I do know this. I actually accidentally deleted the stock ROM while in recovery. Instead of going back through the opti-sfx.exe, I downloaded the ZVJ update.zip. Flashed xionia recovery, factory reset, apply update. Zip and install jcase_rootme.zip.
Got my stock rooted GB back without the computer. Yay
Really? Is it that noticeable of difference in performance?
Well I don't want to say It'll help everyone because I'm sure it's a ymmv situation but myself and AndrewNelson both experienced noticeably better signal strength on LS670ZVJ
Tapatalk'n it from my VM670 running Mirrage on LS670ZVJ Baseband
Changing firmware isn't easy but is better. The ZVJ radio/firmware update is true sprint.
The VM670(2.2.1/2.2.2 froyo) is a subversion of the LS670.
Take for example, when you update the ov (zv9) you still are running froyo. Updating the LS670 to ZVJ gets you to gingerbread and the updated sprint radio. All this at stock value.
Using my VM670 running rooted stock ZVJ
Okay, a few more questions.
Can I run ZVJ on a custom V ROM (particularly MiRaGe)?
If I get to ZVJ, would I have to change the PRL, too?
Just to be sure if your going to try I suggest you save a qcn file from qpst and a nvs file as per this guide. Between the two you basically have your all your radio settings backed up.
this is what i do after writeing the .nvs file to zvd to get data back
To Restore Data on LS670 Firmware:
1: Install anycut.apk
2: Run anycut and "create shortcut"-"Activity"-"LG HIDDEN DATA" and hit ok
3: Return to desktop and open the shortcut
4: go into CDG2 Data Settings and change PPP CARRIER from Sprint to Undetermined
5: Hit back and the phone will reboot
6: Open Qpst service programing and hit Load from file
7: Select the .qcn file you saved durring prep
8: Select write to phone and enter your spc
9: The phone will reboot
10: Open LGNPST and Select "Phone Setting" Enter your Spc hit ok then Read
11: Close lgnpst and open DFS and enter your Spc and click SPC
12: Click the Programing Tab then the Mobile IP TAB and click Read
13: On the first Profile Uncheck the boxes next to Enter value in HEX for both AAA Shared Secret and HA Shared Secret
14: Clear anything there and click write current profile settings
15: go to profile 3 and Uncheck the Enter Value in HEX box for AAA Shared Secret and Copy the value
16: Go To profile 2 and Paste that value into AAA Shared Secret box and Enter Vmug33k for HA shared Secret
17: Hit Write current profile settings and switch to the data tab next to mobile ip and hit read
18: under HDR AN and HDR AN Long you'll see with PWD boxes under them
19: Paste your AAA Key that you copied earlier into both pwd boxes and hit write
Reboot Phone and you will have Data
This is a big help, anyone trying, I suggest use this to help get your data. This is thewraith420 method. I'm just copying and pasting for anyone who goes to the last reply.
I used this and it is a life(data) saver.
Again, this is not my work. Copied from an earlier post from thewraith420.
VM670 on ZVJ-running Hydro Rom
Thanks, I planned on reposting that anyways. You saved me having to find it again
Tapatalk'n it from my VM670 running MiRaGe Cm7 on LS670ZVJ Baseband
When school is over, I will be a flashaholic, testing more stuff, porting more ROMs...etc. My optimus V is forever stuck on optimus u firmware. My optimus S running v firmware has reboot problems....but it seems to reboot less the longer you use a Rom (and not change it).
I was surprised to see your v working at all knowing what bricked it, LGNPST still won't take it back to zv5 huh?
Tapatalk'n it from my Cold As Ice VM670 running LS670ZVJ firmware
Portions of this page are modifications based on work created and shared by the Android Open Source Project
and used according to terms described in the Creative Commons 2.5 Attribution License. AndroidCentral is an independent site
that is not affiliated with or endorsed by Google.
