I'm having an issue like G.Monroy.92
Steps 1-8: Okay
Step 9: Upgrade Error / WParam: 100 / LParam: 84
Step 10: Okay
Step 11: "reindeer battery" = "reinsert battery"?
Step 12: Okay
Then it ends up at:
Phone: CWM-based Recovery v4.0.1.5
KDZ_FW_UPD: Step : Phone Reset(DLL Cmd)
On phone I "wipe data/factory reset" and "reboot system now" and I get to:
KDZ_FW_UPD: Upgrade Error / WParam: 100 / LParam: 92
And phone keeps rebooting into recovery.
I have done the steps 10+ times both with and without the battery and either the above happens or it gets stuck on repeating "Step : Flash Burning(SDRAM to FLASH)".
I updated to VM670ZV9 without thinking about waiting for it to be road tested then rooted as per (
http://forums.androidcentral.com/op...-security-update-now-rooted-thanks-jcase.html). I wanted to get rid of crumbs of things I installed/uninstalled and without thinking (once again) I did the Menu / Settings / Privacy / Factory Data Reset. Any help you can give would be greatly appreciated, I can't afford a new phone and losing my grandfathered plan! Any other information you need?
