[ROM][BETA] Quattrimus ICS
ThatGuyLurkin
2,155
665
Just wanted to say beta1 is working great for me. No reboots and it feels snappier then iho
Edit: also anyone having reboot issues try backing up your sdcard to pc and repartition (I added swap too) and reformat your sdcard then do a fresh install. I haven't had an issue since
Rather than to do that, take the SD out and run the rom.
inceyet
393
121
Don't wanna get off subject but I partioned my SD card 512 ext 64 swap size on my 16g card is this good or should I change it I've been have reboots and freezes not a lot but some. Again sorry for off subject just curious. Thanks for the help :cool:
cbucz24
195
38
The wifi will just disconnects and says out of range even while sitting a couple of feet away from the router and the actual range seems to be less than when I use a gb ROM. On ics I can't get off my front porch, on any gingerbread ROM I can go down the street a ways without losing wifi
That's odd. I cut my grass yesterday while streaming Pandora. No disconnect at all, didn't have n issue I'll I was at the neighbors house.
On a different note;
I did reproduce my reboot. Made call while on bt. Turned headset off n finished the call. Soon as I hung up it rebooted?
reaper420
215
21
The wifi must be one of those things you can chalk up to not all phones being the same, still its a small price to pay for using such an awesome ROM
morimar
6
I'm so glad to see AOKP in beta!
Quick question - I haven't seen anything so far regarding the linaro patches, have they been applied to either the CM9 or the AOKP builds? If not, are there any plans to do so?
tdm
1,409
3,596
No, linaro causes too many subtle stability issues. We have enough of those, don't need any more. ;)
If and when the base projects (cm9 and aokp) start using linaro, then I will reconsider.
jetfactor
46
7
AOKP dope, great battery life, no problems with anything so far. different customizations from CM9. just as snappy. almost crapped myself at the unicorn boot.
:D
(sent from space)
Reactions: tdm
ilikechicken123
420
113
Can anyone else confirm YouTube working on cm9 please? That's the only thing that keeps me from using it daily (besides the horrible stock ICS contacts)
blizard
140
3
Barnicle wifi tether isn't working I haven't found a hotspot app that worked since alpha anyone got one that works
rebel69ization
501
106
Last Time on "As Quattrimus Turns":
Mr."Alpha" and Ms."Nightly" had an intense one-night-stand that lasted until the morning. A few days later, Ms."Nightly" realized that she missed her period.
After she took a pregnancy test and it turned out to be positive, she began to panic knowing that Mr. "Alpha" would never accept "Beta" as his child. What will she do? Will she break the news to Mr. "Alpha"? Or will she leave him behind, raising "Beta" alone?
Only time will tell "As Quattrimus Turns".
Lmao
inceyet
393
121
Don't know if anyone saw this but just wanted to get clarification on this
AOKP, G-T-R, MiRaGe, Godzilla, JOYOS, Harmonia killing the game!!!!
