dominic Haar
