Zakman
Did it just show a black screen?
No, it dimmed the boot animation but never booted in.
Well that means its not a kernel issue. Probably framework-res is refusing to work... I have no idea why it would do that. Try copying all the extra lib files and bin files from drews port into your port, and see if it boots.
Ok I ported lugohirps p500 rom but radio still isnt working for some odd reason.
btw, here is the list of files that arnt in the p500 rom(besides browser, it was actining up for me on the p500 rom so i replaced it):
Code:app----- browser.apk bin----- cnd netmgrd port-bridge rmt_storage su tsdown wl qmuxd etc----- init.qcom.bt.sh init.thunderc.usb.rc MELFAS_FIRM profile setwifi.sh apns-conf FIRMWARE-- wlan PERMISSIONS-- android.hardware.telephony.cdma android.hardware.touchscreen.multitouch lib----- libjackpal-androidterm4 libloc_api-rpc-qc libreference-cdma-sms libstagefrighthw MODULES--ALL
Also, does anyone know the correct RIL files to replace?? I have this list from a different phone port but im not sure if its correct:
@nitestalkr these are the files I used for the issues with the color banding:
Color Banding.zip
Place them in system/lib and it should fix it. I havent tested them but they should work.
My port is finished, weird thing about moving latinIME to data and using jb gapps is that it doesn't show up at start you have to set up you google account later and go to input settings and disable voice input. but then keyboard functionality works.
Also, if we changed the Android Version in build.prop to 4.0.4 would we have the apps we did with ics?
Doubt it, cause its still 4.1 software.
Changing it to 4.0.4 just tricks the play store, and the about phone menu.
Other than that, it won't really change the apps.
I restored all of my apps from quattrimus AOKP, currently I'm running Drew's CMX Jelly Bean port.
Figured I'd go ahead and set everything up, and create a back up I can bounce back and forth between the two aforementioned ROMs.
sent from my un-dead sammich.
No, I think he means will we be able to get the ICS apps instead off of the Play store if our build.prop identifies us as an ics device. Which I think should be correct...?
