01-01-2014 07:38 PM
167 12345 ...
tools
  1. anon631962's Avatar
    OMG! I decided to try the directions in the original thread [Custom Recovery] Xionia Clockwork (CWMA v1.2518.6) (using adb shell) instead of the one you gave me http://androidforums.com/optimus-v-a...ml#post2904142 (using phone's recovery screen) and it rebooted right into the phone! Thank you so much!
    Now, when I want to do a factory reset (getting the phone back to original everything), do you think it would be best to apply the VM Update Package http://forums.androidcentral.com/ext...252Fupdate.zip again, then root as per [ROOT] Virgin Mobile Security Update Now Rooted!!! Thanks jcase!!? Or is there a better method?
    09-11-2012 06:39 AM
  2. strabo231's Avatar
    You don't have to apply that update. It's actually been recommended by virgin not to now because a lot of people have reported it killing their data speeds. I applied it on mine and ended up going back to zv5 I had on it originally...but if you wanted to try it, then you need to apply the update first, then root. Otherwise you can just skip it and go ahead and root.
    09-11-2012 08:16 AM
  3. anon631962's Avatar
    Then I should use [HOW-TO] Simplified Root + Recovery + Custom ROM to root and will the custom recovery factory reset restore everything to factory (except rooted)? Or should I use How to restore your Optimus V to almost original condition then root again through the first link? Or is there a better method to restore to factory? I'm a little OCD and like to be able to start from scratch regularly. Thanks!
    09-11-2012 09:15 AM
  4. strabo231's Avatar
    If you are wanting to root and install a custom rom, and you are not going to upgrade to zv9, all you need to do is root and flash the recovery. If you truly restore your phone to stock that is also going to mean putting a stock recovery back on the phone which will also unroot. Unless you don't want root or you don't want a custom rom, restoring to factory first is just causing you to do everything twice, and there is really no benefit to that, and its also unnecessary. So basically just follow that first guide and then put whatever rom you want on the phone. Just skip the part about trying to restore stock...like I said, it is not a necessary step, and its kind of a waste of time in this instance. I don't know which baseband you have on the phone now, but gingerbreak May not work, in which case you will need a pc and superoneclick.
    09-11-2012 09:47 AM
  5. anon631962's Avatar
    Baseband Version: VM670ZV5_60401001
    I don't necessarily care about a custom Recovery or ROM (unless there's one that provides on-the-fly encryption of the SD Card), I just want to Root to be able to get rid of bloatware I won't be using and save space on the internal storage using Link2SD. First time, I Rooted via [How-To] Root the LG Optimus V - is that better for me to use? I'm looking for a safe, not too complex, way to Root, Restore (including stock stuff I may want to use again), and repeat as my OCD deems necessary. Thanks again!
    09-11-2012 10:28 AM
  6. strabo231's Avatar
    No, you need Gingerbreak. You are running ZV5. Superoneclick will only work with ZV4. If you want a stock rom, I would actually suggest finding the third stock version. It's exactly what came with the phone, but minus all the bloatware and other unnecessary items. That's probably your best bet. That way you can be sure you aren't removing something that needs to be on the phone, as there are s few Google apps that need to stay in order for android to function properly. Actually I'd also suggest that you go ahead and apply a custom recovery as well...makes backup and restore a little easier, and also will save you some steps later if you change your mind about a rom. Just makes various installations easier in general.
    09-11-2012 10:55 AM
  7. anon631962's Avatar
    So I should Root and install custom Recovery as per [HOW-TO] Simplified Root + Recovery + Custom ROM, right? Can you link me to the ROM you're talking about? I've been unable to find it.
    09-11-2012 11:33 AM
  8. strabo231's Avatar
    Yeah for the recovery you really can't get any easier than that. The rom I'll dig up for you. Might take a few, but I'll get it
    - - - Updated - - -
    Here is the link where you'll find the stock modified froyo rom. http://androidforums.com/optimus-v-a...ck-virgin.html
    anon631962 likes this.
    09-11-2012 12:26 PM
  9. cammie199510's Avatar
    kdz fw updater says my phone was not found in the log bog
    09-12-2012 04:47 PM
  10. strabo231's Avatar
    Kdz? What are you using that for exactly? Since you aren't doing an upgrade or a restoration, you don't need it. Do you have a custom recovery? If you don't just get one on the phone before you worry about the rom and you won't even need to mess anything else. You'll be able to install the rom using the recovery
    09-12-2012 05:18 PM
  11. joeycmb's Avatar
    i follow step by step but isnt working for my optimus my v doesnt boot black screen with LG logo cant renember how i brick can some one tell me whats this ::: please ...error was runin for hr till i unplug here picture sorry for the size of pix
    Sent from my LG-LG855 using Tapatalk 2
    09-16-2012 02:58 PM
  12. TaylordKris's Avatar
    All of you may or may not know about my KP500 unbrick method, but this one will replace my unbrick and upgrade/downgrade/return to stock methods. Why? Because this is 100x more easier than KP500 and 10x more easier than LGNPST. These are somewhat the same directions is in the readme file that I included in the single download that contains everything you need.
