Page 5 of 119 FirstFirst ... 2345678 ... LastLast
Results 101 to 125 of 2961
Like Tree539Likes
  1. #101
    Default
    Quote Originally Posted by blizard View Post
    Barnicle wifi tether isn't working I haven't found a hotspot app that worked since alpha anyone got one that works
    Works for me. Did u skip wpa supplicant
    Thanked by:
    fpoama
  2. #102
    Default Re: [ROM][BETA] Quattrimus ICS
    AOKP maps seems to be working MUCH better now.
    i did just encounter a reboot while using voice search to navigate to an address tho.
  3. #103
    Quote Originally Posted by reaper420 View Post
    sorry to go off topic but i found two really awesome boot animations for AOKP. If you dont really like the pink unicorn check these out. he was nice enough to resize for mdpi
    that second one looks pretty tight. if i wasn't fundamentally against boot animations i would be running it.
  4. #104
    Quote Originally Posted by dschlemmer318 View Post
    I skipped the wpa supplicant in the settings and my tethering now works. Thanks.
  5. #105
    blizard's Avatar
    Posts
    ROM
    IHO backside cm7.2
    Default
    That's does nothing if I skip wpa
  6. #106
    Love the rom, i was wondering though if there is an issue with hash's kernel for kindle fire because it can't see barnacle wifi.
    Thanked by:
    tdm
  7. #107
    reaper420's Avatar
    Posts
    ROM
    quattrimus aokp
    Default
    Does anyone know how to set a normal size wallpaper for the lockscreen
  8. #108
    Badboytoast's Avatar
    Posts
    Global Posts
    822 Global Posts
    ROM
    ICS 2.3.7/ tvall kernel
    Default
    Quote Originally Posted by skryboyd View Post
    Because hotspot "barnacle" for cm9 it only turns on but there's no connection!
    Sent from my VM670 using Tapatalk 2
  9. #109
    anthonycr's Avatar
    Themer. You've seen them
    Posts
    Default
    Kindle fire can't see ad hoc connections which are what all the wifi tether apps use. Google "how to tether kindle fire to ad hoc wifi"
  10. #110
    Default
    Tried aokp beta, still can't get apps to load from the market. They stay stuck in the pre download state. I don't have a sd partition. Is it a must to get the downloading working?
  11. #111
    Default
    Probably a dumb question but my SD ext has nothing in it even after installing apps. I partitioned the SD card for 500 mb right after flashing rom. Did I do that right or is there more I need to do
  12. #112
    Default
    Quote Originally Posted by jto101680 View Post
    Pretty much, yes.
    You'll be glad you did
  13. #113
    Default
    Quote Originally Posted by tdm View Post
    Put your apk's in /sd-ext/app and delete everything in /data/app
    Will try. Do I do this before I flash the ROM or after? Do I need to format sd-ext before flashing? Can I just cut and paste them all from the data folder to the app folder?
    Thanks for all your hard work.
  14. #114
    Default
    Quote Originally Posted by dbacon84 View Post
    After
    Yes
    Yes
    Thanked by:
  15. #115
    I accidentally enabled automatic brightness, and there's no way I can disable it now! Display settings brightness has no automatic brightness toggle, and the display brightness power widget won't turn automatic brightness off. What do I do?
    P.S. Can't find the disabling of camera shutter sounds in the sounds settings either...
    P.P.S. Instagram crashes everytime I try to take a photo.
    Edit: I'm using CM9 beta1.
  16. #116
    Default
    Ignore it. Doesn't do a thing :L
  17. #117
    Quote Originally Posted by ThatGuyLurkin View Post
    Well, now my status bar brightness controll refuses to enable itself... Also, last time I accidentally enabled it, my phone was doing the auto brightness thing, which I don't want.
  18. Thread Author  Thread Author    #118
    tdm
    tdm is offline
    tdm's Avatar
    Posts
    Global Posts
    1,411 Global Posts
    ROM
    Quattrimus
    Default
    Quote Originally Posted by BuggerZ View Post
    I should look into disabling that. I don't believe there is an ambient light sensor on the phone.
    Thanked by:
  19. #119
    CloudBusterr's Avatar
    Posts
    ROM
    Quattrimus AOKP / CM9
    Running AOKP all day, not a single reboot. You've done an amazing job, TDM!
    My questions never seem to cease
    Thanked by:
    tdm
  20. #120
    Do you recommend ext3 for the 2nd partition?
  21. #121
    dzdzjb's Avatar
    Posts
    ROM
    Quattrimus (for now)
    I just discovered that AOKP doesn't have Apollo (or any other music player) by default, and Apollo isn't available in Market. Any suggestions for a music player that works, well, about like the default Android music player (i.e., Apollo)? Or how to acquire Apollo?
    Last I checked, most of the fully-featured players (e.g., Winamp et al) are overloaded with extra junk I won't need (including but not limited to ads, annoying trial periods, or crippleware), and DeadBeef is as bad on Android as it is my laptop (nonstandard commands and impractical issues with playlists).
  22. Thread Author  Thread Author    #122
    tdm
    tdm is offline
    tdm's Avatar
    Posts
    Global Posts
    1,411 Global Posts
    ROM
    Quattrimus
    Default
    Quote Originally Posted by dzdzjb View Post
    I'll look into adding one tomorrow.
    Thanked by:
    dzdzjb
  23. #123
    kylemaguire's Avatar
    Resident Teen
    Posts
    ROM
    Quattrimus
    Default
    Hey tdm
    Do you think when posting to goo.im you could put Cm9 and aokp in separate folders? (Ex. /devs/tdm/
    Quattrimus/Ls670/CM9/build.zip)
    I'm just afraid that I'm going to rush and tap the wrong one.
    Thanks
    Sent from my LG-LS670 using Android Central Forums
  24. #124
    cole2kb's Avatar
    Retired Moderator
    Posts
    Global Posts
    4,017 Global Posts
    ROM
    Stock
    If anyone wants a resized boot animation for AOKP, here you go. I didn't do any work to make it look "pretty" (you can definitely tell it's been scaled down), but it's proportionate and I personally find it much nicer to look at then before.
    Thanked by 5:
  25. #125
    Octahedron's Avatar
    Posts
    ROM
    MIUIv4
    can anyone give me a step by step on how to setup sd-ext with this rom? i tried creating an sd-ext from cannibal recovery, but how do i know if it worked?
