DEAL OF THE DAY: Save 43% on the Seidio SURFACE Case (with kickstand) for HTC One!
Page 119 of 119 FirstFirst ... 116117118119
Results 2,951 to 2,961 of 2961
Like Tree539Likes
  1. #2951
    bigsupersquid's Avatar
    o_O
    Posts
    ROM
    PAC ROM+Raspbian wheezy
    Default Re: [ROM][BETA] Quattrimus ICS
    Quote Originally Posted by thewraith420 View Post
    Yes, there's a key mapper apk on xda.
    Tapatalk'n it from my VM670 running OM-Mandylion IHO on LS670ZVJ firmware
    I hate to degrade the quattrimus thread with further off-topic conversation, but did want to pass on useful info.
    the best keymapper I've ever seen is
    but even it won't return the keycode for that button, since the button overrides the app while it's running.
    You'll have to find the button in your keymap by name, and disable it there.
    a little info on keylayouts is on xda
    and the 'real deal' full list of possible key events straight from Google is
    you're probably after "SEARCH" or maybe "APP_SWITCH" in the keymap file.
    Thanked by 2:
  2. #2952
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    What happened to all activities
    Sent from my LS670 using Tapatalk 2
  3. #2953
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Just curious but what's the good word on quattrimus ICS or quattrimus jb
    Sent from my LG-LS670 using Tapatalk 2
    notown likes this.
  4. #2954
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Quote Originally Posted by jonny5449 View Post
    Nothing has changed, questions like this are still frowned upon. Tdm is busy ATM with other devices.
    Sent from my PG86100 using Android Central Forums
    Guess whos coming back!
    Thanked by:
    cole2kb likes this.
  5. #2955
    i just installed quattrimus, it keeps freezing for some reason, any ideas? (was previously on backSIDE)
  6. #2956
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Quote Originally Posted by droidnoob89 View Post
    Some phones (i see more reports on zv9) just can't handle ICS. Try raising your min CPU clock to 480 and try lowering your max.
    Sent from my PG86100 using Tapatalk 2
  7. #2957
    optimus v, i cant even get that far, it asks me to tap the android and says it has stopped working, tap ok, and try again and stops again
  8. #2958
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Sounds like you installed gingerbread gapps if you have to tap an android. ICS gapps, should have a start button to push
    Thanked by:
  9. #2959
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    What thekraven said. Also if you didn't do a full wipe, you need to do that as well
  10. #2960
    inceyet's Avatar
    Posts
    ROM
    MIUIgb
    Hey haven't used this rom on a min due to the video lag like on YouTube ...was there a new release that fixed it or is there a work around it
  11. #2961
    kenharkey7's Avatar
    Posts
    ROM
    G-T-R Reloaded 7.8
    Quote Originally Posted by inceyet View Post
    Me thinks not, for lagless YouTube on ics, cold as ice is still the only way to go
    Add me around the web:
    Google Plus
    Facebook
    Twitter
