Results 1 to 25 of 25
    Default HELP! I bricked my phone and my custom rom wont load
    I was loading custom roms off rom manager (i learned thats bad) now it goes to lg boot logo and a lit black screen please help.
  2. #2
    sammyz's Avatar
    Posts
    ROM
    OV:quattrimus OM:BACKside
    Default Re: HELP! I bricked my phone and my custom rom wont load
    i get that
    Attached Thumbnails Attached Thumbnails HELP! I bricked my phone and my custom rom wont load-nooooooooo.jpg
  4. #4
    clodfelterac's Avatar
    Samurai Dev
    Posts
    ROM
    IllusionB / OM
    did you make a backup of your previous rom before you flashed the rom mangler rom?...
  5. #5
    Nate456's Avatar
    Posts
    ROM
    Stock, CM10, AOKP
    Default
    If you don't mind answering, which rom did you flash?
    Sent from my shole using Tapatalk 2
    Yeah. its on my sd card
    im not sure which one i flashed , im so caught up on this
  8. #8
    Samurai Dev
    Posts
    ROM
    IllusionB / OM
    Quote Originally Posted by k4no1 View Post
    its under clockworkmod/backup?... then you should be able to wipe cache/dalvik/data, format boot/cache/data/system, and restore your backup... delete rom manager and never use it again...
  9. #9
    sammyz's Avatar
    Posts
    ROM
    i get that
    It's a bad download, redownload the cab and try again, delete the one on the computer now...file size is 101 MB. I need to start doing md5 checksums...
  10. Thread Author  Thread Author    #10
    Quote Originally Posted by clodfelterac View Post
    How would i do that?
  11. #11
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    Boot into recovery by holding home, volume down, and power at the same time til the lg icon flashes then restore your backup.
    Sent from my VM670 using Tapatalk
  12. Thread Author  Thread Author    #12
    Quote Originally Posted by sellers86 View Post
    when i do that it just goes blank after lg logo flashing
  13. #13
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    See the stickies, or do Sammy's unbrick guide. You have a new v, and the recovery rom manager flashed is not compatible with your screen.
  14. Thread Author  Thread Author    #14
    ive done his method about 5 times and it seems to not work
  15. #15
    inceyet's Avatar
    Posts
    ROM
    MIUIgb
    Default
    When that happens try pressing the power button see if that gets cwm to come up
  16. Thread Author  Thread Author    #16
    Quote Originally Posted by inceyet View Post
    nothing bro
  17. #17
    Nate456's Avatar
    Posts
    ROM
    Stock, CM10, AOKP
    Try using droid@screen (its somewhere in the stickies) to see the recovery.
  18. Thread Author  Thread Author    #18
    Quote Originally Posted by Nate456 View Post
    idk bout that , the program dosent pick up my device,
  19. #19
    andrewnelson23's Avatar
    Posts
    ROM
    Quattrimus
    You proly don't have adb installed and working. You have to have that working. I'd follow sammyz's advice if I were you. Much less of a headache.
    Olan Rogers, ladies and gentlemen. Funniest video ever!!!
    Thanked by 2:
  20. #20
    inceyet's Avatar
    Posts
    ROM
    MIUIgb
    Default
    Quote Originally Posted by andrewnelson23 View Post
    +1
  21. #21
    Samurai Dev
    Posts
    ROM
    IllusionB / OM
  22. Thread Author  Thread Author    #22
    im going to try sammyz's 2nd method. hopefully it works
  23. Thread Author  Thread Author    #23
    nvm that last post of mine -____-
  24. #24
    Samurai Dev
    Posts
    ROM
    IllusionB / OM
    youre going to need adb to flash a working recovery and screencast to see what your doing... hopefully one of sammyz tutorials will work for you... and bigsupers fix blackscreen thread works... its just gonna take some effort... such comes with the territory... :-)
  25. #25
    sammyz's Avatar
    Posts
    ROM
    Default
    Actually you could use the second post, just start from the blank screen in recovery mode.
    Sent from my Optimus M
