01-17-2014 02:43 PM
470 12345 ...
tools
  1. andrewnelson23's Avatar
    Im going to go ahead and guess that your on windows 7 64-bit... the generic installer does not work correctly. you have to register the dll manually. to do that, go to start, search cmd, right click cmd and run it as an administrator. when it opens, copy and paste this into the cmd window (your phone may have to be plugged in, not sure.)
    regsvr32.exe "C:\LG Electronics\LGNPST\Model\MTP\VM670.dll
    then press enter. it may take awhile but be patient. after its done, open up LGNPST and select the cab file. you may get an error, if you do Ill help you through that one to.
    No, actually I'm windows 7 32 bit. it should work. I think the problem arises from the old lgnpst/lgnpst components/etc that I had from phatninja's unbrick guide from april. I tried uninstalling all of that, but it won't work. sammyz helping me to uninstalling using the admin account.
    07-23-2012 06:33 PM
  2. sammyz's Avatar
    We bought two of them off EBay (Thanks, Mr. Anonymous!) and I had to drive two hours both ways to get them at 1am. Fun times.
    It was a good thing we did it that way, though, because we don't live in a 3G area and they wouldn't have been sold at local stores.
    I run win7 64 bit I don't have problems at all with LGNPST.
    Sent from my Optimus V running Optimus S firmware on MetroPCS
    07-23-2012 06:47 PM
  3. Nate456's Avatar
    Alright so I was able to get signal but no 3g. It's my Droid all over again.
    Gonna try DFS to get it back.
    07-23-2012 06:53 PM
  4. sammyz's Avatar
    You kidding me? O.o
    07-23-2012 06:54 PM
  5. Nate456's Avatar
    You kidding me? O.o
    Nope
    07-23-2012 06:59 PM
  6. sellers86's Avatar
    i dont think that was the problem... I got that same exact error too, and Ive never used lgnpst before. Use the command I put on there and see if it works. It did for me. It will save you a lot of hassle.
    07-23-2012 07:00 PM
  7. nitestalkr's Avatar
    Just out of curiosity, what are the benefits of ZVJ vs. ZVD?
    I know that in ZVJ, hardware acceleration is broken(Netflix dev said this in an email sent to another AC user in the s forums)
    sent from my un-dead sammich.
    07-23-2012 07:44 PM
  8. sammyz's Avatar
    OS ZVJ roms functional on ov
    07-23-2012 07:47 PM
  9. ThatGuyLurkin's Avatar
    Then again! Virgin Mobile has an Activate app. Try flashing Harmonia 1, activate if you can, go back to ZVJ rom.
    I can't get this going. Keep getting an error at registering the ActiveX dll.
    07-23-2012 07:49 PM
  10. nitestalkr's Avatar
    So other than ZVJ specific ROMs, there's no real benefits in capabilities, performance, or battery life?
    07-23-2012 07:55 PM
  11. sammyz's Avatar
    Oh God........everyone seems to get this error....uninstall LGNPST completely, erase LG Electronics folder from C:\ reboot and start over.
    If you cannot uninstall LGNPST then you must enable the admin account by doing this:
    Press Start
    Type cmd
    Right click cmd and press run as admin
    Type net users administrator /active:yes
    Type net users administrator *
    Hit enter 3 times
    Log out
    Choose administrator account and then uninstall, reboot, log onto admin, install, reboot, log in to admin register the dll and start following the guide.
    ThatGuyLurkin likes this.
    07-23-2012 07:56 PM
  12. sammyz's Avatar
    I don't know, ask someone who owns an optimus S, I'm not on ZVJ yet and probably wont be until Wednesday.
    nitestalkr likes this.
    07-23-2012 07:58 PM
  13. ThatGuyLurkin's Avatar
    I'm gonna see if he can get 3G going before attempting this. Sorry.
    07-23-2012 08:02 PM
  14. sammyz's Avatar
    Just gotta flash AAA and HA
    07-23-2012 08:07 PM
  15. Nate456's Avatar
    In 5 minutes I will have root, then flash Lesie's Rhode rom, try the activate app (who knows how many times).
    07-23-2012 08:09 PM
  16. sammyz's Avatar
    Hopefully that's all you gotta do for data.
    07-23-2012 08:12 PM
  17. andrewnelson23's Avatar
    Use dfs to fix your data. bottom of the first op.
    nitestalkr and sammyz like this.
    07-23-2012 08:16 PM
  18. Nate456's Avatar
    Yea I know but I'm going to try Rhode first.
    07-23-2012 08:30 PM
  19. ThatGuyLurkin's Avatar
    Omg. Sammyz, I love you. xD!
    I just reverted to ZV5 with no problems. You've done some amazing work. :P
    I'm gonna do this. I got the LG stuff going.
    sammyz likes this.
    07-23-2012 08:51 PM
  20. ThatGuyLurkin's Avatar
    I was wondering. How to back up those keys? Once this is posted, I'm re-reading the OP.
    Also, can I do this with Stock recovery? I just reverted to ZV5, and it's kinda a long process to flash a new recovery. :P
    07-23-2012 08:56 PM
  21. sellers86's Avatar
    Run the command I posted a few posts up.
    07-23-2012 09:02 PM
  22. andrewnelson23's Avatar
    there's a few ways. open them up in dfs before you do anything, and you can copy all of them.
    07-23-2012 09:02 PM
  23. Nate456's Avatar
    Well I couldn't get data with DFS so on to Rhode.
    07-23-2012 09:03 PM
  24. nitestalkr's Avatar
    You can install cannibal open touch recovery via flash able zip (labeled alternative zip in Drews thread). Never knew it was possible to install a recovery, from a recovery, by flashing a zip.. its mind blowing xD
    07-23-2012 09:14 PM
  25. sammyz's Avatar
    Andrewnelson knows how, my AAA/HA keys are both "metropcs" :P my data worked fine after resoring the nvs file and flashing PRL for metroPCS and the AAA and HA keys must be entered for data to work so I think LGNPST does back up and restore the keys, but others have said that it didn't get data working, maybe you just have to reactivate with harmonia or something O.o idk, but find a way to get those keys if you dont have them already.
    07-23-2012 09:14 PM
470 12345 ...
