[ROM][BETA] Quattrimus ICS
Well, I guess it should be a bug report anyway. If you switch your lockscreen style to Honeycomb, the option to unlock it and any other shortcuts on there completely disappear. Just tried it and sure enough, it happened again and I had to unlock by going to settings in the notification bar.
Honeycomb works perfect for me. Honeycomb never had shortcuts though, did you set any?
No, I just saw that guy's post and remembered it happening to me too, so I went messing around with them again to see which one was doing it. The culprit was Honeycomb. Simply switching to that style makes my lock disappear. Someone in the S thread is having the same problem.
Odd. What happens if you reflash.
Flashed the 07-11 nightly. I no longer have those random reboots
Also, what boot animation were you talking about?
I think they were talking about aokp
Great rom but I've noticed a bug in manage apps: the bar at the bottom for free /used space is inverted. Used space is free space and free is used. Any way to fix that?
Not a bug. Its just as it is. Blue is the used spaced, grey is free.
How do you install the nightly downloads ....I'm new to all of this ..plus my phone keeps rebooting and freezing up
I'm running aokp will leaving my screen density on 340 hurt anything I kinda like it:cool:
I doubt it would hurt anything. What does the OV screen look like at 340? Can you post a screenshot? I set mine down to 140 and kind of like it.
It just feels cleaner smoother an if I at 340 its says its xhpdi so can I use themes for xhpdi phones?
No. Thats LDPI. XHDPI would be 120-130 maybe. I know 140 is perfect for HDPI.
Update: Rom locked up on me when downloading an app from the store.
Update2: My reception hit rock bottom. Going back to gingerbread :o
It actually works as xhdpi because that is an xhdpi density. I've used that density and it works but it is better to use the lower density.
Can you apply XHDPI themes at a density so huge?
Do NOT change your DPI to 250+(It could be 220+ or so)
You won't be able to get off the lockscreen.
Do you have it overclocked? Mine is pretty stable as long as I don't OC more than 729.
I don't even know how to over clock...lol...It seems to have smoothed out now...I was using IHO...this is a lot different....just need some good themes now.
Mine would constantly reboot also. As soon as its up and running go straight to performance settings and change minimum CPU frequency to 480 and leave Max at 600. Any other settings and I get constant reboots.This is for CM9 and AOKP.
ROM or Nova Launcher issue?....I cannot place widgets for any apps I download...they dont appear in the widget list...so aggravating.:banghead:
Edit:...figured it out.. :o. apps need to be on phone, not SD card for widget.
Sent from my Quattrimus ICS Optimus V
I've had mine set to 340 since I put aopk on my phone with beta 1, not had a single problem.
r3dpuk3
