Results 1 to 15 of 15
    upconvert's Avatar
    Posts
    ROM
    Cold as Ice
    Default [Solved] Phone's mic mutes when headphones are plugged in
    Hi all,
    I'm new to this forum (and ROMs in general). With the stock ROM and the official 2.2.2 update I would frequently make calls with my earbuds in using the phone's microphone. I found it very convenient. I have recently started trying out several custom ROMs, and this no longer works.
    I have an LG VM670 currently running GingerSnap 1.3. I have had this issue with all of the ROMs I have tried, including Harmonia 2.08, BobZhome cm 7.2 and cm 9.0.0, BACKside IHO cm7.2, and quattrimus cm9.
    I've googled around quite a bit on this and couldn't find a good answer. I find it odd that it would work in the stock ROM and be broken in so many different ROMs. I noticed in the changelog for one of the BobZhome ROMS that the headset/microphone bug was addressed. Am I doing something wrong? Are there other ROMs for the VM670 that I could try that aren't based on Cyanogenmod? Do I need a new kernel? Also have I posted this in the correct place?
    Thanks,
    Nick
  2. #2
    cole2kb's Avatar
    Retired Moderator
    Posts
    Global Posts
    4,030 Global Posts
    ROM
    Stock
    Default Re: Phone's mic mutes when headphones are plugged in
    Moved to Rooting, ROMs, and Hacks subforum.
    As far as I know, this is a bug that has stuck with all of our CM7 ROMs, and there are no non-CM7 based Gingerbread ROMs for our phone. The only thing I can suggest is trying a Froyo ROM like Harmonia 1 if this is really that important to you, or you don't mind stepping back from Gingerbread,
    --Chris [cole2kb]
  3. #3
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Quote Originally Posted by cole2kb View Post
    actually, we have an aosp gingerbread rom. but there are a couple bugs that make it unusable for most people. and the headset bug has been address, it works fine for me on my build and any build i use except ics (havent tried it on ics). not sure why you are having problems with it.
    Guess whos coming back!
  4. #4
    cole2kb's Avatar
    Retired Moderator
    Posts
    Global Posts
    4,030 Global Posts
    ROM
    Stock
    Default
    My bad. It's never worked for me, I'll have to give it a go tonight. AOKP doesn't like me.
    Thanked by:
    upconvert's Avatar
    Posts
    ROM
    Cold as Ice
    Default
    Thanks, maybe I'll give that a shot, though I would prefer a stable ROM. Does anyone know how this "bug" made it all the way to cm9? It seems like it's the case with a few other phones as well.
  6. #6
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    Quote Originally Posted by upconvert View Post
    Its not as much of a priority as getting it working. Lol
  7. #7
    mrg666's Avatar
    Posts
    ROM
    CM7.2-IHO-MiRaGe
    True, more than a few.
  8. Thread Author  Thread Author    #8
    upconvert's Avatar
    Posts
    ROM
    Cold as Ice
    Default Re: [Solved] Phone's mic mutes when headphones are plugged in
    Kraven fixed it! I tried his Cold as Ice rom for the optimus S, and this issue has been fixed! Finally there is not one single thing I miss about the stock rom! I'm not sure where along the line he fixed it, but I'm using alpha 18b and it works!
    http://forums.androidcentral.com/lg-...d-alpha18.html
  9. #9
    What do I download and flash to get this working on my optimus v?
  10. #10
    Quote Originally Posted by DaveM6 View Post
    The CAI ROM
    Sent from my LG-VM670 using Xparent Cyan Tapatalk 2
  11. #11
    Quote Originally Posted by _alexkta View Post
    The CAI ROM
    Yeah but I thought its for the sprint optimus so the keys won't be the same on my v
  12. #12
    Yea but there's a virgin fix for the keys
  13. #13
    Links?
  14. #14
    Links?
    There's a link a couple of posts above
  15. #15
    Quote Originally Posted by sellers86 View Post
    Where can I download the aosp gb rom?
B
