Page 5 of 14 FirstFirst ... 2345678 ... LastLast
Results 101 to 125 of 329
Like Tree50Likes
  1. Thread Author  Thread Author    #101
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default Re: [ROM][ALPHA][WIP][ICS]: CodenameAndroid
    made some edits to the boardconfig.mk (wifi changes) and im running a build now. wish me luck
    Guess whos coming back!
    Thanked by 2:
  2. #102
    tcrider84's Avatar
    Posts
    ROM
    Quattrimus CM9 beta1pre3
    Quote Originally Posted by sellers86 View Post
    I haven't done any git, the vendor files are bobzhomes ics and the device files are modified bobzhome ics. Its not the kernel, I've tried different kernels. I've switch the wireless.ko in system/lib/modules with the one from the rom I pulled the boot.img from. The reason it wouldn't turn on is because the build.prop had it set to eth0 instead of wlan0. Now it will turn on, it just wont pick anything up.
    wireless.ko shouldnt matter, all of them are built from the same bcm4325 drivers located inside the kernel (system/kernel/lge/thunderc/drivers/net/wireless/bcm4325)
    the wifi section of your vendor/lge/thunderc-common/boardconfigcommon.mk should look like this:
    Code:
    #Wifi
    WPA_SUPPLICANT_VERSION          := VER_0_6_X
    BOARD_WLAN_DEVICE               := bcm4325
    BOARD_WEXT_NO_COMBO_SCAN        := true
    BOARD_WPA_SUPPLICANT_DRIVER     := WEXT
    WIFI_DRIVER_HAS_LGE_SOFTAP      := true
    WIFI_DRIVER_MODULE_PATH         := "/system/lib/modules/wireless.ko"
    WIFI_DRIVER_MODULE_ARG          := "firmware_path=/etc/wl/rtecdc.bin nvram_path=/etc/wl/nvram.txt config_path=/data/misc/wifi/config"
    WIFI_DRIVER_MODULE_NAME         := "wireless"
    WIFI_DRIVER_FW_PATH_STA         := "/system/etc/wl/rtecdc.bin"
    WIFI_DRIVER_FW_PATH_AP          := "/system/etc/wl/rtecdc-apsta.bin"
    BOARD_SOFTAP_DEVICE_TI          := bcm4325
    the following should be removed from bobzome's boardconfigcommon.mk with reasons listed:
    hostapd configuration is not set in /kernel/arch/arm/configs/thundercvm670_defconfig, so this is not necessary:
    BOARD_HOSTAPD_DRIVER := bcm4325
    only wpa_supplicant 8 uses external lib, and only bcmdhd drivers work with it, so this is not needed:
    BOARD_HOSTAPD_PRIVATE_LIB := lib_driver_cmd_wext
    the bcm4325 does not have a p2p driver. it has the wlan driver(rtecdc.bin) and the soft ap driver (rtecdc-apsta.bin), furthermore p2p was not introduced until wpa_supplicant 8, and is not a feature in wpa_supplicant 6. the coding for the drivers themselves in the kernel have NO support for p2p, so chances are wifi-direct will not work for the OV. this is not needed:
    BOARD_P2P_DEVICE_TI := bcm4325
    I learned all this after spending a week fighting with the broadcom drivers. I still havent updated my github with the correct settings >.>
    Thanked by:
  3. Thread Author  Thread Author    #103
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    those were almost the exact edits i made. the wifi settings in the boardconfig were a little odd in order and there were missing parts so i pulled the wifi section of the boardconfigcommon on my cm9 build and threw them in there.
