[AIO][WIP] Romtools by Phatninja55
Status
Not open for further replies.
Re: Romtools v1 by Phatninja55
Flash recovery on what????????
Unrooted phone???
OMG!!!
I am trying this!
Need to install ubuntu...
Unrooted phone???
OMG!!!
I am trying this!
I'm guessing it must use the gordita exploit to accomplish that. Still a pretty cool tool.
Tapatalk'n it from my VM670 running LS670ZVJ Hydro Rom
It doesn't.....he actually was unable to get that downloaded....
It does, it uses the same command for getting correct permissions to flash recovery....
Uploaded romtools for windows. If there is anything you want me to add, modify, or remove, please feel free to let me know.
Edited windows version to include adb, less files, and a bin folder, because of all the changes I have bumped it up to V2. Linux remains the same, other than small tweaks and such.
Reactions: sammyz
Re: Romtools v1+v2 by Phatninja55
If you like I can edit the main script for Linux to flash any ROM without having to rename it update.zip? Do not ask me about Windows I'm not really good with Windows Batch files.
Go right ahead. I could probably change it to work with windows. I'm not that great with either scripting types. Just enough to get a good working script.
Can you use this to flash tons without flashing, or do you still have to wipe? Perhaps you could add that into the options? This could really help for those blank recoveries.
It has automatic wiping process :D but to flash ROM, you must have a recovery that has signature verification off by default, or an actual signed ROM....
I just added an option to sign a zip. =d
Might stop production on linux. Windows only from now on, will keep v1 for linux up tho.
Edited OP with version 2.5 of Romtools for windows. Linux will no longer receive updates.
You need to add the virgin mobile mms patcher and add instructions how to use it.
Sent from my Optimus V running Optimus S firmware on MetroPCS
Re: [WIP] Romtools v1 (Linux) and v2.5 (Windows) by Phatninja55
That would be way to much work. It would ruin the simplicity of the tool.
why no linux updates? thats all I use...
You've got to be ready for everything! ;) Dual boot and/or use VMs.
I do. Ubuntu 10.04, and Windows 7. I'm just not that great at bash scripting. I actually started working on the bash script again, just never said anything about it. I will soon have it up to par with the windows version.
Minor changes, fixed some spelling.
Status
websitedesig102
