01-07-2013 05:03 PM
37 12
tools
  1. terthii's Avatar
    How can I find out what's doing it? I would hate to think it was my battery monitor...lol
    There's still an issue with the phone not going into deep sleep mode in Quattrimus.
    07-19-2012 01:34 PM
  2. Locool676's Avatar
    I wanted to chime in on this because I ran into the same problem with the Godzilla Rom. I had the one piece charger, meaning it was not the USB cable and wall plug in two parts. However, my girlfriend has a two piece charger. I tried it and whoa, my phone is charging. So I bought a two piece charger from eBay for $5 and it solved my charging problems. So op, if you have not tried to change your charger, buy a new one and see if that fixes it.
    07-22-2012 10:01 AM
  3. josh2903's Avatar
    Yeah I had gotten to sick of switching out batteries to continue trying to find out a solution to this problem so have since switched roms. If anyone figures this out though please let me know as I would much rather be running the Quantimus Rom.
    07-24-2012 11:25 PM
  4. sellersj27's Avatar
    What monitor are you using? I have had a few that will wipe a battery out in 4 hours! I run AOKP with very heavy usage....usually throttled 3 weeks in...and my battery will last a full 12 hours.
    07-25-2012 12:28 PM
  5. varockchick's Avatar
    I've noticed my phone goes into deep sleep on aokp but doesn't on cm9...sad part is I like cm9 better
    07-30-2012 12:14 PM
  6. kjmott's Avatar
    I tried 2 different chargers and I tried my car charger and still no go with any of them.
    Anyone have any luck yet with finding a fix for this?
    08-06-2012 08:55 PM
  7. josh2903's Avatar
    I downloaded the latest nightly and now the problem appears to be fixed because my phone is charging successfully!
    08-08-2012 01:57 AM
  8. kjmott's Avatar
    No luck for me. What recovery are you using? What is the exact method you use to flash the rom? I'm hoping somethings not lingering around causing the phone not to charge.
    Thanks
    08-09-2012 09:09 PM
  9. kjmott's Avatar
    Just thought I would bump this again.
    I am still not able to charge on any JB or ICS rom. I just wondered if anyone had any more suggestions on what to try. Thanks for any help.
    09-24-2012 10:07 AM
  10. ochenta's Avatar
    I'm also running into this problem...does your phone's USB mass storage feature work in GB roms? I can charge my phone on GB roms but am unable to use USB mass storage, I wonder if my phone's miniUSB is somehow responsible.
    10-01-2012 11:10 PM
  11. kjmott's Avatar
    I am unable to use the usb mass storage feature. I have no clue as to why I can't.
    01-06-2013 08:24 PM
  12. AndyOpie150's Avatar
    Have you tried going to the USB debugging option and as fast as you can, uncheck then recheck the box?
    01-07-2013 05:03 PM
37 12