  4. #104
    tcrider84's Avatar
    Posts
    ROM
    also the system/vendor/lge/vm670/vm670-vendor-blobs.mk should include this for the wireless proprietary files to copy over:
    Code:
    # Wifi
    PRODUCT_COPY_FILES += \
        vendor/lge/VM670/proprietary/system/etc/wifi/wpa_supplicant.conf:system/etc/wifi/wpa_supplicant.conf \
        vendor/lge/VM670/proprietary/system/etc/wl/nvram.txt:system/etc/wl/nvram.txt \
        vendor/lge/VM670/proprietary/system/etc/dhcpd/dhcpcd.conf:system/etc/dhcpcd/dhcpcd.conf \
        vendor/lge/VM670/proprietary/system/etc/wl/rtecdc.bin:system/etc/wl/rtecdc.bin \
        vendor/lge/VM670/proprietary/system/etc/wl/rtecdc-apsta.bin:system/etc/wl/rtecdc-apsta.bin \
        vendor/lge/VM670/proprietary/system/etc/wl/rtecdc-mfgtest.bin:system/etc/wl/rtecdc-mfgtest.bin \
        vendor/lge/VM670/proprietary/system/etc/firmware/wlan/cfg.dat:system/etc/firmware/wlan/cfg.dat \
        vendor/lge/VM670/proprietary/system/etc/firmware/wlan/qcom_cfg.ini:system/etc/firmware/wlan/qcom_cfg.ini \
        vendor/lge/VM670/proprietary/system/etc/firmware/wlan/qcom_fw.bin:system/etc/firmware/wlan/qcom_fw.bin \
        vendor/lge/VM670/proprietary/system/bin/wl:system/bin/wl
    Thanked by 2:
  5. #105
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    How close is wi fi
    I'm Rockin G.T.R On My Optimus $
  6. Thread Author  Thread Author    #106
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    idk yet
    Thanked by 2:
  7. Thread Author  Thread Author    #107
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    well, i screwed my build environment up. lol. probably done for today, ill work more tomorrow.
  8. #108
    Badboytoast's Avatar
    Posts
    Global Posts
    822 Global Posts
    ROM
    ICS 2.3.7/ tvall kernel
    Default
    Quote Originally Posted by tcrider84 View Post
    Code:
    # Wifi
    Could you post this file/. And help seller find a fix, also the camera preview would be nice just a suggestion
    Because CNA its the Rom!!
    Thanked by:
  9. Thread Author  Thread Author    #109
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    Quote Originally Posted by Badboytoast View Post
    He doesn't need to post the file, I already have it (both for cm9 and cna). Ill try getting camera preview sometime but I'm not sure if the code will work or not.
    Thanked by:
  10. #110
    Posts
    Global Posts
    822 Global Posts
    ROM
    Default
    Cool!
  11. #111
    topdawg661's Avatar
    Posts
    ROM
    The GODZILLA Rom
    Default
    Would the wifi fix zip on xda work?
    Sent from my VM670 using Tapatalk 2
    Thanked by:
  12. Thread Author  Thread Author    #112
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    Quote Originally Posted by topdawg661 View Post
    Idk. I'm not at home right now, ill check it out tomorrow
    Thanked by:
  13. #113
    inceyet's Avatar
    Posts
    ROM
    MIUIgb
    Default
    Yo sellers don't know if this has been addressed but I didn't see no music player I need my player side note I can get my own which I did aside that and the known bugs which I know your on your way to fixing can't wait and drews touch recovery works with this. thanks for the hard work
    Thanked by:
  14. Thread Author  Thread Author    #114
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Quote Originally Posted by inceyet View Post
    Ill pull apollo from my cm9 build and put it in there.
    Thanked by 2:
  15. Thread Author  Thread Author    #115
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    my guess is no, ill give it a shot sometime though.
    Thanked by 3:
  16. #116
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Gonna test wi fi fix wish me luck.....
    Looking for good cm9 or cm7 themes??? visit this site for good themes.
  17. #117
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Nope failed status0
  18. Thread Author  Thread Author    #118
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    Quote Originally Posted by jonny5449 View Post
    Nope failed status0
    Well then you would have to install the apk by itsself. But it wouldn't work anyways because there is an edit that needs to be made in the build.prop
  19. #119
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Hmmmmmmmmmmmmmm
  20. Thread Author  Thread Author    #120
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    Hmmmmmmmmmmmmmm
    Hmmmmm what?
  21. #121
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Hmmmmm what?
    Trying to think
    Looking and comparing build.props see if I can help but I'm not that smart gonna start looking into sense on the s cuz its being recontinued
  22. Thread Author  Thread Author    #122
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    Trying to think
    I already know the edit. Search eth0 and change it to wlan0
  23. #123
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    When will u upload build with fix then?????
  24. Thread Author  Thread Author    #124
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    all it does is allows the wifi to turn on. But you can't connect or find any hotspots.
  25. #125
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Weird
