- 07-29-2012, 09:17 PM #1526
OK please forgive me, I'm outta town and can't get to a PC an use the real search function. And tapatalk search never find anything.
What wifi tether is working with AOKP? I know I've seen people talking about a few, but before now I've never needed one. I know I'm not expecting streaming speeds, its virgin mobile after all.
Edited: I installed barnacle, it connected fine. Just slow as hell. Wish I could bump my 3g speeds :screwy:
Sent from my LG-VM670 using Tapatalk 2Last edited by cbucz24; 07-29-2012 at 09:57 PM.
- 07-29-2012, 10:54 PM
Thread Author #1527
Back to civilization. Was camping with the kids. Gonna check out the nightly builds and take a look at bluetooth reboots in the morning.
Also looks like hephappy decided to stop developing again. We'll see how long that lasts this time, lol.Thanked by 9: - 07-29-2012, 11:21 PM #1528
- 07-30-2012, 12:49 AM #1529
- 07-30-2012, 12:57 AM #1530
Im having problems with the playstore i tryed to download an app but when it starts to install it says insunufical storge
Sent from my LG-VM670 using Android Central Forums - 07-30-2012, 01:12 AM #1531
Srry for double posting lol thos gose to my previous post
- 07-30-2012, 01:29 AM #1532
- 07-30-2012, 01:50 AM #1533Thanked by:
- 07-30-2012, 02:28 AM #1534
- 07-30-2012, 02:52 AM #1535
- 07-30-2012, 02:55 AM #1536
- 07-30-2012, 05:28 AM #1537
- 07-30-2012, 06:17 AM #1538
- 07-30-2012, 08:12 AM #1539
- 07-30-2012, 09:50 AM #1540
- 07-30-2012, 10:08 AM #1541
Re: [ROM][BETA] Quattrimus ICS
Without a pc, I don't know how you will backup your card before formatting it. You will lose all data on your card when you partition it!!!
If you set the partition up with CWM, wipe cache/dalvik and reboot. You should see that your internal memory is now near empty. Your storage submenu will not show your ext3 partition. SD Maid(free in play store) will show you exactly where everything is at. - 07-30-2012, 10:45 AM #1542
It can be after. Flash the rom and gapps, then just partition the card before you reboot. Or you can reboot the phone to make sure the flash took, then reboot into recovery, format the card and partition it. If you don't format first, be sure to wipe the dalvik before you reboot.
EDIT: Actually if you need reference, I just did a big write up on this a few weeks ago. It's the top link in my signature
Sent from my LG-VM670 using Android Central ForumsLast edited by strabo231; 07-30-2012 at 10:55 AM.
- 07-30-2012, 10:45 AM #1543
he said he just bought the sdcard, so he shouldn't really have anything to backup on it.
Olan Rogers, ladies and gentlemen. Funniest video ever!!! - 07-30-2012, 10:46 AM
Thread Author #1544
- 07-30-2012, 10:51 AM
Thread Author #1545
Okay .. here's the scoop.
The nightly builds are not so nightly anymore because there are frequently no changes to the source in any given day. For example, on cm9, the build was skipped on 7/28 and 7/30, while aokp skipped 7/28, 7/29, and 7/30. I will try to get some indicator pushed to say "no changes" in this case because it's confusing not knowing if the build failed or not.
Played around with bluetooth this morning. Found a way to prevent it from crashing. I will be testing throughout the day and it should be fixed for tomorrow's nightly. That might just push us to beta2.Thanked by 13:+ Show/Hide list of the thanked
- 07-30-2012, 11:01 AM #1546
- 07-30-2012, 11:05 AM #1547
- 07-30-2012, 11:06 AM #1548
Don't you have an sd-ext? Just go into recovery and wipe your cache. Once your internal storage shows less than about 100mb, it always causes problems with play store downloads. Also make sure all your apps are on your ext and not your phone. The other option is to clear app data.
- 07-30-2012, 11:07 AM #1549
- 07-30-2012, 11:10 AM #1550
Reply
hope u had a blast
