04-18-2013 11:12 PM
487 12345 ...
tools
  1. sellers86's Avatar
    He uploaded a new build with functional Wi-Fi. If someone tries this, post a screenshot of it working and I'll update the OP. Won't have time for a new flash until tonight.
    It also makes it to where you don't have to plug into a computer to boot.
    Sent from my VM670 using Tapatalk
    07-20-2012 01:24 PM
  2. Teh_Gaberz's Avatar
    07-20-2012 01:41 PM
  3. YoshinJaa's Avatar
    Video of Jellybean. Sorry for the bad production quality and forgetting to show the version but it is the Optimus S port for jellybean running on Optimus V.
    I take it only Wi-Fi works and no 3g on the OV right?
    07-20-2012 01:54 PM
  4. andrewnelson23's Avatar
    Is offline dictation functional? Or is that part of gapps that was removed? Sorry I would test it myself but I don't have time.
    07-20-2012 01:59 PM
  5. drymarro's Avatar
    Working: Wi-Fi, Audio
    Not Working: 3G, Phone, Messaging, Camera, HW acceleration, Voice, SD card recognition for Apps that need it. (Not writable)
    It's very smooth as you can tell from the video. I did not even overclock it.
    Voice without Wi-fi: Connection Problem
    w/ WiFi: Audio problem
    Note: I did not see a voice option on the default keyboard. Tried swiftkey 3 keyboard trial and when i click the voice button Audio option fails.
    Also I have been having problems with Apps recognizing the SD card.
    mlson and Badboytoast like this.
    07-20-2012 02:01 PM
  6. StingDrop's Avatar
    Sum odd reason I was playing around with airplane mode and 3g came on for about 10 min then dissapeared I made a call but it didn't even last 30 seconds but pretty good for an early alpha release
    Sent from my LG-VM670 using Xparent ICS Blue Tapatalk 2
    mlson likes this.
    07-20-2012 02:14 PM
  7. Nate456's Avatar
    Damn it really is smooth Now I want it on my droid.
    inceyet likes this.
    07-20-2012 04:05 PM
  8. anthonycr's Avatar
    Just flashed it and was wowed by the smoothness... even without an over clock. I generated a logcat to see what was wrong and one of the only errors showing was that it failed to load libwvm.so
    sellers86, sammyz and inceyet like this.
    07-20-2012 06:59 PM
  9. HurrrDurrrDURP's Avatar
    new build is up, GPS is now fixed.
    How well does this ROM work with Virgin mobile? As in does txting/Data/Calling work?
    07-20-2012 09:16 PM
  10. sellers86's Avatar
    only wifi.
    07-20-2012 09:31 PM
  11. funk223's Avatar
    I need you. I love U! My Bean
    07-20-2012 09:34 PM
  12. YoshinJaa's Avatar
    In regards to possibly getting data/sms/mms/calls to work using this rom on VM, does anyone know what else needs to be looked into besides trying to get the ZVD libs working?
    07-20-2012 09:41 PM
  13. sellers86's Avatar
    I just replaced all of the ril files, ill flash later tonight...
    07-20-2012 10:10 PM
  14. inceyet's Avatar
    This unreal within the last 6mons our rooms have gone from iho cm7 to miui which was said that it wasn't going to happen so don't ask thanks rukin5197 for proving them wrong to a beta ics thanks to all involved plus a variety of ics roms to neko bring gtr then gsnap aand now and cm10 not only is this phone a BEAST but our dev, kernel makers ,&testers community are killing the game all of y'all work is appreciated thanks and oh by the way I'm to excited about this can't wait(btw if I missed a rom my apologies , was just making a statement ):thumbup::thumbup:
    Sent from my VM670 using Android Central Forums
    sellers86 and topdawg661 like this.
    07-21-2012 01:12 AM
  15. Nate456's Avatar
    Too...many...smiles...to...count
    Sent from my shole using Tapatalk 2
    inceyet and topdawg661 like this.
    07-21-2012 01:16 AM
  16. jetfactor's Avatar
    i'm a happy girl. all of this is super sweet.
    sent from space.
    sellers86 and cammykool like this.
    07-21-2012 01:19 AM
  17. YoshinJaa's Avatar
    Seller, did the ril files get anything working on VM (call, sms, mms, 3g)?
    07-21-2012 01:38 AM
  18. sellers86's Avatar
    I haven't tested yet, got frustrated trying to build jb and went away from my computer before I falcon punched it I'll test sometime soon.
    07-21-2012 01:42 AM
  19. sellers86's Avatar
    doesnt boot. I have a logcat, there are a lot of crashes, but i cant read a logcat worth a crap
    07-21-2012 03:23 AM
  20. YoshinJaa's Avatar
    Ah, I see. I believe you will find the solution
    07-21-2012 07:38 AM
  21. cammykool's Avatar
    People the tom is ZVJ. That is a gingerbread baseband it will not work on our phones. Only ZVD Roms will.
    07-21-2012 09:57 AM
  22. andrewnelson23's Avatar
    That's for the ported rom. If the rom is built from source it doesn't have to be zvj.
    Someone correct me if I'm wrong.
    07-21-2012 10:49 AM
  23. Zakman's Avatar
    Can we upgrade our ZVD to ZVJ?
    07-21-2012 03:13 PM
  24. sellers86's Avatar
    It *might* work if built from source
    07-21-2012 03:43 PM
  25. sellers86's Avatar
    You wont have data
    07-21-2012 03:43 PM
487 12345 ...