    This may not fully unbrick your phone in certain circumstances (neither will KP500). In such cases, please PM me.
    DO NOT USE THIS TO RETURN TO ZV5 IF YOU ARE RUNNING ZVD/ZVJ FIRMWARE.
    Download this: Unbrick OV KDZ.rar
    Unbrick directions:
    1. Install Drivers (LGUnitedMobileDriver_S4981MAN37AP22_ML_WHQL_Ver_3.7.2)>Reboot
    2. Install MSXML 4.0 SP3 Parser (msxml.msi)
    3. Connect phone in emergency mode (Phone off> Volume Down + Back key + plug in USB)
    4. Run KDZ_FW_UPD.exe
    5. Select ZV5.kdz
    6. In "type", choose 3GQCT
    7. In Phonemode, choose EMERGENCY
    8. Click Launch software update
    9. Wait for the error to come up
    10. Press OK
    11. Unplug phone, pull battery, reindeer battery, press power button, reinsert usb cable.
    12. Click Launch software update
    13. This time it won't error, you will be unbricked.
    14. Enjoy
    Upgrade/Downgrade/Return to stock directions:
    1. Install Drivers, Reboot
    3. Connect phone in recovery mode (Phone off> Volume Down + Home key)(This will not work with certain recoveries, in that case you will need your MSL code here and then dial ##PORT# and enter MSL code (aka SPC code))
    5. Select ZV5.kdz
    6. In type, choose 3GQCT
    7. In Phonemode, choose DIAG
    9. Enjoy
    If you get a bootloop after any of these methods above, go into recovery, factory reset, reboot.
    If you get a blackscreen while trying to access recovery and can't boot up, redo unbrick method. After that you will most likely still get a blackscreen recovery, but it boots. In that case, just flash another custom recovery. DO NOT FACTORY RESET from privacy menu. PM me if you need stock recovery on it.
    Like my work?
    Donate here
    hey sammy, I'm kind of a noob, so I apologize if I do come off as that..
    But this i for Optimus V right? I want to root my phone, the model number is VM670, Version 2.2.2, HW version 1.2..
    Is this the right place to root it?
    09-21-2012 01:27 PM
  13. sammyz's Avatar
    This is in case you brick (screw up phone). Not to root.
    Sent from my Optimus S running VM670ZV5 on MetroPCS.
    09-21-2012 03:29 PM
  14. ldking931's Avatar
    You just literally saved my life. Thank you sooooooooo much.
    09-25-2012 12:04 AM
  15. davidR420's Avatar
    yo can anyone help , me lg optiums v stuck in A BOOTLOOp my noob @ss dont know how to fix it can someone help me plzs thank you.
    10-01-2012 09:17 PM
  16. thewraith420's Avatar
    Get the xionia zip clod linked you to in your other post flash it from recovery, reboot to recovery, go to advanced and choose fix boot loop and reboot
    Sent from my VM670 using Tapatalk 2
    10-01-2012 09:39 PM
  17. Chasingsun123's Avatar
    Ok, My OV will not boot up, will not go into emergency mode, nor will it go into recovery mode. Every time i try to attempt to fix it, it goes to a complete blue screen. Is there anyway to unbrick it, without using emergency/recovery mode?? Thanks in advance!
    10-20-2012 05:21 PM
  18. tgp's Avatar
    Depending on what happened, recovery might not be possible.
    Sent from my Galaxy Nexus
    10-20-2012 06:30 PM
  19. tgp's Avatar
    This happened to me once; the solution turned out to be rather simple. I called Virgin Mobile Customer Service, they created an RMA, sent me a replacement, and I sent them the bricked phone. Problem solved!
    However, before I called I tried everything to resurrect mine. I couldn't.
    10-20-2012 06:36 PM
  20. vinceeze1's Avatar
    how long does step 3 actually take? its been like this for awhile
    10-29-2012 11:57 PM
  21. sammyz's Avatar
    .......follow the other steps....it DOESN'T do ANYTHING automatically!
    10-30-2012 05:24 PM
  22. Getbeanies's Avatar
    my optimus v goes into fastboot when i boot it im able to go to recovery will this fix my problem
    12-04-2012 05:15 PM
  23. thewraith420's Avatar
    Stock recovery or a custom recovery? If it's a custom recovery try flashing a rom if it's stock try the zv9 update.zip it sounds like your system partition got wiped.
    Tapatalk'n it from my Cold As Ice VM670 running LS670ZVJ firmware
    12-04-2012 07:15 PM
  24. Getbeanies's Avatar
    i dont know how i did it but i think i have a custom recovery. its called xionia recovery and i dont know how to flash a rom also. do i put into sd card and install zip from sd card?
    12-05-2012 05:09 PM
  25. ZackVortex's Avatar
    This should help. You don't need the recovery that's in the op you can use anyone you like
    Sent from my VM670 using Android Central Forums
    12-05-2012 11:30 PM
167 12345 ...
