Optimus V Support - [ROM][ZVJ][WIP] CyanogenMod 10 (Jellybean!)
anthonycr
Themer. You've seen them
Jul 11, 2011
2,104
571
No, it dimmed the boot animation but never booted in.
Well that means its not a kernel issue. Probably framework-res is refusing to work... I have no idea why it would do that. Try copying all the extra lib files and bin files from drews port into your port, and see if it boots.
Zakman
492
185
Re: Optimus V Support - [ROM][ZVJ][WIP] CyanogenMod 10 (Jellybean
Ok I ported lugohirps p500 rom but radio still isnt working for some odd reason.
Zakman
492
185
UPDATE: Got Data and radio working without color banding :D now im working on sound issues... but should be an easy fix :D and GAPPS Sticks :D
Reactions: nitestalkr
nitestalkr
889
261
btw, here is the list of files that arnt in the p500 rom(besides browser, it was actining up for me on the p500 rom so i replaced it):
Code:
app-----
browser.apk
bin-----
cnd
netmgrd
port-bridge
rmt_storage
su
tsdown
wl
qmuxd
etc-----
init.qcom.bt.sh
init.thunderc.usb.rc
MELFAS_FIRM
profile
setwifi.sh
apns-conf
FIRMWARE--
wlan
PERMISSIONS--
android.hardware.telephony.cdma
android.hardware.touchscreen.multitouch
lib-----
libjackpal-androidterm4
libloc_api-rpc-qc
libreference-cdma-sms
libstagefrighthw
MODULES--ALL
Also, does anyone know the correct RIL files to replace?? I have this list from a different phone port but im not sure if its correct:
I believe those are all RIL files.. I know there's 1 or 2 in the /bin folder that control RIL stuff.
sent from my un-dead sammich.
nitestalkr
889
261
@nitestalkr these are the files I used for the issues with the color banding:
Color Banding.zip
Place them in system/lib and it should fix it. I havent tested them but they should work.
Thanks, I'll test it soon, and if it fixes it, I'll incorporate it in both JB patches, and add even more thanks to you in the op. :D
nitestalkr
889
261
Sorry for the late response, I got distracted after testing it. :p
any who..
Updated 2nd Post, updated both patches to include Zakman's Color Banding fix, so now there's a smoother color fade instead of bars(or bands) in places like the settings menu!!
I'm thinking of using Jelly Bean as my daily now :p
Zakman
492
185
My port is finished, weird thing about moving latinIME to data and using jb gapps is that it doesn't show up at start you have to set up you google account later and go to input settings and disable voice input. but then keyboard functionality works.
Zakman
492
185
Also, if we changed the Android Version in build.prop to 4.0.4 would we have the apps we did with ics?
nitestalkr
889
261
Doubt it, cause its still 4.1 software.
Changing it to 4.0.4 just tricks the play store, and the about phone menu.
Other than that, it won't really change the apps.
I restored all of my apps from quattrimus AOKP, currently I'm running Drew's CMX Jelly Bean port.
Figured I'd go ahead and set everything up, and create a back up I can bounce back and forth between the two aforementioned ROMs.
andrewnelson23
795
145
No, I think he means will we be able to get the ICS apps instead off of the Play store if our build.prop identifies us as an ics device. Which I think should be correct...?
Chelsea rae
