- 07-05-2012, 11:23 PM #176
- 07-05-2012, 11:27 PM #177
- 07-05-2012, 11:30 PM #178
I have been having that problem since cm9 pre beta 3 u r the only person I have seen post anything about the issue. I posted on the alpha thread and it went unanswered. I'm now taking screen shots of the log after the freeze and I believe it said error 624 but I'm not sure on the error number. Next time it happens take a screen shot and post it. Ima post the few screenshots I have after the next YouTube freeze
Sent from my LG-VM670 using Android Central Forums - 07-05-2012, 11:33 PM #179
- 07-06-2012, 12:16 AM #180
- 07-06-2012, 01:37 AM
Thread Author #181
Thanked by 5: - 07-06-2012, 01:57 AM #182
- 07-06-2012, 02:15 AM #183
has any one tryed the AOKP nightly 7/05?
Sent from my LG-VM670 using Tapatalk 2 - 07-06-2012, 03:15 AM #184Thanked by:
- 07-06-2012, 03:20 AM #185
Re: [ROM][BETA] Quattrimus ICS
As others have said, and what worked for me was to:
1) backup apps with titanium backup
2) backup the data from your sd card to your computer
4) repartition sd card in recovery (will erase all data on sd card, so make sure to back up)
5) move files back to sd card from computer
6) restore apps using titanium backup
It's a pain and a half, but this was the only method that was able to fix this issue reliably for me.Thanked by: - 07-06-2012, 04:02 AM #186
- 07-06-2012, 05:30 AM #187
Installed beta a few hours ago and I love it
thank you tdm your work is amazing.
There is one thing that I think would be a useful feature for this ROM, I noticed that the Galaxy S3 has a "kill all" feature when you bring up the running apps. Is there any way you can implement that feature into this ROM? Or would it be more trouble than its worth? Thanks in advance
- 07-06-2012, 06:57 AM #188
People keep complaining about Youtube. Yes, Youtube in the browser doesn't work.
But the Youtube APP does work!
Watching Olan Rogers' Ghost in the Stalls right now and it's PERFECT. So use that instead!Olan Rogers, ladies and gentlemen. Funniest video ever!!! - 07-06-2012, 07:38 AM #189
- 07-06-2012, 07:41 AM #190
- 07-06-2012, 07:53 AM #191
- 07-06-2012, 07:59 AM
Thread Author #192
- 07-06-2012, 08:36 AM
Thread Author #193
Thanked by 7: - 07-06-2012, 09:25 AM #194
@tdm--- aokp--0705- i partitioned sd to 512/64 for this one with cannibal... rom picked up and installed nicely... i stuck the default_oc script back in init.d... have only had three rr's total... two while adjusting settings, one while browsing with operamini... <-- last night*...
rom seems to have settled in nicely... : -) - 07-06-2012, 09:39 AM #195
Ahhhh. It's aokp's fault. haha I'm on cm9. something about unicorn porn bothers me.
Olan Rogers, ladies and gentlemen. Funniest video ever!!! - 07-06-2012, 10:18 AM #196
been using quattrimus for over a month as my daily. had to post about the battery life, it's unbelievable i can easily get three moderate usage days out of it on the new aokp with out any crashes..much better than the 10 hours on stock! thanks for the great work tdm i never expected this from my phone.
Sent from my LG-VM670 using Android Central Forums - 07-06-2012, 10:55 AM #197
- 07-06-2012, 10:57 AM #198
- 07-06-2012, 11:02 AM #199
- 07-06-2012, 11:10 AM #200
Reply
