01-05-2016 04:35 PM
2,975 ... 111112113114115 ...
tools
  1. koeylondon's Avatar
    @kakapopo- Try the alternate site, and use mirror 3 (which is internally hosted). All should work for downloads.
    @Purplehaze- Try clean installing, making sure to clear your cache, data, and dalvik cache. Remember to backup you shtuff of you'll lose it all!
    11-02-2012 10:05 AM
  2. purpulehaze's Avatar
    Ty but that's just the problem I wiped it twice and clean flashed but I'm still having the problem
    11-02-2012 11:59 PM
  3. brotherswing's Avatar
    Try flashing it twice, then reboot to the system twice, then flash your additional zips. See how it works then....
    Repensum Est Canicula
    11-03-2012 12:09 AM
  4. ThatGuyLurkin's Avatar
    Not really. Same happened with IHO backside. Jerry just disappeared without good bye. Last TDM post is from oct 12. ... is November now. Last update is from.... I don't even remember. So I think we can call it.
    Look at MRG. He disappeared for nearly 2 months, and came back with an updated Mirage.
    Sent from my HTC One V using Tapatalk 2
    Anonymo, EnMod, ZackVortex and 2 others like this.
    11-03-2012 10:00 AM
  5. unknownsoldierx's Avatar
    Has anyone gotten the Amazon Kindle app to work? It loads the splash screen, then it force closes.
    11-03-2012 01:10 PM
  6. droiddekka's Avatar
    is there any reason this ROM would not work on the Optimus M?
    inquiring minds want to know.
    11-03-2012 09:52 PM
  7. thekraven's Avatar
    Needs a different kernel due to a different LCD, so you'll either get a blackscreen or no touch on the touchscreen.
    droiddekka likes this.
    11-03-2012 10:51 PM
  8. droiddekka's Avatar
    Cool thanks.
    11-04-2012 03:17 PM
  9. chcub1's Avatar
    Audio Routing Fix: https://github.com/thekraven/android...e9f36cad3b6fea
    Camera Fix added late last month: https://github.com/thekraven/android...f52cf774a6429d
    Unfortunately, I can't find the USB Fast Charge commit. I also couldn't find the Home Button to answer call commit. I will continue searching, though. The later is important to me, the former seems to be popular right now (I never use it, anyway).
    how do you use these codes to fix the audio and camera? O.o
    11-04-2012 04:03 PM
  10. chcub1's Avatar
    does anyone know where to get gapps?
    11-04-2012 06:13 PM
  11. johnh02's Avatar
    Go to the alternate page from op and download the gapps
    Sent from my iPhone 5 using Tapatalk 2
    11-04-2012 06:15 PM
  12. koeylondon's Avatar
    Unfortunately, that would require another source build for this. As it stands, it's unlikely to happen (unless TDM proves us wrong...). Again, we're waiting for word from TDM. Anything else is speculation.
    11-04-2012 11:25 PM
  13. chcub1's Avatar
    4.2 Camera here.
    [url]http://forums.androidcentral.com/showthread.php?t=220830Didn't
    Do I jfr
    How do I Install this? i2
    11-05-2012 12:17 AM
  14. koeylondon's Avatar
    Unfortunately, I don't think it's working for us. I tries sideloading it (by placing it in the apps folder and editing permissions) and it FCed every time.
    11-05-2012 12:22 AM
  15. jiggygeek's Avatar
    If something isn't broken, don't fix it or a buy a new one. I just put Q cm9 version on my OV and it works great. I was using a custom rom cm7 from the beginning when I first got the OV.
    The only difference in the new phones: bigger screens, more rez on the cameras, higher bluetooth, the latest android os, etc, but if all you need is an android phone to check mail and get online when you're away from home, why buy a new phone? Wow, a screen thats .5 inches bigger, big whoop. a camera thats 2 mp more. who cares. I'm locked into the $25 rate. when i buy a new phone, they will put me into the $35 rate. So why buy, when I can use Q and keep updating the android os. It might be nice to have beats audio on the Q
    11-05-2012 03:53 AM
  16. brotherswing's Avatar
    Beats audio can be found here...
    http://forum.xda-developers.com/show....php?t=1525226
    11-05-2012 04:48 AM
  17. koeylondon's Avatar
    IMHO, the reason I'm looking to upgrade has more to do with wanting 4g data and a faster phone. Also, I want to try a nexus phone. I have to admit, I get jealous of my wife's iPhone. She has the bigger tech. I wants to catch up!
    11-05-2012 11:28 AM
  18. brotherswing's Avatar
    There isn't any 4G near me, so upgrading my phone wouldn't do me any good. Besides, my OV is still running strong.
    11-05-2012 12:07 PM
  19. chuckconnors's Avatar
    Can someone tell me if a version of Google Now exists that works with this ROM? If so, do I need to somehow remove the existing Google Search and then install the Google Now apk (m6-velvet.apk?). How do you remove the existing Google Search app?
    11-05-2012 01:16 PM
  20. sdxben's Avatar
    no need to remove. just go in root explorer and change it to have no permissions and rename it to whatever you like
    11-05-2012 02:12 PM
  21. chuckconnors's Avatar
    Excellent. Can I bother you to tell me the path and filename? Looked in /system/app and only found GoogleQuickSearchBox.apk .
    11-05-2012 02:30 PM
  22. brotherswing's Avatar
    /system/apps
    11-05-2012 02:32 PM
  23. chuckconnors's Avatar
    and GoogleQuickSearchBox.apk is the apk, right?
    11-05-2012 04:27 PM
  24. brotherswing's Avatar
    Correct, good sir.
    11-05-2012 07:09 PM
  25. clodfelterac's Avatar
    @chuck--- just delete the original and paste/rename velvet to GoogleQuickSearchBox.apk to system/app... (I didnt have to adjust permissions, i added preflash via pc/gedit)
    brotherswing likes this.
    11-06-2012 02:03 AM
