Data speed increase
reaper420
215
21
Hello all, I was recently looking for a way to fix my wifi problems on the Ics roms and came across this thread to increase data speeds. I have flashed it using the latest mirage build and my wifi speeds have increased one mgb faster. I have no idea how it works for 3g because I have to drive a good ten miles to even get 3g, but wifi has sure increased in speed. So here's the link for anyone who wants to try it
http://forum.xda-developers.com/showthread.php?t=1675457
Think it would work on cna
CodeName Android da place to be :p
It should but they say it doesn't always stick when you flash on Ics, so you might have to manually place the file in your phones system
I don't believe increasing your wifi. Ya know hoe you have High Speed, and that stuff? Verizon, Comcast, Netgear? Wouldn't the max be what the box is pushing out?
I should have specified on that, my broadband has a max of 5mgb, but I have only ever been able to get 2.5 to 2.8 on my phone for some reason. After this I'm getting 3.8 to 4
[MOD]Data Speed Tweak [ICS/GB][Wifi/3g/4g]>Flashable ZIP< - xda-developers
am trying it now be back soon with my findings :)
RayAndrews
