01-17-2014 02:43 PM
470 ... 23456 ...
tools
  1. Nate456's Avatar
    Rhode didn't work I doubt Harmonia would.
    07-23-2012 09:31 PM
  2. sellers86's Avatar
    You may have to revert using the sticky.
    07-23-2012 09:34 PM
  3. ThatGuyLurkin's Avatar
    You can install cannibal open touch recovery via flash able zip (labeled alternative zip in Drews thread). Never knew it was possible to install a recovery, from a recovery, by flashing a zip.. its mind blowing xD
    sent from my un-dead sammich.
    Stock recovery, not possible I believe. Maybe even a brick, I don't know. :P
    Andrewnelson knows how, my AAA/HA keys are both "metropcs" :P my data worked fine after resoring the nvs file and flashing PRL for metroPCS and the AAA and HA keys must be entered for data to work so I think LGNPST does back up and restore the keys, but others have said that it didn't get data working, maybe you just have to reactivate with harmonia or something O.o idk, but find a way to get those keys if you dont have them already.
    Sent from my Optimus V running Optimus S firmware on MetroPCS
    So I have to use that DFS thing? Sorry. I always avoided these programs. And I have no files labeled VM670_COM##. Should I do that Read thing?
    Edit: Got my VM670_COM## file. I copied to where I will remember, and now I deleted the one in the folder. I'm going to keep going.
    07-23-2012 09:39 PM
  4. sammyz's Avatar
    Yes to both questions
    07-23-2012 09:44 PM
  5. Nate456's Avatar
    I'm just going to keep going.
    07-23-2012 09:46 PM
  6. sellers86's Avatar
    Did the command work?
    07-23-2012 09:47 PM
  7. sammyz's Avatar
    I think he followed what I told him to do
    07-23-2012 09:55 PM
  8. ThatGuyLurkin's Avatar
    Everything is going good. I DIDN'T Do the DFS thing though. I didn't refresh this page, so I didn't seen your message. It's currently doing the LS670 and ZVD Bin file.
    07-23-2012 09:57 PM
  9. sammyz's Avatar
    Oh boy, you may never have data again
    07-23-2012 10:06 PM
  10. Nate456's Avatar
    Woo I got official GingerBread on my OV well OS
    07-23-2012 10:09 PM
  11. sammyz's Avatar
    Data?
    07-23-2012 10:15 PM
  12. ThatGuyLurkin's Avatar
    We'll see. I have a few ideas. I'm in Recovery atm.
    Update: I'm now at the point of Reception, but no 3g. Hey Nate, what did you do to get 3g?
    07-23-2012 10:15 PM
  13. Nate456's Avatar
    Data?
    Nope but still trying.
    07-23-2012 10:19 PM
  14. sammyz's Avatar
    You can write AAA/HA with LGNPST and QPST as well.
    07-23-2012 10:26 PM
  15. sammyz's Avatar
    Are you guys trying to write AAA/HA while booted or in recocery? Try it while booted, you do not have to dial anything to enable the PORT
    07-23-2012 10:59 PM
  16. ThatGuyLurkin's Avatar
    What's the file extension on the AAA/HA file? I have everything but 3g/1x. I went to ZVJ
    07-23-2012 11:32 PM
  17. andrewnelson23's Avatar
    This is WAY complicated. It'd be fine if the gal-dang user id didn't keep switching back to sprintpcs after I write it to be vmobl in qpst. ugh. I'm somewhat closer to getting data to work than earlier tonight.
    nitestalkr likes this.
    07-24-2012 02:02 AM
  18. Nate456's Avatar
    Yea when I realized that was happening I said, "f*** it I'll do it tomorrow."
    07-24-2012 02:13 AM
  19. ThatGuyLurkin's Avatar
    Actually. What I believe we need is a ZV4.bin/ZV5.bin/ZV5.bin file so we can change it back to Optimus V.
    I was able to get 3G to appear, but it disappears after leaving the settings.
    Any chance of getting that Sammyz or Asadullah? I've been looking around the threads and the LG thing and noticed that there was aa way to go to Optimus S.bin file, and not Optimus V.bin file
    07-24-2012 02:38 AM
  20. andrewnelson23's Avatar
    I got a couple profiles to stick at least. We need the vm670 dll NV settings.
    Then we can just change the ones that matter out so we can switch the user id.
    07-24-2012 03:00 AM
  21. ThatGuyLurkin's Avatar
    What do you meam by NV? NVS?
    I thought we just needed the Bin file so we can flash back. We already have the dll.
    07-24-2012 03:22 AM
  22. andrewnelson23's Avatar
    the nv for the vm670 so we can know what to edit to get data working. Ah, but see, we aren't stuck. You can use the fixing brick with s firmware guide in order to get back to v roms and recoveries and get your data back. (provided you didn't lose that :P)
    07-24-2012 05:17 AM
  23. ThatGuyLurkin's Avatar
    I don't believe I did. Correct me if I'm wrong. I still have reception, and 3G only when toggling back and fourth(meaning its still there hopefully) :P
    Also, I can send/receive text.
    07-24-2012 05:33 AM
  24. taha1112's Avatar
    Is there anyway to get data back? I didn't backup those keys as it wasn't in your old guide.
    07-24-2012 06:39 AM
  25. asadullah's Avatar
    you may be able to get 1x. vmug33k is the ha password for all virgin mobile phones. That alone can get you 2g data. BUT before you do that
    if you flash teh sprint rom and don't touch dfs or anything you can just downgrade the virgin mobile rom (radio and all) and then use the activate app to get data to work 100% and then backup your ha aaa keys.
    On a side note I don't recommend lgnpst 1.3. Personal preference had a lot of issues with it
    07-24-2012 07:14 AM
470 ... 23456 ...
