Page 19 of 20 FirstFirst ... 1617181920 LastLast
Results 451 to 475 of 487
Like Tree37Likes
  1. #451
    nitestalkr's Avatar
    Posts
    ROM
    Tapatalk Signature~
    Default Re: Optimus V Support - [ROM][ZVJ][WIP] CyanogenMod 10 (Jellybean
    Sorry for the late response, I got distracted after testing it.
    any who..
    Updated 2nd Post, updated both patches to include Zakman's Color Banding fix, so now there's a smoother color fade instead of bars(or bands) in places like the settings menu!!
    I'm thinking of using Jelly Bean as my daily now
  2. #452
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    My port is finished, weird thing about moving latinIME to data and using jb gapps is that it doesn't show up at start you have to set up you google account later and go to input settings and disable voice input. but then keyboard functionality works.
  3. #453
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    Also, if we changed the Android Version in build.prop to 4.0.4 would we have the apps we did with ics?
  4. #454
    poweredge99's Avatar
    Posts
    ROM
    AOKP Beta 2 (thanks TDM)
    Default
    You guys are making for a exciting weekend. Thank you.
    Sent from my VM670 using Tapatalk ² to here.
  5. #455
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Quote Originally Posted by Zakman View Post
    Link??????
    kinda weird but looking for good keyboards????
    visit my sight
  6. #456
    nitestalkr's Avatar
    Posts
    ROM
    Tapatalk Signature~
    Default
    Doubt it, cause its still 4.1 software.
    Changing it to 4.0.4 just tricks the play store, and the about phone menu.
    Other than that, it won't really change the apps.
    I restored all of my apps from quattrimus AOKP, currently I'm running Drew's CMX Jelly Bean port.
    Figured I'd go ahead and set everything up, and create a back up I can bounce back and forth between the two aforementioned ROMs.
    sent from my un-dead sammich.
  7. #457
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    Quote Originally Posted by jonny5449 View Post
    Link??????
    visit my sight
    Later tonight I'll make a thread with all credits given. I'm working on decompiling the boot img to put a better kernel in.
    Thanked by 3:
  8. #458
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    Link??????
    visit my sight
    Thread:
    http://forums.androidcentral.com/opt...ml#post2047460
  9. #459
    andrewnelson23's Avatar
    Posts
    ROM
    Quattrimus
    Quote Originally Posted by nitestalkr View Post
    No, I think he means will we be able to get the ICS apps instead off of the Play store if our build.prop identifies us as an ics device. Which I think should be correct...?
    Olan Rogers, ladies and gentlemen. Funniest video ever!!!
  10. #460
    nitestalkr's Avatar
    Posts
    ROM
    Tapatalk Signature~
    Default
    Quote Originally Posted by andrewnelson23 View Post
    I should have worded that a bit differently...
    The answer is still no.
    sent from my Zom-"Bean"(AOSP JellyBean).
    Thanked by:
  11. #461
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    Do we need a jellybean kernel or can we use an ICS kernel?
  12. #462
    Posts
    ROM
    Quattrimus
    I'm pretty sure we've been using gingerbread kernels. tdm's working on an ics kernel.
  13. #463
    nitestalkr's Avatar
    Posts
    ROM
    Tapatalk Signature~
    Default
    The kernel in Drew's port, is the same one in tdm's quattrimus beta1 rom.
    I'm just surprised that we are using an outdated kernel, without an apocalypse of bugs!
  14. #464
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    If I update the kernel does that mean I have to make a new boot.img?
  15. #465
    Posts
    ROM
    Quattrimus
    what kernel are you going to use instead? I don't think there's a better one for our phones yet until tdm finishes with his ics one(or someone else finishes it first. ) I have my hunches about some people.
  16. #466
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    Honestly, I believe BobzHome's Kernel is the best.
  17. #467
    nitestalkr's Avatar
    Posts
    ROM
    Tapatalk Signature~
    Default
    From what i understand, to replace the kernel, you need to decompile the boot.img, and replace the kernel with the one you want, recomplie it(and I think sign it.. not sure), and repackage the ROM.
  18. #468
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    I just did that. Testing now.
  19. #469
    Posts
    ROM
    Quattrimus
    yay I just learned how to decompile/recompile tonight haha. Oh, I haven't used Bobzhomes. why do you think so?
  20. #470
    nitestalkr's Avatar
    Posts
    ROM
    Tapatalk Signature~
    Default
    Bob's kernels are usually the most stable, his was the favored kernel of nearly all IHO ROM devs.
    Thanked by:
  21. #471
    Posts
    ROM
    Quattrimus
    Can't you just flash a kernel?
  22. #472
    nitestalkr's Avatar
    Posts
    ROM
    Tapatalk Signature~
    Default
    Yes, if you don't want the one prepackaged with the rom.
    Without a kernel, the rom wont boot.
    Its always best if the dev packages his/her kernel of choice with their rom.
  23. #473
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    Default
    Yes but if I want to implement it into my port then I need to change the boot.img
  24. #474
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    Default
    I tried bobz kernel and I got stuck at the lg logo.. idk if I decompiled wrong or what but will work on it tomorrow
  25. #475
    nitestalkr's Avatar
    Posts
    ROM
    Tapatalk Signature~
    Default
    It could be a recompiling issue, hard to tell when it hangs at the LG screen.
