02-07-2017 04:18 PM
192 ... 34567 ...
tools
  1. LeoLawliet's Avatar
    Does this need to be flashed after a new rom install? It works great for me on Quattrimus. My Antutu Benchmark was 1864. I am going to flash over to Vanilla Bean to try it out and definitely want to keep this tweak running!!
    Thanks for the great work.
    Flashing a new rom will disable the tweak, reflash it after installing a new rom.
    Sent from my LG-E739 using Tapatalk 2
    07-18-2012 09:19 AM
  2. RidDleZ's Avatar
    Works for me. VS660. I play a lot of emulators, snes, gens, gba, ect. I've had a hard time finding emulators that will play at full speed on this device. But I used the flashable zip and it seems I can now play at full speed. An emulator for example was DroidEmu.
    Thank you LeoLawliet for digging this up!
    07-18-2012 02:46 PM
  3. LeoLawliet's Avatar
    You're welcome, I just tried out PCE and it looks excellent
    07-18-2012 04:00 PM
  4. drezliok's Avatar
    Does this help with video playback on ICS?
    07-22-2012 08:14 AM
  5. LeoLawliet's Avatar
    Nope, that's a whole different issue.
    07-22-2012 12:36 PM
  6. RavinX's Avatar
    When trying to flash on Quattrimus AOKP nightly build 7/20, I get a error message that says:
    E: Missing file:
    system/build.prop
    E: Verification failed.
    I assume I'm just missing something obvious?
    07-22-2012 06:53 PM
  7. jonny5449's Avatar
    E: Missing file:
    system/build.prop
    Disable signature verification
    Looking for good cm9 or cm7 themes??? visit this site for good themes. http://forum.digitalhouseoftreats.com/
    07-22-2012 07:06 PM
  8. LeoLawliet's Avatar
    If this helps, I suggest mounting system before flashing. That way you make sure it does flash correctly.
    07-23-2012 08:56 AM
  9. niftypixel's Avatar
    I've had this flashed for quite a few days. It has definitely sped up orientation shifting delay. I've noticed nothing else thus far (have no games). Thank you very very much!
    07-23-2012 01:06 PM
  10. PMUSER's Avatar
    Any chance this would work on my Optimus S. Currently they are saying we have to use Froyo as the fix for Netflix. I tried flashing this zip and it said not signed. So I am wondering about just modifying it the manual way, but wanted some input before I start out
    07-25-2012 10:11 AM
  11. niftypixel's Avatar
    Don't believe this works on any froyo based Roms regardless
    07-25-2012 11:00 AM
  12. PMUSER's Avatar
    I am on a GB rom, but I am just wondering if this could possibly brick my phone
    07-25-2012 12:07 PM
  13. LeoLawliet's Avatar
    I'm using this on an LG myTouch 4G, and my Optimus V, and my Optimus Slider all at once. Didn't brick any of them.
    07-25-2012 01:23 PM
  14. LeoLawliet's Avatar
    I just tried a few build.prop edits that effect dalvik, huge speed boost on my LG-E739. I tried it on my OV running the latest Ginger Snap, it's noticeable.
    I found it here: http://forum.xda-developers.com/show....php?t=1726988
    "-Manual Mode --
    Open build.prop and add the following
    change dalvik.vm.dexopt-flags=m=y TO
    dalvik.vm.dexopt-flags=m=y,v=n,o=v,u=n
    right below add
    dalvik.vm.execution-mode=int:jit
    then change windowsmgr.max_events_per_sec = 300
    comment out with #
    dalvik.vm.heapgrowthlimit
    then save"
    notown, bigsupersquid and irish-68 like this.
    07-27-2012 07:17 PM
  15. monochromatik's Avatar
    I found it here: [MOD] LAG FREE g2X + dalvik fix - xda-developers
    "-Manual Mode --
    right below add
    comment out with #
    then save"
    just curious, i just flashed the latest bobz, and the build.prop already has dalvik.vm.execution-mode=int:jit. also, there's already a dalvik.vm.heapgrowthlimit set to 48m. should i just comment that out, or just add #dalvik.vm.heapgrowthlimit as the instructions state?
    07-27-2012 09:01 PM
  16. clodfelterac's Avatar
    -just add the #
    07-27-2012 09:15 PM
  17. LeoLawliet's Avatar
    I'm not sure, I just did what it said and it worked. I'm trying it out on ICS now, I will report back and let you know if it made a difference.
    07-27-2012 09:23 PM
  18. LeoLawliet's Avatar
    Confirmed working noticeably on ics too
    notown likes this.
    07-28-2012 12:25 AM
  19. flipmack's Avatar
    I'm going to have to try this...running GTR (CM7.2).
    08-13-2012 11:35 AM
  20. LeoLawliet's Avatar
    Already tried, that was the first rom I tested it on. It'll work
    08-13-2012 11:43 AM
  21. b34tls4ever's Avatar
    i tried this on Quatrimus and it got stuck at the boot sceen
    08-13-2012 03:38 PM
  22. LeoLawliet's Avatar
    Did you mount system before flashing?
    08-13-2012 07:29 PM
  23. beastieboii's Avatar
    Is there a flash zip for the new build prop tweaks I suck at doing stuff manually
    08-14-2012 05:54 PM
  24. MidtownHD's Avatar
    is dalvik.vm.heapsize (in Jerry's cm7) the same as dalvik.vm.heapgrowthlimit?
    08-16-2012 10:43 PM
  25. ThatGuyLurkin's Avatar
    I have attached here a flashable zip file that will do the trick for you. Like bigsupersquid, I am not sure if there is any difference and Antutu is giving exactly the same 2D/3D GPU scores. Anyway, it is good to have one less library in the ROM as long as we can do without it.
    08-17-2012 02:39 AM
192 ... 34567 ...
