jonny5449
AC Citizen
No he didn't he got it to build not boot.
Sent from my shole using Tapatalk 2
I mistaken
Srry
Looking for good cm9 or cm7 themes??? visit this site for good themes. http://forum.digitalhouseoftreats.com/
Im sure data is an easy fix, seeing what Drew did.
Sent from my LG-VM670
V users your closer than you think
Now everyone smile and say...
THANKS TVALL
Click to view quoted image
Word!
If you wanna test plug into computer and flash gapps from drew
I haven't tried computer yet
Refer to last page to see link
http://www.vmroms.com/index.php?topic=122.0
Sent from my LG-LS670 using Tapatalk 2
Ok i did know i can test on my laptop how does that work
So is that a build made for the ov? As in, calls and sms should work?
Tvall built it??? I gotta flash that.
Sent from my Optimus M
Yup dunno wat works
So you just flash and have it plugged into the computer? And it'll do the rest?
Kinda confused. I want to try this as I have 2 Optimus V's.
Side note, my phone isn't being recognized by the computer. No SD card but still... the other Optimus V with quattrimus is recognized.
