I have done the steps 10+ times both with and without the battery and either the above happens or it gets stuck on repeating "Step : Flash Burning(SDRAM to FLASH)".
I updated to VM670ZV9 without thinking about waiting for it to be road tested then rooted as per ([ROOT] Virgin Mobile Security Update Now Rooted!!! Thanks jcase!!). I wanted to get rid of crumbs of things I installed/uninstalled and without thinking (once again) I did the Menu / Settings / Privacy / Factory Data Reset. Any help you can give would be greatly appreciated, I can't afford a new phone and losing my grandfathered plan! Any other information you need?
Re: [GUIDE] Unbrick/Upgrade Optimus V [EASY] [KDZ]
[R&D Test Tools Log File]
22:16:17 : Launching SW update
22:16:17 : Unpacking KDZ
22:16:18 : KDZ file extraced
22:16:18 : Files were extracted.
22:16:18 : LGMobileDL Load.
22:16:18 : Port = -1
22:16:18 : Connecting to phone
22:16:18 : PHONE WAS NOT FOUND!
22:16:20 : ===FINISHED===
KDZ just does not work....Im pretty sure there are phones out there that just cannot be un-briCked and I think I own one of them!
Using lgnpst from e-mode you could probably get it unbricked but it's a long process to restore calling and sms and you'll never get data back
My phone is stuck at a flashing lg logo, both the screen and the four bottom buttons flash. I don't know if this is considered to be "bricked" but I thought I'd try this guide.
And I've done it at least a dozen times and I kept getting either
"Upgrade Error"
"WParam: 100"
"LParam: 89"
or it gets stuck and keeps repeating "Step Complete : Flash Burning(SDRAM to FLASH)" over and over.
I've also tried the older guide with the KP500 several times and I kept getting errors there too.
Any ideas?
My phone is rooted but I can't get into recovery, only emergency mode. This problem started after my phone randomly shut down in the middle of a text.
"Upgrade Error"
"WParam: 100"
"LParam: 89"
Any ideas?
I don't know if you're a Virgin Mobile customer but if you are I'd say call customer service and demand a replacement phone. I currently have 4 various Optimus platforms and 3 of them are rooted and have had nothing but problems with them. 1 of them is rooted and I'm assuming bricked as It gets stuck on the LG splash boot loop and all four buttons flash with no boot-up. I have tried KDZ (as you see in my last post) to no avail. This was very frustrating but Virgin is an up and coming service provider that offers GREAT prices for its various annual and non annual packages with "newer" phones available. I'd say forget this forums advice because nobody really has the right answers for a truly bricked phone to call your provider up and ask for a replacement phone at no extra cost and do not take "no" for an answer. I did this and now have a brand new, out-of-the-box Optimus V and it works flawlessly(for now)!
Good Luck
OMG!!!!! I tried a untested ROM and bricked my new Otpimus V and I had to come back here and use KDZ over again and I have to give it to you, IT WORKS....THANKS A MILLION GUYS!!!! WHEW, I thought I was going to die, for real but you saved my life on this one...I'm donating some $$$ for sure!!!
I tried this method, and it did not work.... then I installed the zip file at the end of this page: [FIX]Black screen with custom recovery and custom roms
using the install zip option in recovery mode and my phone is like brand new!!!!!
Thanks Sammy,
after a cupla tries, this worked, I kept getting the dreaded "the application dialer has stopped unexpectedly" with the obnoxious and recurrent "force close". Now to reinstall my apps. Thanks again. will contribute if I can figure out how.
Originally Posted by sammyz
All of you may or may not know about my KP500 unbrick method, but this one will replace my unbrick and upgrade/downgrade/return to stock methods. Why? Because this is 100x more easier than KP500 and 10x more easier than LGNPST. These are somewhat the same directions is in the readme file that I included in the single download that contains everything you need.
This may not fully unbrick your phone in certain circumstances (neither will KP500). In such cases, please PM me.
DO NOT USE THIS TO RETURN TO ZV5 IF YOU ARE RUNNING ZVD/ZVJ FIRMWARE.
Connect phone in emergency mode (Phone off> Volume Down + Back key + plug in USB)
Run KDZ_FW_UPD.exe
Select ZV5.kdz
In "type", choose 3GQCT
In Phonemode, choose EMERGENCY
Click Launch software update
Wait for the error to come up
Press OK
Unplug phone, pull battery, reindeer battery, press power button, reinsert usb cable.
This time it won't error, you will be unbricked.
Enjoy
Upgrade/Downgrade/Return to stock directions:
Install Drivers, Reboot
Install MSXML 4.0 SP3 Parser (msxml.msi)
Connect phone in recovery mode (Phone off> Volume Down + Home key)(This will not work with certain recoveries, in that case you will need your MSL code here and then dial ##PORT# and enter MSL code (aka SPC code))
Run KDZ_FW_UPD.exe
Select ZV5.kdz
In type, choose 3GQCT
In Phonemode, choose DIAG
Enjoy
If you get a bootloop after any of these methods above, go into recovery, factory reset, reboot.
If you get a blackscreen while trying to access recovery and can't boot up, redo unbrick method. After that you will most likely still get a blackscreen recovery, but it boots. In that case, just flash another custom recovery. DO NOT FACTORY RESET from privacy menu. PM me if you need stock recovery on it.
all of you may or may not know about my kp500 unbrick method, but this one will replace my unbrick and upgrade/downgrade/return to stock methods. Why? Because this is 100x more easier than kp500 and 10x more easier than lgnpst. These are somewhat the same directions is in the readme file that i included in the single download that contains everything you need.
This may not fully unbrick your phone in certain circumstances (neither will kp500). In such cases, please pm me.
do not use this to return to zv5 if you are running zvd/zvj firmware.
connect phone in emergency mode (phone off> volume down + back key + plug in usb)
run kdz_fw_upd.exe
select zv5.kdz
in "type", choose 3gqct
in phonemode, choose emergency
click launch software update
wait for the error to come up
press ok
unplug phone, pull battery, reindeer battery, press power button, reinsert usb cable.
this time it won't error, you will be unbricked.
enjoy :d
upgrade/downgrade/return to stock directions:
install drivers, reboot
install msxml 4.0 sp3 parser (msxml.msi)
connect phone in recovery mode (phone off> volume down + home key)(this will not work with certain recoveries, in that case you will need your msl code here and then dial ##port# and enter msl code (aka spc code))
run kdz_fw_upd.exe
select zv5.kdz
in type, choose 3gqct
in phonemode, choose diag
enjoy :d
if you get a bootloop after any of these methods above, go into recovery, factory reset, reboot.
If you get a blackscreen while trying to access recovery and can't boot up, redo unbrick method. After that you will most likely still get a blackscreen recovery, but it boots. In that case, just flash another custom recovery. Do not factory reset from privacy menu. Pm me if you need stock recovery on it.
Like my work?
Donate :d
okay i did all of this, it took me back to the clockworkmod recovery 5.0.2.7 on my phone whatt do i do now?
Now you need to flash a new rom. Download a rom and gapps from one of the many rom threads in this forum and place them on the sd card. From the recovery menus wipe/format boot, data, system, cache, and dalvik (that option is under advanced). Then find the install zip from sdcard option. Do that with the ROMs .zip and the gapps' .zip. Then reboot and enjoy your new working rom.
Portions of this page are modifications based on work created and shared by the Android Open Source Project
and used according to terms described in the Creative Commons 2.5 Attribution License. AndroidCentral is an independent site
that is not affiliated with or endorsed by Google.
