Page 4 of 14 FirstFirst 1234567 ... LastLast
Results 76 to 100 of 329
Like Tree50Likes
  1. Thread Author  Thread Author    #76
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default Re: [ROM][ALPHA][WIP][ICS]: CodenameAndroid
    Quote Originally Posted by ilikechicken123 View Post
    I wish I could help. Testing is the only way I can help. I just love this rom! I am excited for it to start working... I just need video and camera fixed and I could live. If you need testers, I'm here. Sorry I can't do more..
    video and camera will be the last things to be fixed... theres no gaurentee the code will work for it.
    Guess whos coming back!
  2. #77
    ilikechicken123's Avatar
    Posts
    ROM
    MiRaGe
    I can wait c: good luck ;D
    Thanked by 2:
    sellers86 likes this.
  3. #78
    topdawg661's Avatar
    Posts
    ROM
    The GODZILLA Rom
    Default
    Bump
    Don't want this bad boy to get lost
    Sent from my at100 using Tapatalk 2
    Thanked by 2:
  4. Thread Author  Thread Author    #79
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    working on a new build now. hopefully it will fix some issues, no guarentees though
    Thanked by:
  5. Thread Author  Thread Author    #80
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    updated OP with a feature list.
    Thanked by:
    sammyz
    sammyz likes this.
  6. #81
    cole2kb's Avatar
    Retired Moderator
    Posts
    Global Posts
    4,026 Global Posts
    ROM
    Stock
    Default
    After reading this feature list, I'm a bit confused as to hhow this is any different than aokp. Can anybody shed some light for me? Thanks!
  7. #82
    Default
    This isn't to much different from AOKP, but when you using the UI, its alot different. Only way is to flash and view.
    Thanked by 2:
  8. #83
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Gonna retest the LS670 build I have a couple ideas
    I don't care who u are this is an awesome song
  9. #84
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    I fixed my probs everythings works great except wi fi ect. Can u make ur latest build for the optimus s
  10. #85
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Btw on s its not smooth for some reason
  11. Thread Author  Thread Author    #86
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    Quote Originally Posted by jonny5449 View Post
    Try adjusting advanced settings.
  12. #87
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Quote Originally Posted by sellers86 View Post
    I did still no go
    Please note I'm running ls670 version not latest build
  13. Thread Author  Thread Author    #88
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    I did still no go
    Only different thing in the latest build is a new keyboard. Still same zip. Crazy idea, but it could be that its not made for your phone . Jk. Try downloading apex launcher from the market.
  14. #89
    Zhara's Avatar
    Queendroid
    Posts
    ROM
    Stock
    Default
    Or it may not be smooth because you're testing like 3 roms a day, johnny. You have to give your phone a break and let it settle in sometimes...
    Not trying to be mean but I don't see how you can accurately test if you constantly jump from rom to rom.
  15. #90
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Quote Originally Posted by Zhara View Post
    U have a point.......... OK will do
    Rocking quattrimus and cna
  16. #91
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    One question sellers posted a ls670 build a little while ago I used that maybe it was slow cuz of kernel for different phone ? Just checking
  17. Thread Author  Thread Author    #92
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    That's part if what I meant by made for a different phone.
  18. Thread Author  Thread Author    #93
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    i got the new build to compile, will test in a bit.
  19. Thread Author  Thread Author    #94
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    no go. Still no wifi. I dug my laptop out and grabbed the wireless.ko from bobs rom and made a change to the build.prop. ill test sometime. I'm lazy
    Thanked by:
  20. #95
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Here's wat I did on s . After install sit for 20mins
    Changed carrier name on lock screen
    Installed CAI kernel
    Clocked to 768 Max smartassv2
    Smoother than before but not the smoothest rom I have had but let's see if my phone likes it and decides to make it smoother
    Also installed apex
    Thanked by:
  21. Thread Author  Thread Author    #96
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    made some progress on wifi... but not enough. i got it to turn on, but it doesnt pick any up. It was the build.prop edit that allowed it to turn on. I tried adding the wireless.ko from bobs build that i took the boot.img from and i get nothing. I honestly have no idea what to do at this point... ill check out the permissions.
    Thanked by:
  22. #97
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Kool when wi fi works ill be on in a jiffy
    I'm Rockin G.T.R On My Optimus $
  23. #98
    tcrider84's Avatar
    Posts
    ROM
    Quattrimus CM9 beta1pre3
    Im working on it, i just have no idea whats wrong with it...
    got a link to your github/sources? ive been working with the v's wifi settings lately trying to get tethering to work. i might have a quick fix for the rom. what vendor files are you using and what kernel?
    Thanked by:
  24. Thread Author  Thread Author    #99
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    Quote Originally Posted by tcrider84 View Post
    I haven't done any git, the vendor files are bobzhomes ics and the device files are modified bobzhome ics. Its not the kernel, I've tried different kernels. I've switch the wireless.ko in system/lib/modules with the one from the rom I pulled the boot.img from. The reason it wouldn't turn on is because the build.prop had it set to eth0 instead of wlan0. Now it will turn on, it just wont pick anything up.
  25. #100
    topdawg661's Avatar
    Posts
    ROM
    The GODZILLA Rom
    Default
    I wish I was a dev to help. The only thing I can offer is me being a test subject haha you ever need one for any rom just pm!
    Thanked by:
