- 07-30-2012, 02:58 AM
Thread Author #1
Lg Optimus V Stuck On Recovery Please Help
Hello i recently unrooted my optimus v using gingerbreak
i thought that since i did this i could factory reset BIGGEST mistake ive ever made
i need help my phone is stuck in recovery mode
"CWM-based Recovery v4.0.1.5"
i have tried using Xionia recovery but i cant seem to unzip it dont know what im doing wrong or what i am not doing
im confused please help me
ive tried so many guides on what to do when you get stuck there but i still dont understand
what can i do
Thanks - 07-30-2012, 03:11 AM #2
- 07-30-2012, 04:20 AM
Thread Author #3
- 07-30-2012, 04:23 AM #4
- 07-30-2012, 04:27 AM
Thread Author #5
- 07-30-2012, 05:44 AM
Thread Author #6
- 07-30-2012, 06:36 AM #7
If he's stuck in cwm recovery the ports are closed and lgnpst won't be able to communicate with the phone.
If you downloaded the flashable zip of Xionia recovery then your problem is you tried to unzip it. You need to put it on the root of your SD card and flash it with cwm.... Really though Xionia is getting old I'd recommend cannibal recovery there's a thread for it in this forum and it does come in a flashable zip. Anyways under the advanced menu of cannibal or Xionia recovery there is an option to fix boot loop this is what you need.
Tapatalk'n it from my VM670 running LS670ZVJ Dante Rom - 07-30-2012, 06:49 AM #8
Re: Lg Optimus V Stuck On Recovery Please Help
Noooo, don't do the unbrick method. That's not what you need. You're going through what's called a recovery boot loop. You need to install a different recovery.
Download Cannibal Recovery. It has an option to stop recovery boot loop. Grab the one that says alternate zip installer. First, rename it to simply Cannibal, and put it on the root(top level of your sdcard, not in any folders).
boot into your recovery, install zip from sdcard, choose zip and choose Cannibal.zip. If it works, reboot into recovery and you should have a different recovery-Cannibal.
Once it works correctly, you're going to want to transfer a fresh rom over to your phone. If it needs gapps, transfer that over too. If you can mount the sdcard and transfer files over, that's fine, or you may need to adb push them. Just ask if you can't seem to move files over. Next, you will wipe the everything but the sdcard. Then you'll want to flash the rom and gapps but DON'T REBOOT YET. Go into advanced and click stop recovery boot loop. and then you should boot up just fine.
Ahhh, Wraith ninja'd me.Olan Rogers, ladies and gentlemen. Funniest video ever!!!Thanked by 2: - 07-30-2012, 02:20 PM
Thread Author #9
theres no "Stop recovery boot loop" option
Found it Thanks A lot you saved my phone
Thanked by: - 07-30-2012, 04:46 PM #10
- 08-01-2012, 08:20 PM #11
Hello, first off, thanks for the info on how to save this phone but how does one go about transferring the Cannibal zip file into the SD card? I'm a newbie here as well as with the Android and I'm also stuck on this CWM Recovery menu however I don't know how to access my SD Card on the PC while I'm stuck in this CWM menu.
Sorry to bring up this topic again.
Thanks,
She-Wolf - 08-01-2012, 08:52 PM #12
Either take the sdcard out and put it in a card reader on a pc or mount usb mass storage under mounts and storage. There's also adb push but that's a little more advanced. Phatninja55 also has romtools that I belive can help. (never used myself)
Tapatalk'n it from my VM670 running LS670ZVJ Dante Rom - 08-05-2012, 04:43 PM #13
- 08-05-2012, 05:07 PM #14
Sounds like you have a 2.2.1 rom on a 2.2.2 phone. They changed the screen when they released the 2.2.2 version. So everything probably is working you just can't see it. Can you get back to recovery to flash a different rom
Tapatalk'n it from my VM670 running LS670ZVJ Baseband on Mandylion IHO ROM - 08-05-2012, 05:11 PM #15
Volume down + home + power from powered off also if it's going to be rooted anyway you may as well put one of the roms found on this forum on it for WAY better performance and they support both screens
Tapatalk'n it from my VM670 running LS670ZVJ Baseband on Mandylion IHO ROM - 08-05-2012, 05:13 PM #16
- 08-05-2012, 06:11 PM #17
- 08-05-2012, 06:53 PM #18
Use Titanium Backup to delete bloatware.
Olan Rogers, ladies and gentlemen. Funniest video ever!!! - 08-05-2012, 06:54 PM #19
- 08-05-2012, 07:37 PM #20
Overdrive is a good one if you want stock based there are quite a few to choose from you should look around the forums some and check them out. You did say it's your wife's phone right? Maybe harmonia 2 would be good. It's cm7 with as much removed as possible. Android 2.3.7 gingerbread any of the IHO ROMs are good choices. @sammy while I love ics we have to remember beta isn't for everyone.
Tapatalk'n it from my VM670 running LS670ZVJ HydroROM - 08-05-2012, 07:41 PM #21
- 08-05-2012, 07:44 PM #22
- 08-05-2012, 07:49 PM #23
- 08-05-2012, 07:53 PM #24
Yeah... It sort of works... Sync is off.. I thought I read a fix in the OS forums though... I don't have netflix so never looked into it much... Hulu works great once you figure out how to install it and get past the this device is unsupported message
Tapatalk'n it from my VM670 running LS670ZVJ HydroROM - 08-05-2012, 07:54 PM #25
I got em both working in ics
Reply
