02-07-2017 04:18 PM
192 ... 5678
tools
  1. ducatiman1098's Avatar
    I'm trying on HD2, but I dont see differences
    09-15-2012 11:19 AM
  2. LeoLawliet's Avatar
    Hi there
    .. just follow a thread @ xda,they linked to this thread, so this tweak should generally work with adreno 200 gpu?
    I own a E10i which runs under CM10 Android 4.1.1.. is this compatible or has the ROM to be an ICS one?
    Is this with the X10 mini possible too, or only reserved for LG devices..??
    Thank you, if necessary, please move the questions into right corner. thx
    E: Ok thank you, what about the entries/changes as described above, do I have to open named file via Root explorer by using the terminal? hm
    One point.. cyanogen10 implies a setting called "force GPU rendering in 2D".. doesnt archieve this exactly the same result, which can be reached through the tweak??
    Thanks in advance for enlightenment
    You know I have put a lot of thought into that, I honestly think this isn't necessary on ICS. You can always force GPU rendering from development settings anyway. As for those build.prop tweaks, I should update that post. Someone else corrected an error in it. You'll want to try "m=y,o=v,u=y", that's what A.I advised me.
    P.S. this should work on any adreno200 device. If you have something different, just change it according to the name onto the egl.cfg file. Like Tegra for example.
    Sent from my LG-E739 using Tapatalk 2
    09-15-2012 12:41 PM
  3. garynagra's Avatar
    i tried to flash this on my verizon gs3 through cmw and i get "Install aborted" im running cm10 latest build.
    Thakns in advance
    09-16-2012 08:59 PM
  4. LeoLawliet's Avatar
    Thakns in advance
    Redownload it, maybe it was a bad flash. Mount system before installing. And don't forget to disable signature verification
    09-16-2012 09:36 PM
  5. EarthnFire78's Avatar
    Just a note this is already build into OM-Mandylion by default.
    09-16-2012 09:41 PM
  6. jonny5449's Avatar
    Cool
    Trying to find ways to make jb as smooth as butter
    Starting here also love this tweak a bunch
    Well looks like Im flashing loopy smoothness tweak also
    LeoLawliet likes this.
    09-16-2012 10:16 PM
  7. LeoLawliet's Avatar
    Cool and do the users love it or what
    09-16-2012 11:26 PM
  8. EarthnFire78's Avatar
    Yes, and with the teaks made to the Kernel game playing is a lot soother.
    09-17-2012 12:34 AM
  9. Nemesis-X's Avatar
    My GS3 does not have a system folder, i've looked with ASTRO file manager and windows 7 explorer. It's just not there. I tried flashing mrg666's file but that failed. My phone is rooted. Any advice?
    09-17-2012 12:22 PM
  10. flapjack.fiasco's Avatar
    Sounds like you're looking on the sd-card, you need to start at the root directory. Try going up one level in the folder structure.
    This space intentionally left blank.
    09-17-2012 12:53 PM
  11. daddy4life09's Avatar
    does this work on bobs cm10?
    09-17-2012 02:25 PM
  12. A-android-B's Avatar
    Cm10 has force GPU rendering built in. Its in settings, developer
    09-17-2012 02:49 PM
  13. Nemesis-X's Avatar
    I wish that was the case but I looked on both the internal and external storage and no system folder...I checked if system folders were hidden in explorer but it's checked to show.
    09-17-2012 03:21 PM
  14. cole2kb's Avatar
    Might be better to post in the SGS3 forums and reference back to this thread.
    09-17-2012 06:08 PM
  15. Encerspay45's Avatar
    So I just flash the VM670 patch zip in recovery, right?
    10-11-2012 11:07 AM
  16. LeoLawliet's Avatar
    First mount system, then flash
    10-12-2012 11:59 PM
  17. Mauricio Medina's Avatar
    I do it to my Samsung galaxy I5500 with CyanogenMod 7.2 - So far no issues -i think-, a little bit more smooth. So, thanks guys
    01-22-2013 08:08 PM
  18. kenharkey7's Avatar
    I was just about to search for this, thanks to the person who last posted, I don't have to lol
    01-22-2013 11:02 PM
  19. EarthnFire78's Avatar
    If you're still on OM-Mandylion this is already implemented.
    01-22-2013 11:13 PM
  20. kenharkey7's Avatar
    I know, I'm actually making nandroids of various roms. I'm on harmonia now.
    01-22-2013 11:31 PM
  21. AndyOpie150's Avatar
    One thing to remember about nandroids.
    If you use a ROM with ext support or LINK2SD, then that nandroids apps will only show if the ext format on the SD card is the same.
    Something to think about if contemplating changing the format of the partition.
    01-23-2013 04:49 PM
  22. Akash Rastogi's Avatar
    hi. i am using xperia tipo dis will work on my phone???
    it has adreno 200 ....
    i hav understand that first we hav to extract efg file into system/lib/egl and then delete libGLES_android.so file but whats is the permission... u r talking about..what is permission.it is compolsry .?? plzz help
    can u tell me step by step what i hav to do ....
    05-07-2013 10:10 AM
  23. Akash Rastogi's Avatar
    if i dont follow permission step will my phone get brick ....or wat will happen plzz help...LEOlawliet
    05-07-2013 10:14 AM
  24. Akash Rastogi's Avatar
    what is the defference if we do (force gpu rendering) in developer option ..and all this things.???
    05-07-2013 10:18 AM
  25. notown's Avatar
    dude. just flash the zip (VM670_eglpatch.zip) through recovery. its easy. its safe this way.
    05-07-2013 01:29 PM
192 ... 5678
