Page 1 of 18 1234 ... LastLast
Results 1 to 25 of 449
Like Tree25Likes
    sammyz's Avatar
    Posts
    ROM
    OV:quattrimus OM:BACKside
    Default [GUIDE] Optimus V ZVJ
    For those who are not the best with reprogramming an entire phone: [Patch's]ZVJ to ZVD & ZVD to ZVJ Flashable zips(Optimus V)
    For advanced users that like advanced stuff
    Read everything before attempting, make sure you are comfortable with these programs.
    (There are more later in the guide.)
    Ok, before you start saying data won't work, it WILL work. I have tested this myself with an Optimus V ZV4 baseband. Now what won't work is MMS, which is why we have this thread: Porting Optimus S ZVJ ROMs to Optimus V ZVJ
    Support for the Optimus V on ZVJ is in that thread, which is why it was created.
    Now to get LGNPST set up:
    [INFO]
    What You Need:
    1. Drivers installed
    2. LS670.dll
    3. YOU MUST BE ON LGNPST 1.3
    4. ----Thank you asadullah!
    5. Your SPC code, get it by following the youtube video. Thank you asadullah!
    [/INFO]
    [YT]http://www.youtube.com/watch?v=t_bSUGSnkak[/YT]
    DO NOT OPEN LGNPST until I say so.
    [BOX="Steps"]
    Step 0: Enable the Administrator account (Windows Vista/7 users only. Windows XP users skip to Step 1.)
    -Click Start
    -type "cmd" (without quotes)
    -right click cmd
    -Run as Admin
    type "net users Administrator /active:yes" (without quotes)
    type "net users Administrator * " (without quotes)
    Hit enter 3 times
    Log off
    Select the Administrator account.
    FROM NOW ON you will only use this account for the entire process.
    Because this program has issues when it is not used/installed via the actual Admin account. Normally install issues and running issues.
    Step 1: Install LGNPST>Reboot>Extract and install everything in LGNPST Components.zip
    Step 2:
    -Extract VM670.dll to C:\LG Electronics\LGNPST\Model\MTP (create folders if they don't exist) and Right-click VM670.dll press Register Active X DLL
    -Extract LS670.dll to C:\LG Electronics\LGNPST\Model\MTP\LS670 and and Right-click LS670.dll press Register Active X DLL
    The LS670 DLL must be in a seperate folder before you register it!
    Step 3: Connect phone while in recovery mode. If using VM670NH recovery, you must boot into phone and open the PORT by dialing ##7678# then enter SPC code> then check the checkbox. Leave the phone alone now.
    Step 4: Open LGNPST, make sure it connects to your phone.
    Step 5: Go to where you registered the VM670.dll
    Copy the file called VM670_COM##.nvs and paste it to a place you will remember it.
    If file doesn't exist yet, press Phone Setting>Enter SPC>Press Read, then close it and go look for the file now.
    YOU MUST HAVE THIS FILE BEFORE CONTINUING AND BACKED UP! FAILURE TO DO THIS WILL RESULT IN PERMANENT 3G/DATA LOSS ON YOUR PHONE. I WILL NOT BE HELD RESPONSIBLE BY YOUR MISTAKE.
    IF YOUR COMPUTER HAS HDD PROBLEMS, YOU BETTER BACK IT UP TO A FLASH DRIVE!
    Step 6: Disconnect phone, put it in emergency mode.
    [INFO]If you do not know how to do this, you shouldn't be doing this, go learn more about the Optimus V.[/INFO]
    Step 7: Select LS670.dll and the bin file that you extracted from the RAR Archive.
    Step 8: Press Start
    Step 9: Go eat a cookie with some milk because this will take a while.
    Step 10: When it is done, you will notice everything zeroed out. Press the Data tab and then browse to where you backed up the VM670_COM##.nvs file. Press Start> Press Yes.
    Reboot the phone if it doesn't automatically after it hits 100%.
    Step 11: Flash a Virgin Mobile PRL
    Press Provision tab, PRL/ERI
    Go to the top where it says "Tool (T)" and press Show Only Old UI
    Select Write, Checkmark PRL and Nam1 and Nam2
    Browse and select to where you extracted the PRL file
    Press Start, Enter SPC if asked.
    Phone will reboot.
    Step 12: Now follow this to get AAA/HA keys and to reprogram the phone for data to work:
    Fix V data for ZVD/ZVJ
    Do not forget, to get into recovery mode, it will now be Power+Menu+Volume Down because of key switch.
    Congrats you are on LS670ZVD, now follow this guide to root and to get ZVJ on it:
    [How-To] Automated Rooting of LS670ZVD/ZVH/ZVJ
    You are on Optimus S firmware now, you must use Optimus S recoveries.
    [INFO]Use this patch created by nitestalkr to run Optimus V ROMS and ZVD OS ROMS:
    [Patch's]ZVJ to ZVD & ZVD to ZVJ Flashable zips(Optimus V)---The second patch. [/INFO][/BOX]
  2. Thread Author  Thread Author    #2
    sammyz's Avatar
    Posts
    ROM
    Default Re: [GUIDE] Optimus V ZVJ
    Reserved for not being sure if my current guide to returning to ZV5 will work or not. If it does not, I know a way that will.
