Page 75 of 119 FirstFirst ... 72737475767778 ... LastLast
Results 1,851 to 1,875 of 2961
Like Tree539Likes
  1. #1851
    nitestalkr's Avatar
    Posts
    ROM
    Tapatalk Signature~
    Default
    Quote Originally Posted by ganggreen30 View Post
    Your on jellybean? Which rom the alpha one
    Sent from my LG-VM670 using Xparent Pink Tapatalk 2
    Follow the link Kobe provided, and look at my second post on how to get Drew's CM10 port working on the V
    sent from my Zom-"Bean"(AOSP JellyBean).
  2. #1852
    Default
    I just read it.... Why do you need to partition?
  3. #1853
    nitestalkr's Avatar
    Posts
    ROM
    Tapatalk Signature~
    Default
    Quote Originally Posted by ThatGuyLurkin View Post
    Same reason as you would with ICS, more app space due to Jelly Bean taking up nearly all internal space.
    sent from my un-dead sammich.
  4. #1854
    nitestalkr's Avatar
    Posts
    ROM
    Tapatalk Signature~
    Default
    Quote Originally Posted by grosskum View Post
    How do you enable different media volumes for headsets in AOKP. In CM9, if I plugged in my headset my media volume would go from 0 to like 50%. I've looked in sound settings and can't find that option. Does it have to do with the dsp manager app that is included in CM9? Because I can't that dsp manager in the store.
    Its settings, rom control, general UI, enable volume options.
    Now when you change volume level, you can change each level individually. That way, you can have media level up, notification level on vibration, and call level on vibration. That way, when you plug in your headphones for music, you won't have to worry about adjusting the volume, each and every time.
  5. #1855
    Default Re: [ROM][BETA] Quattrimus ICS
    In AOKP beta 2 when I hold power it reboots rather than power menu. I've rebooted, looked in settings, but can't find anything. It worked right when I downloaded beta2 but now it just reboots. Any workarounds or help?
    i have this problem also. the power menu shows up when i first install the rom...but after i run my titanium backups and restore system data it starts doing the soft reset every time i hold the power button.
    gotta be something with one of these apps i/we have installed...i probably run about 35 user apps total.
  6. #1856
    i think i may have found why the play store doesn't recognize our devices. (when you go to reviews on an app, then choose the one that says "this device only" or something like that and nothing pops up) So i was looking at the device list on play.google.com and the maker is unknown. i think if you fixed that it would recognize it. just my guess though..
    Thanked by:
    tdm
  7. #1857
    Default
    Quote Originally Posted by nitestalkr View Post
    You should put recommended. Not needed.
  8. #1858
    nitestalkr's Avatar
    Posts
    ROM
    Tapatalk Signature~
    Default
    Garsh darn tapatalk posted my replies here instead in this thread, this forum, and this website even....
  9. #1859
    nitestalkr's Avatar
    Posts
    ROM
    Tapatalk Signature~
    Default
    Quote Originally Posted by droiddekka View Post
    DO NOT RESTORE SYSTEM APPS/DATA!
    That is your problem, you're only supposed to restore user apps.
    When you restore System apps, it overwrites the ROM, and causes issues.
    Thanked by:
  10. #1860
    nitestalkr's Avatar
    Posts
    ROM
    Tapatalk Signature~
    Default
    I stated that its only needed when flashing the patch with the sd-ext scripts, I edited and made that more clear(I hope lol) in that post.
  11. #1861
    I've got a stuck new voice mail notification, anyone else get anything like this recently, I've rebooted a few time, the notification persists after I've deleted it. thus far virgin mobile tech support has not been any help.....
  12. #1862
    bigsupersquid's Avatar
    o_O
    Posts
    ROM
    PAC ROM+Raspbian wheezy
    Quote Originally Posted by Wheellzz View Post
    Leave a new voice mail, call from your phone, delete it, and wait for the notification to go away before hanging up. Works in cm7.
