01-17-2014 02:43 PM
470 1234 ...
tools
  1. sammyz's Avatar
    I keep getting
    The module "C:\LG Electronics\LGNPST\Model\MTP\VM670.dll" was loaded but the call to DllRegisterServer failed with error code 0x80020009.
    Do I just ignore that?
    No, install everything in LG Components Archive
    Sent from my LS670 using Android Central Forums
    07-23-2012 02:39 PM
  2. andrewnelson23's Avatar
    From the components? I already installed that. Did it twice. Do I need to reboot again?
    07-23-2012 02:40 PM
  3. sammyz's Avatar
    Try it, if that doesn't work, uninstall and reinstall everything that has to do with LGNPST
    07-23-2012 02:41 PM
  4. drymarro's Avatar
    Will we still be able to use regular Optimus V roms?
    07-23-2012 02:45 PM
  5. sammyz's Avatar
    No, but it may be possible to port them to ZVJ like how they got the CM10 port by drew to work on ZVD....
    07-23-2012 02:52 PM
  6. andrewnelson23's Avatar
    Okay I uninstalled lgnpst and lgnpst generic models, but when attempting to uninstall lgnpst, I got this error.
    Error 1721. There is a problem with this Windows Installer package. A program required for this install to complete could not be run. contact your support personnel or package vendor. Action: UnRegisterCOM_3.0, location:
    C:\windows\Installer\MS12702.tmp, command:
    -uninstall C:\LG Electronics\LGNPST\Components 3.0
    07-23-2012 02:59 PM
  7. sammyz's Avatar
    Make a new account, use it to uninstall and reinstall it all.
    07-23-2012 03:01 PM
  8. andrewnelson23's Avatar
    A new user account for windows?
    07-23-2012 03:07 PM
  9. sammyz's Avatar
    Yes, I know it's the only way because your current windows profile has a corrupt windows installer. I've had this issue before......
    07-23-2012 03:09 PM
  10. andrewnelson23's Avatar
    Dang. That's annoying. Okay I will. I like how you changed your signature. Can you add me on facebook and your help will be much easier. just click that f button on the right side.
    07-23-2012 03:11 PM
  11. sammyz's Avatar
    I didn't change my signature.....I'm on an optimus s right now, but now I changed the tapatalk signature
    Edit I mean I'm on an optimus v with s firmware...
    Sent from my Optimus V running Optimus S firmware on MetroPCS
    07-23-2012 03:13 PM
  12. andrewnelson23's Avatar
    Ohhhh. hahaha
    07-23-2012 03:13 PM
  13. andrewnelson23's Avatar
    I tried doing that and it didn't work.. could it be a problem that i'm 32 bit?
    07-23-2012 04:02 PM
  14. andrewnelson23's Avatar
    I think it has to do with the reggie exe. I think I have to get that to run with administrator access.
    07-23-2012 04:13 PM
  15. sammyz's Avatar
    Right click the dll and press register active x dll......
    07-23-2012 04:20 PM
  16. andrewnelson23's Avatar
    I put this thing called reggie.exe(after giving it administrator access) onto the mtp and then just dragged the dll's to it and it registered both of them
    07-23-2012 04:22 PM
  17. andrewnelson23's Avatar
    I had been trying that and it kept giving me that error that I showed earier. freaking annoying. so I just used the method that phatninja55 used in his unbrick guide using s firmware(involving the reggie.exe)
    07-23-2012 04:24 PM
  18. sammyz's Avatar
    That's strange, I will add Reggie to this thread if need be.
    07-23-2012 04:25 PM
  19. sammyz's Avatar
    So you're finally going to flash S firmware I'm guessing?
    07-23-2012 04:27 PM
  20. andrewnelson23's Avatar
    No. I'm having great difficulty. will you add me on fb already so I don't hog your thread? haha
    07-23-2012 04:41 PM
  21. sammyz's Avatar
    Facebook isn't loading on my web browser app......I'll pm you my fb and you can add me so I can just use the app
    07-23-2012 04:46 PM
  22. capslock118's Avatar
    Hi sammyz12,
    Thanks for this guide.
    How does this guide affect the current custom rom and custom recovery that I already have on my optimus V?
    i.e. I have a custom recovery already installed and a custom rom (harmonia 2).
    07-23-2012 06:00 PM
  23. ThatGuyLurkin's Avatar
    I just woke up.... Gonna go try this now. Ill report in a few.
    07-23-2012 06:04 PM
  24. sellers86's Avatar
    I keep getting
    Im going to go ahead and guess that your on windows 7 64-bit... the generic installer does not work correctly. you have to register the dll manually. to do that, go to start, search cmd, right click cmd and run it as an administrator. when it opens, copy and paste this into the cmd window (your phone may have to be plugged in, not sure.)
    regsvr32.exe "C:\LG Electronics\LGNPST\Model\MTP\VM670.dll
    then press enter. it may take awhile but be patient. after its done, open up LGNPST and select the cab file. you may get an error, if you do Ill help you through that one to.
    07-23-2012 06:27 PM
  25. Nate456's Avatar
    Success I got the OS firmware on now time to get data back.
    sellers86 and misternovember like this.
    07-23-2012 06:29 PM
470 1234 ...
