Page 1 of 8 1234 ... LastLast
Results 1 to 25 of 179
Like Tree19Likes
    LeoLawliet's Avatar
    Posts
    ROM
    CM7.2/MiRaGe kernel
    Default [GUIDE] Disable CPU rendering
    I found this tweak while trying to look for a loopy smothness tweak made for ICS, but I ended up finding something better than loopy smoothness, a guide to disable CPU rendering. With this tweak you can take full advantage of your device's GPU. In other words you disable software rendering and enable hardware rendering instead (correct me if I'm wrong).
    Original thread where I found the tweak:
    If you end up adding this tweak into a custom rom you are sharing, please don't forget to give credit for it. You can thank me and mrg666 for it
    Confirmed working on:
    - BobZhome CM9 [VM670]
    - quattrimus CM9 [VM670]
    - mrg666 MiRaGe IHO [VM670]
    - BobZhome IHO [VM670]
    - any device with working adreno200 drivers (in this case my LG myTouch 4G is a good example, it worked marvelously and more noticeably on this device)
    It should work on any rom.
    What might you benefit from? So far this is what I noticed.
    - performance boost
    - speed boost
    - increased responsiveness
    - better audio quality
    - apps such as Facebook that would become slow and unresponsive are suddenly blazing fast
    I forgot to mention this before, I recommend you use Root Explorer or another file browser that has root support to install the tweak. Also set the permission to rw-r--r-- for the egl.cfg file.
    Code:
    It removes the entire soft-rendering pathway, hence good performance.
    Download the attachment and put it under system/lib/egl and delete libGLES_android.so from egl folder.
    That's all.
    P.S. It's flashable via CWM recovery now with the eglpatch, it just got easier. But if you would like to do it manually for whatever reason, this guide will still remain here.
    I didn't develop this tweak, I came across it and tested it with my LG Optimus V and my LG myTouch 4G both on GB and ICS roms for both devices and it works and I'm not entirely sure about this but it should work on some other devices. I'm not responsible for anything that goes wrong with your device, you know the risks of flashing files to root. Make a backup first.
    Enjoy
    Update! mrg666 compiled a flashable zip, the link to his post is right here
    Another update! It's been confirmed that this tweak doesn't seem to work on Froyo based roms, it causes an endless bootloop. Although it's been confirmed to work on Harmonica. So from what I know it will work best on GB and above.
    Edit: try out this build.prop tweak, it speeds things up a bit more.
    Open build.prop and add the following
    change dalvik.vm.dexopt-flags=m=y TO
    dalvik.vm.dexopt-flags=m=y,o=v,u=y
    right below add
    dalvik.vm.execution-mode=int:jit
    then change windowsmgr.max_events_per_sec = 300
    comment out with #
    then save
    Attached Files Attached Files
    Thanked by 29:
    + Show/Hide list of the thanked
  2. #2
    Default Re: [GUIDE] Disable CPU rendering
    So how exactly do use this on my V?
    LeoLawliet's Avatar
    Posts
    ROM
    CM7.2/MiRaGe kernel
    Root Explorer or a file browser that has root support.
  4. #4
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    Didn't work for me. Soft bricked my phone. On bobzhome cm7 5-20
    LeoLawliet's Avatar
    Posts
    ROM
    CM7.2/MiRaGe kernel
    Quote Originally Posted by sellers86 View Post
    Did you set the right permissions for the egl.cfg? Do that and restart.
    It should be rw-r--r--
    Sorry about that, I should've mentioned it on the first post, the original post didn't mention anything about that.
  6. #6
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    Quote Originally Posted by LeoLawliet View Post
    I didn't even think of that lol. I'll try again
  7. #7
    Default
    Soft brick meaning bootloop? I get confused with meanings. :P
  8. Thread Author  Thread Author    #8
    LeoLawliet's Avatar
    Posts
    ROM
    CM7.2/MiRaGe kernel
    I hope it works for you this time, if anything I can confirm that it works on mirage.
    Quote Originally Posted by ThatGuyLurkin View Post
    I think that's what he meant lol
  9. #9
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    Just booted up. It runs great. No keyboard lag, better performance. Thanks.
