Optimus V Support - [ROM][ZVJ][WIP] CyanogenMod 10 (Jellybean!)
drymarro
12
7
Re: Optimus V Support - [ROM][ZVJ][WIP] CyanogenMod 10 (Jellybean
Just flashed Tvall's CM10. Stuck at boot screen(CM9 guy) btw.
EDIT: Just flashed The Optimus S JB port and it works.
Might put up a video... not sure.
ThatGuyLurkin
2,155
665
It boots, nothing special. Its in Early Alpha. Real Early. No data, just wifi. The basics. Try the newest build.
drymarro
12
7
Video of Jellybean. Sorry for the bad production quality and forgetting to show the version but it is the Optimus S port for jellybean running on Optimus V.
[YT]http://www.youtube.com/watch?v=ty5p6BR3Zp0[/YT]
cole2kb
Retired Moderator
Apr 7, 2011
2,503
547
He uploaded a new build with functional Wi-Fi. If someone tries this, post a screenshot of it working and I'll update the OP. Won't have time for a new flash until tonight.
sellers86
1,837
617
It also makes it to where you don't have to plug into a computer to boot.
Sent from my VM670 using Tapatalk
Teh_Gaberz
Active member
Mar 21, 2011
28
7
andrewnelson23
795
145
Is offline dictation functional? Or is that part of gapps that was removed? Sorry I would test it myself but I don't have time.
drymarro
12
7
I take it only Wi-Fi works and no 3g on the OV right?
Working: Wi-Fi, Audio
Not Working: 3G, Phone, Messaging, Camera, HW acceleration, Voice, SD card recognition for Apps that need it. (Not writable)
It's very smooth as you can tell from the video. I did not even overclock it.
Voice without Wi-fi: Connection Problem
w/ WiFi: Audio problem
Note: I did not see a voice option on the default keyboard. Tried swiftkey 3 keyboard trial and when i click the voice button Audio option fails.
Also I have been having problems with Apps recognizing the SD card.
StingDrop
133
18
Sum odd reason I was playing around with airplane mode and 3g came on for about 10 min then dissapeared I made a call but it didn't even last 30 seconds but pretty good for an early alpha release
Sent from my LG-VM670 using Xparent ICS Blue Tapatalk 2
Reactions: mlson
HurrrDurrrDURP
356
111
new build is up, GPS is now fixed.
How well does this ROM work with Virgin mobile? As in does txting/Data/Calling work?