    Thanked by 2:
  13. #1863
    Quote Originally Posted by bigsupersquid View Post
    I'll give it a shot, however i'm no longer running CM7...
    Hey it worked....very odd.....
    Thanked by:
  14. #1864
    brotherswing's Avatar
    Posts
    ROM
    BACKside, TMU Bugless
    Default
    Sometimes my phone goes right to the home screen without showing the lock screen. CM9 beta 2. Not a big deal for me, just letting you know.
    sent from the hip.
    #_ Guru-to-Noob Translator C:/_ .
  15. #1865
    Any of the Nightly have a fix for the aokp video slideshow? just curious
    p.s Great job tdm[=
  16. #1866
    Default
    Not yet.
  17. #1867
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    Yeah, he meant to try it because it works on cm7. Lol.
    Guess whos coming back!
    bigsupersquid likes this.
  18. #1868
    o_O
    Posts
    ROM
    I guessed that process because I have a couple backups with the voicemail notification set. It's the only trick I found to get rid of it. Glad it still works.
    I think the deal is that android wants the service provider to send notification the voicemail isn't new, and vm only sends that once. Whatever makes it stick, it goes away as soon as the system pings the phone to remove the notification.
  19. #1869
    henrikb's Avatar
    Posts
    ROM
    Android 2.2.1
    Default No-charging issues [(hopefully) SOLVED]
    Regarding the battery no-charging problem (Post #7384):
    I'm happy to report that my phone charges after I flashed quattrimus-VM670-cm9-nightly-20120731.zip [74.41Mb; VM670ZV4; 2.6.35.7-tdm-gk-hkicsam-0.1+tommy@ics #1; cm_VM670_userdebug 4.0.4 IMM76L eng. tommy.20120731.021607 test-keys] last week. Previously, at rare occasions, I managed to get it to charge a few times, but with this flash/ROM it now charges all the times. I didn't do anything particular when flashing this time, so I assume something changed with the build.
    Thxs
  20. #1870
    How do i remove the quattrimus splash screen? Its kind of ugly
    Oh and how cab i move themes from the sd ext to the phone?
  21. #1871
    Ryuk6666's Avatar
    Posts
    ROM
    AOKP
    Default
    Quote Originally Posted by JussCallMeUno View Post
    Ouch man. That was kind of rude. Tdm made that. Speaking of which, tdm, out of like the 3 boot logos submitted, have you chosen one of them yet? Or are you still going to hold a poll for which one?
    Sent from my A.C.R. Zombified Quattrimized AOKP OV.
  22. #1872
    unpack the boot.img and replace the required .rle files with ones of the same size. I do that with every update.
  23. #1873
    I think I might of thought of a way to fix video on our phones.
    I was doing research on our phones SOAC(System on a chip) and it seems that the GPU does all video encoding/decoding. The reason why it doesn't work is because of the OMX drivers and the big Q refusing to released the source/updated drivers.
    So why don't we just patch the system with the ARMv6 VFP Codec from the market? It got video working in the first place on bobzhomes, so why not integrate it into the system?
    Thanked by 4:
  24. #1874
    nitestalkr's Avatar
    Posts
    ROM
    Tapatalk Signature~
    Default
    Quote Originally Posted by HurrrDurrrDURP View Post
    I was kinda thinking the same thing, cause MX player with ARMv6 VFP Codec plays perfectly fine, so if its possible to take the code from the ARMv6 VFP Codec, and implement it into the system, and have the GPU use it as its source video decryption, couldn't that fix the video issues indefinitely?
    sent from my Zom-"Bean"(AOSP Jellybean)
    RidDleZ likes this.
  25. #1875
    nitestalkr's Avatar
    Posts
    ROM
    Tapatalk Signature~
    Default
    Quote Originally Posted by clodfelterac View Post
    @tdm--- heres my entry for the bootsplash contest... i left it png... :-)
    Might want to either change the color of the text, or the background, to make it a lil easier to read
    Thanked by:
