Page 117 of 119 FirstFirst ... 114115116117118119 LastLast
Results 2,901 to 2,925 of 2961
Like Tree539Likes
  1. #2901
    upconvert's Avatar
    Posts
    ROM
    Cold as Ice
    Default Re: [ROM][BETA] Quattrimus ICS
    This thread has some good ideas for utilizing your sd-ext partition.
    http://forums.androidcentral.com/sho....php?p=2395617
    Sent from my GT-P7310 using Android Central Forums
  2. #2902
    Can we use those scripts with quattrimus?
    Sent from my Nexus 7
  3. #2903
    upconvert's Avatar
    Posts
    ROM
    Cold as Ice
    I've never tried, but I'd assume it has init.d support. Make a backup and give it a try.
  4. #2904
    Upconvert: Quattrmus already has a program that is linking data/apps to sd, and says in the instructions that any other appsto program will mess it up.
  5. #2905
    Aokp nightly battery drained to 48% in less than 2hrs
  6. #2906
    Quote Originally Posted by jxc011 View Post
    Try to turn the CPU down. Or try a new govern.
    Sent from my HTCEVODesign4G using Tapatalk 2
  7. #2907
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Quote Originally Posted by classpro View Post
    Quattrimus has scripts built in for sdext. Other scripts can cause conflict
    Sent from my PG86100 using Android Central Forums
    Guess whos coming back!
  8. #2908
    upconvert's Avatar
    Posts
    ROM
    Cold as Ice
    Quote Originally Posted by sellers86 View Post
    You can delete those, as it says in the thread I linked. It sounded like the script wasn't working for classpro, as they were running out of space.
  9. #2909
    The script doesn't link the data/data directory, only data/apps. I thought maybe titanium would let me selectively link data files to the ext partition, but it doesn't work so far. Am I the only one with space issues? We have so little hardware memory on this phone....
  10. #2910
    Upconvert: I don't see anything in the thread you linked about deleting the built in quattrimus scripts.
  11. #2911
    upconvert's Avatar
    Posts
    ROM
    Cold as Ice
    Perhaps that wasn't clear enough. It said "sometimes you need to experiment with which scripts to delete, and which to add." Sorry if that was confusing.
  12. #2912
    Ryuk6666's Avatar
    Posts
    ROM
    AOKP
    Just thought I'd pop in to say hi. I noticed tdm hasn't posted some October 12th. I wonder what happened...... Maybe family issues. I hope he comes back. I still use my ov as an mp3 player (even though the processor is almost fried)
    Sent from my AOKP JB One V.
    sellers86 likes this.
  13. #2913
    HavocX's Avatar
    Posts
    ROM
    Quattrimus: 4.0.4
    Is the Quattrimus been updated? I don't think it has been updated since this build quattrimus-VM670-cm9-nightly-20120721. Any info on updates?
  14. #2914
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Quote Originally Posted by HavocX View Post
    Go back two pages and look at Coles post.
    Sent from my HTC Evo 3D using Android Central Forums
    Thanked by 2:
    Ryuk6666 likes this.
  15. #2915
    cbucz24's Avatar
    Posts
    ROM
    CAI & Quattrimus ICS
    Its good to see he's alright. I haven't been back in months, figured I'd say hi.
    Sent from my PC36100 using Tapatalk 2
  16. #2916
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Quote Originally Posted by cbucz24 View Post
    Yeah he's alright, I was chatting with him on gtalk the other day
    Sent from my PG8600 using Android Central Forums
  17. #2917
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    any news on Jellybean?
  18. #2918
    Quote Originally Posted by Zakman View Post
    Your quite lucky to have ice cream sandwich.
    Sent from my C5170 using Tapatalk 2
    Thanked by:
  19. #2919
    brotherswing's Avatar
    Posts
    ROM
    BACKside, TMU Bugless
    Considering that the OV was never designed to handle even Gingerbread, I tend to agree.
    Repensum Est Canicula
    #_ Guru-to-Noob Translator C:/_ .
  20. #2920
    thewraith420's Avatar
    Posts
    ROM
    Changes Daily
    Actually on sprint the optimus s has official gingerbread and since the ov is identical hardware wise I'd say it was designed to run gb. Just vm decided to deny us it. I'd be interested to see Quatrimus jb.... We do have jb Bobzhome has been working on it Soo its not like we don't have jb at all.
  21. #2921
    The newest version of titanium backup is able to move and link program data to the sd card, freeing up memory. I was getting download failures when updating apps from the market. I moved some big data users to sd and problems went away. In titanium, go to backup/restore tab, long press on the app whose data you want to move, select move app data to sd card and wait a really long time while it does its thing. The first time it will ask if you want to create the necessary folder. Say yes.
    Thanked by:
  22. #2922
    thewraith420: I'm confused by your post. GB=Gingerbread. JB=Jellybean. The fact that there is an official GB for the Optimus S does not mean that JB will run on the S or the V. I'm pretty sure LG (Lucky Goldstar) hasn't released JB for any of these phones, but I confess that I have not been following the Optimus S forums very closely. If there was an official JB for the Optimus S, I think you're right that it would not be hard to port it to the OV. But I think all the JB's for the optimus line are very unofficial.
  23. #2923
    upconvert's Avatar
    Posts
    ROM
    Cold as Ice
    You misunderstood what thewraith was saying. There are two different comments, one about official roms and one about unofficial. Since there was an official gb rom for the S, one could say that the V hardware was designed to run gb, even though there was no official V gb. On the unofficial side, BobZ proved that the V can run jb, so quat jb should be possible, if tdm can find the time, and/or wants to.
    Thanked by:
    thewraith420 likes this.
  24. #2924
    cbucz24's Avatar
    Posts
    ROM
    Provided you have libs to support the OS, you can run anything on anything.
    Doesn't always mean it will run well...lol
    Thanked by:
    EnMod
    EnMod likes this.
  25. #2925
    Posts
    ROM
    True, I had Windows 2000 running on a Pentium 75 with 72 MB of ram. It ran like old people make love....slow and jerky.
