- 07-22-2012, 03:19 PM
Thread Author #1
Porting Optimus S ZVJ ROMs to Optimus V ZVJ
Hello everyone, as you all may know, I got data working on my optimus v with optimus s ZVJ flashed onto it. What will not work with this is MMS and the home key and menu key is switched. So, I was wondering if anyone could fix some ZVJ based roms to get these 2 things working. I wont have time to make the tutorial today I won't be home till late tonight. Tomorrow I will make it, but it would be nice to have some ZVJ roms ported to have the 2 issues fixed. Mainly the CM10 rom, post how to fix it in the OV support thread please and upload files that need to be replaced. Other ZVJ based ROMs that are ported or how to port them should be put in this thread. I know a couple of you guys have ported a few ZVD based roms to the OV before because of Cold As Ice by the kraven, it should be the same, if not a similar process.
Edit: also the model # has to be changed.
How to get onto ZVJ is here [GUIDE] Optimus V ZVJ
Sent from my Optimus MLast edited by sammyz12; 07-23-2012 at 12:04 PM.
Thanked by 2: - 07-22-2012, 05:26 PM #2
Re: Porting Optimus S ZVJ ROMs to Optimus V ZVJ
You can probably do it similar to the way cm7 is set up. Deodex the zvj rom, change build prop add te proper mmsconfig.xml to mms.apk and use apk manager to modify the smsdispatcher.smali in framework.jar if you can find someone to do that though send them my way since I don't have working incoming mms on my marquee.
Also forgot switching the keys is easy just go into usr/share/keylayout/ - 07-22-2012, 05:31 PM #3
- 07-22-2012, 05:40 PM #4
is there a stock zvj rom ?
- 07-22-2012, 05:41 PM #5
Stock ZVJ Gingerbread
Sent from my LG-VM670 using Tapatalk 2 - 07-22-2012, 05:42 PM #6
- 07-22-2012, 05:43 PM #7
- 07-22-2012, 05:43 PM #8
- 07-22-2012, 05:45 PM #9
Here it is
[COMMUNITY ROM][2.3.3][ZVJ] Stock Rooted ROM Base
Looking for good cm9 or cm7 themes??? visit this site for good themes. - 07-22-2012, 05:46 PM #10
- 07-22-2012, 05:47 PM #11
- 07-22-2012, 05:47 PM #12
- 07-22-2012, 05:47 PM #13
- 07-22-2012, 05:48 PM #14
- 07-22-2012, 05:49 PM #15
- 07-22-2012, 05:49 PM #16
- 07-22-2012, 05:49 PM #17
- 07-22-2012, 05:50 PM
Thread Author #18
You MUST get sprint firmware flashed while in e-mode and LGNPST......remember you will lose AAA/HA keys.<br />Originally Posted by jonny5449<br />
I shall digit up<br />
Whatever baseband I'm on gets either a port or heavely tweaked rom <br />
<br />
<br />
I have zvh update but I can't remember if it is gingerbread or not?? But if there is a already deodexed zvj me wants that
Sent from my Optimus M - 07-22-2012, 05:50 PM #19
- 07-22-2012, 05:51 PM #20
- 07-22-2012, 05:54 PM #21
- 07-22-2012, 05:56 PM
Thread Author #22
- 07-22-2012, 06:02 PM #23
I must know, are you connected to VM on a ZVJ stock GB rom? THAT, I want to know. Please and thank you.
Sent from my LG-VM670 using Tapatalk 2 - 07-22-2012, 06:02 PM
Thread Author #24
- 07-22-2012, 06:04 PM #25
Reply
which makes me think that I need to find out where in the rom it's setting that value. But in the past I haven't had that problem with sprint roms.
