- 11-16-2012, 09:39 AM #2851
- 11-16-2012, 11:20 AM #2852
- 11-19-2012, 06:43 PM #2853
Re: [ROM][BETA] Quattrimus ICS
I've been running Quattrimus beta 2 CM9 for quite some time now. At work I have no service, no wifi, and no 3G. I find that when I leave work I have to do a reboot to get the 3G working again. Is there a fix for this or a better way to re-enable it? Also, can anyone tell me the difference between CM9 and AOKP? Should I go to the AOKP, why or why not?
“The things you used to own, now they own you.”
― Chuck Palahniuk, Fight Club - 11-19-2012, 06:51 PM #2854
Toggle airline mode, that will restore the connectivity. For the difference between CM9 and AOKP, AOKP is CM9 with a ton of customization options (like BACKside to CM7) but YouTube performance is awful on it. Those are the biggest things you'll notice.
Repensum Est CaniculaThanked by: - 11-19-2012, 06:55 PM #2855
- 11-19-2012, 11:33 PM #2856
- 11-20-2012, 12:28 AM #2857
You can also get a widget or app on market. I use Data on/off widget. I sometimes have the same issue when my subway train goes from underground to above ground. I just click the widget to turn off, then again to turn on.
Sent from my Zombie ICS-VM670 using Xparent Red Tapatalk 2Thanked by: - 11-20-2012, 03:59 PM #2858
How do I turn off automatic brightness off? I looked in display in setting I didn't see an option so I put the power widget and that didn't help. After that I dis the status bar widget and that too did not work.
Sent from my LG-VM670 using Xparent Red Tapatalk 2I love this show - 11-20-2012, 07:07 PM #2859
- 11-20-2012, 07:14 PM #2860
- 11-20-2012, 07:31 PM #2861“The things you used to own, now they own you.”
― Chuck Palahniuk, Fight Club - 11-20-2012, 07:59 PM #2862
- 11-20-2012, 09:00 PM #2863
Great, I never had a problem with the auto brightness since I never used it. Now I can't get it to go away either. I don't think it works though. The widget button in the notification drawer now looks like it is always in auto but touching it cycles through the brightness levels. I'll keep an eye on it to see if it changes brightness on its own.
― Chuck Palahniuk, Fight Club - 11-20-2012, 09:03 PM #2864
- 11-24-2012, 10:29 AM #2865
Few things i'd like to bring up..
The calling app is very laggy at times..
Slow Performance at times.
Random Reboots.
Apps won't download, only when using this rom..
other then that, the overall quality is good rated 9.5/10
few more but i can't think of..
Best Regards,
Vivider - 11-24-2012, 02:20 PM #2866
- 11-24-2012, 06:48 PM #2867
- 11-24-2012, 09:27 PM #2868
- 11-24-2012, 10:13 PM #2869
- 11-24-2012, 11:32 PM #2870
[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Sent from my LG-VM670 using Tapatalk 2This space intentionally left blank. - 11-25-2012, 08:59 AM #2871
- 11-25-2012, 11:08 AM #2872
- 11-25-2012, 12:09 PM #2873
- 11-25-2012, 01:13 PM #2874
Know the feeling lol I change a lot too. With the current development on cai I've been content playing with it lately. I still want to make my way back to cyanmobile too. Soo many good roms so little time!
Tapatalk'n it from my Cold As Ice VM670 running LS670ZVJ firmwareLast edited by thewraith420; 11-25-2012 at 01:47 PM.
- 11-25-2012, 09:12 PM #2875
Reply
I'm on CM9