  10. Thread Author  Thread Author    #10
    LeoLawliet's Avatar
    Posts
    ROM
    CM7.2/MiRaGe kernel
    Awesome! You're welcome
  11. #11
    Another confirmation of this working using Bobzhome cm9 rom. I do feel everything is a bit more responsive. Any idea it fixes some of the other issues like white screen on gmail and related apps? thanks
    edit: I use twitter primarily on browser. Previously between touch and trying to scroll there was a lag, and now its smooth and fast.
  12. Thread Author  Thread Author    #12
    LeoLawliet's Avatar
    Posts
    ROM
    CM7.2/MiRaGe kernel
    Quote Originally Posted by zoidberg_md View Post
    I'm pretty sure you still have to move those apps over to system instead of data to get it working without the white screen issue. And thanks for confirming that it works, I may make a list of roms it's confirmed to be working on, tho that may not be necessary.
  13. #13
    r00t's Avatar
    Posts
    ROM
    CM7.2-IHO-MiRaGe
    So all it is is extracting the egl.cfg to /system/lib/egl then delete /system/lib/egl/libGLES_android.so and reboot?
  14. Thread Author  Thread Author    #14
    LeoLawliet's Avatar
    Posts
    ROM
    CM7.2/MiRaGe kernel
    Quote Originally Posted by r00t View Post
    Don't forget to change the permission for the egl.cfg file before rebooting. It's that simple!
    Thanked by:
    r00t
  15. #15
    bigsupersquid's Avatar
    o_O
    Posts
    ROM
    PAC ROM+Raspbian wheezy
    instead of removing the original .cfg and .so, i renamed em with an added .old extension in case i had to put em back
    i haven't noticed any differences yet myself, but it's only been a half hour or so of testing.
    java007 and glarepate like this.
  16. #16
    r00t's Avatar
    Posts
    ROM
    CM7.2-IHO-MiRaGe
    Yup, I do feel the difference in performance. Much more faster!
    I wish I could've done a before and after benchmark though.
  17. Thread Author  Thread Author    #17
    LeoLawliet's Avatar
    Posts
    ROM
    CM7.2/MiRaGe kernel
    Default
    Quote Originally Posted by bigsupersquid View Post
    Smart man, if I knew how to make scripts I may have actually considered compiling an install script for this that would install the tweak, set the right permissions, and backup the old one, like you just mentioned. Kinda also like V6 Supercharger backs up the old build.prop
    Sent from my LG-E739 using Tapatalk 2
  18. #18
    atrain2324's Avatar
    Posts
    ROM
    BobZ CM10
    how is the battery life using this tweak?
  19. #19
    Default
    Thanks! Noticeable difference in scrolling for sure
  20. #20
    mrg666's Avatar
    Posts
    ROM
    CM7.2-IHO-MiRaGe
    I have attached here a flashable zip file that will do the trick for you. Like bigsupersquid, I am not sure if there is any difference and Antutu is giving exactly the same 2D/3D GPU scores. Anyway, it is good to have one less library in the ROM as long as we can do without it.
    Thanked by 26:
  21. #21
    So any idea what I should do if I forget to set the permissions and end up with a black screen and unable to boot?
  22. #22
    pandulce1's Avatar
    Posts
    ROM
    IHO MiRaGe
    mrg, it will be a sad day indeed when you finally get the banned today/not banned tomorrow Galaxy Nexus (damn that rotten fruit). I know that you'll still have OVs around, but that new toy will take most of your dev time.
    Quote Originally Posted by aimlessanomaly View Post
    I think that the flashable zip posted by mrg right above your post will prevent that from happening by setting the permissions for you. However, make a backup before hand.
    Thanked by 2:
  23. #23
    Quote Originally Posted by pandulce1 View Post
    I think that the flashable zip posted by mrg right about your post will prevent that from happening by setting the permissions for you. However, make a backup before hand.
    What I'm trying to say is I forgot to set the permissions and cannot boot :/
    Edit: Thanks, I'm all fixed :P
  24. #24
    mrg666's Avatar
    Posts
    ROM
    CM7.2-IHO-MiRaGe
    You can wipe cache/dalvik-cache and reflash the ROM in recovery.
    Thanked by:
  25. #25
    clodfelterac's Avatar
    Samurai Dev
    Posts
    ROM
    IllusionB / OM
    boot into recovery from powered off state (hold home, vol down, and power) and restore the nandroid that you made, or wipe and reflash rom, tweak, gapps, reboot?...
    Thanked by:
