04-18-2013 11:12 PM
487 ... 23456 ...
tools
  1. Nate456's Avatar
    You wont have data
    Sent from my VM670 using Tapatalk
    Didn't Sammy try that?
    Sent from my shole using Tapatalk 2
    07-21-2012 04:02 PM
  2. sammyz's Avatar
    I was going to, never got around to it *yet* my OV is just sitting on the table with stock ZV4 after some KDZ flashing...maybe today, or Monday I will do it.
    Edit: phone stuck in e-mode now -_- (sigh) I don't think I'll be able to fix zv4 fw
    Sent from my Optimus M
    07-21-2012 04:56 PM
  3. sammyz's Avatar
    You wont have data
    That's not hard to fix just need some reprogramming with QPST.
    07-21-2012 05:05 PM
  4. Nate456's Avatar
    I would do it but my laptop got messed up so I don't have the zv5 cab file any more.
    07-21-2012 05:19 PM
  5. sammyz's Avatar
    Redownload it
    07-21-2012 05:19 PM
  6. sammyz's Avatar
    Flashing LS670ZVD onto my Optimus V with LGNPST via emergency mode. VERY important to do it with LGNPST and emergency mode when switching to a completely different kind of phone. Anybody want a guide? I'm thinking about making one, and getting data to work, if I can get it working on my OV myself with metropcs first. It's still flashing...
    Edit:
    Done flashing
    Look:
    07-21-2012 11:14 PM
  7. ThatGuyLurkin's Avatar
    Wont that make it.non-Virgin?
    07-21-2012 11:17 PM
  8. sammyz's Avatar
    Yes, but I use metropcs as my carrier :P but there is a way to get it to work with VM as well.
    Man -_- I keep forgetting the stupid buttons are switched -______________-
    07-21-2012 11:23 PM
  9. sammyz's Avatar
    Ok I have 3G and I'm on Optimus S firmware.....that was fast and easy. Now just to update to ZVJ and then root
    Edit: It wanted to update it with MS690 firmware O.o time to uninstall Optimus M drivers.....or maybe it's my MEID.....
    EDIT again: it didn't matter, it already downloaded ZVJ by OTA with WiFi
    now to go and reinstall missing drivers :/
    sellers86 likes this.
    07-21-2012 11:32 PM
  10. Nate456's Avatar
    So if I wanted to flash the zvj update what do I do first?
    07-21-2012 11:47 PM
  11. ThatGuyLurkin's Avatar
    If you flash ZVJ, could yiu use stock Gingerbread roms?
    07-21-2012 11:53 PM
  12. sammyz's Avatar
    I'm going to make a guide either tomorrow or monday. I highly dis-advise you from doing this unless YOU KNOW what you're doing. I g2g to bed, I still didn't get to root
    I will make a guide on how to update to ZVJ and get data working.
    07-21-2012 11:55 PM
  13. Nate456's Avatar
    I got my Droid working on VM so I think I can do this.
    07-21-2012 11:57 PM
  14. xxlemonxx's Avatar
    Non experienced users I would advice sit back and wait a week and just be able to flash the from :')
    07-22-2012 12:14 AM
  15. Nate456's Avatar
    Has anyone been able to find that candy cane that supposedly in the Easter egg or did they take it out?
    Does the notification bar remind anyone else of froyo?
    07-22-2012 01:42 AM
  16. nitestalkr's Avatar
    I just love how crazy you are... in the sense that you're using a Virgin mobile phone, on metroPCS service, with Sprint firmware..... you ARE the mad scientist if the dev community, so I dub thee. xD
    sent from my un-dead sammich.
    TauSigmaNova, sammyz and inceyet like this.
    07-22-2012 04:18 AM
  17. cammykool's Avatar
    Comming from the only device that runs jellybean perfectly. Kudos drew. Kudos
    07-22-2012 04:31 AM
  18. cammykool's Avatar
    And Sammy if can get a stock opt us S ROM on my v with 3G and MMS. I would love you
    07-22-2012 04:34 AM
  19. sammyz's Avatar
    Stock optimus S and data is easy, with MMS........hard as heck. Even I never got MMS working on optimus v stock.
    But maybe there wont be a problem since sprint and vm are the same company .....
    07-22-2012 06:55 AM
  20. anthonycr's Avatar
    The animations remind me of froyo. They're a lot closer to froyo than ICS animations, but thats OK because I'm not fond of the ics fading.
    07-22-2012 07:04 AM
  21. sammyz's Avatar
    Yes
    07-22-2012 07:08 AM
  22. jonny5449's Avatar
    In reality yes because hydro rom and Ginger rom is for zvj I reccomend those or your mom rom
    Looking for good cm9 or cm7 themes??? visit this site for good themes. http://forum.digitalhouseoftreats.com/
    07-22-2012 08:43 AM
  23. andrewnelson23's Avatar
    WOAH!!!! Haven't checked this in a day and a half, and Sammyz YOU ARE A BEAST!!!!
    ZVJ using s firmware hahaha that's so freaking great.
    Sooo if you get this working, we can have ZVJ working on our phone, and then we can fix our data using qpst, and then flash the jelly bean, and then probably be able to fix our mms using a go fix or something like that????
    sammyz likes this.
    07-22-2012 11:37 AM
  24. colossus3874's Avatar
    When I flashed this I got a warning about being grandfathered and said I needed to make a call to activate my phone. Will that make my plan rate go up? I may have download the one for the S
    07-22-2012 11:50 AM
  25. sammyz's Avatar
    Anyone who changes over to optimus s firmware will have to go to the optimus s hacks and stuff to root. I may be able to "hack" the zvj update to get MMS working on stock.
    07-22-2012 01:07 PM
487 ... 23456 ...