  3. #3
    andrewnelson23's Avatar
    Posts
    ROM
    Quattrimus
    Even the Go mms fix doesn't work for this?
    In your second post you should explain how to root it. Or post this link Also, how to switch the buttons back?
    Olan Rogers, ladies and gentlemen. Funniest video ever!!!
    sammyz's Avatar
    Posts
    ROM
    Quote Originally Posted by andrewnelson23 View Post
    Haven't tried it, I'm on metropcs......it should work.
    Thanked by:
  5. #5
    Posts
    ROM
    Quattrimus
    Sammyz, ever since I bricked back in April and had to use S firmware to fix it, my V recovery buttons have been switched. It's weird because I updated to zv9 and everything works perfectly. and in the roms, the buttons are normal v buttons. What's up with that? Do I have S firmware on zv9 update?
    sammyz's Avatar
    Posts
    ROM
    Yes you still have S firmware on your phone....
  7. #7
    Posts
    ROM
    Quattrimus
    O.o WOAH. But I've been using V stuff this whole time. V recoveries, V roms, V tweaks. And everything works. And I didn't know it was possible to get zv9 while on S firmware???
  8. Thread Author  Thread Author    #8
    sammyz's Avatar
    Posts
    ROM
    Wait which recovery you using? Cannibal recovery has the Menu button for selecting.....
  9. #9
    Posts
    ROM
    Quattrimus
    Clockworkmod v 4.0.1.5. Everytime I want to get into recovery, I have to do volume down, menu button, and power.
    Thanked by:
  10. #10
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    I think I might do this, just because I can and Ive always wanted to try hydrorom
    Guess whos coming back!
    sammyz likes this.
  11. Thread Author  Thread Author    #11
    sammyz's Avatar
    Posts
    ROM
    Yea, you have stuff left behind, recovery buttons won't be fixed until you use LGNPST back to ZV5, if you did do that and it still does it, you have to go to ZV5 while in e-mode.
  12. #12
    Posts
    ROM
    Quattrimus
    I think I might go to zvj
    sammyz likes this.
  13. #13
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    i plan on making a rom for this
    if someone can tell me how to make keyswitch it would be great
    i replaced harmonias key layout folder and it didnt work
    im definatly making a rom for zvj it will be awhile though so bare with me i want it perfect
    Sent From My LS670
    Thanked by:
    sammyz
  14. #14
    Default
    I'm gonna give this a go.
    I can return back using your ZV4 stuff? And I will have data? Cause your on Metro which makes me confused
    Thanked by:
    sellers86 and sammyz like this.
  15. Thread Author  Thread Author    #15
    sammyz's Avatar
    Posts
    ROM
    Quote Originally Posted by ThatGuyLurkin View Post
    Yes you will have data, LGNPST backs up all the NV items, which is a great thing, I do recommend everyone writing them down somewhere though, VM will never give you those AAA/HA keys, they will send you a new phone before that happens.
    And yes you should be able to return to ZV5 with my guide.....it may leave traces of S firmware behind though so I may have to create a new guide in this second post. When you flash firmware with LGNPST while in E-Mode, you don't get old fw traces...like what andrew has...
  16. #16
    Default
    What's the combo for Emergency mode? Sure, I've never used it and you don't recommend people like that not being here, but,I want to learn.
  17. Thread Author  Thread Author    #17
    sammyz's Avatar
    Posts
    ROM
    Out of all people lol, my unbrick guide says how to. It's a sticky ^_^
  18. #18
    drymarro's Avatar
    Posts
    ROM
    Quattrimus ICS Nightly
    What's the point of doing this?
  19. Thread Author  Thread Author    #19
    sammyz's Avatar
    Posts
    ROM
    Quote Originally Posted by drymarro View Post
    There are Optimus S ROMs built on ZVJ based firmware, you cannot use those ROMs on the Optimus V unless you follow my OP. Ported ROMs for keyswitch and MMS are coming.
  20. #20
    Posts
    ROM
    Quattrimus
    So after doing this, could we flash the quattrimus OS version?
  21. #21
    Nate456's Avatar
    Posts
    ROM
    Stock, CM10, AOKP
    Default
    Quattrimus for the OS is for the ZVD radio.
    Sent from my shole using Tapatalk 2
  22. Thread Author  Thread Author    #22
    sammyz's Avatar
    Posts
    ROM
    Default
    If you stay on ZVD you should still flash the OV version, if you update to ZVJ it wont work.
    Sent from my LS670 using Android Central Forums
  23. Thread Author  Thread Author    #23
    sammyz's Avatar
    Posts
    ROM
    Default
    I just noticed that op is messed up a little on tapa
  24. #24
    Posts
    ROM
    Quattrimus
    I keep getting
    The module "C:\LG Electronics\LGNPST\Model\MTP\VM670.dll" was loaded but the call to DllRegisterServer failed with error code 0x80020009.
    Do I just ignore that?
  25. #25
    Nate456's Avatar
    Posts
    ROM
    Stock, CM10, AOKP
    I keep getting
    You need the LGNSPT generic installer.
