[Kernel mod] enable USB fast charging(now in the jawz101 kernel!
sammyz
825
190
Re: kernel mod to enable USB fast charging
look further in this thread for flashable and sources
sammyz
825
190
Anyone test mine??? Btw jawz, I added patch to /arch/arm/mach-msm/lge and for the something_Herring.c I added to device_lge.c I think it's called.
Sent from my LG-LW690 using Tapatalk 2
sammyz
825
190
anon(235100)
155
50
i'm having trouble with yours rebooting my phone before I can test it.
for what it's worth this version of his patch seems to match up more with the content of the files on our phones considering it's for another msm7x27 & cdma model phone (he has 7 versions of the patch on separate threads on the xda forums but the one below is the only one I saw for our chipset).
[KERNEL PATCH] Force AC (fast) Charging - xda-developers
following this version of the patch I was modifying
Code:
/arch/arm/mach-msm/lge/Kconfig
    +config FORCE_FAST_CHARGE
/arch/arm/mach-msm/lge/Makefile
    +obj-$(CONFIG_FORCE_FAST_CHARGE)
/arch/arm/mach-msm/lge/fastchg.c
    +#include <linux/fastchg.h>
/drivers/usb/gadget/msm72k_udc.c
    +#ifdef CONFIG_FORCE_FAST_CHARGE
/include/linux/fastchg.h
when I try to enable it on my version with the commands:
Code:
Fast charge can be toggled by issuing:
echo 1 > /sys/kernel/fast_charge/force_fast_charge
and off:
echo 0 > /sys/kernel/fast_charge/force_fast_charge
On mine I get "cannot create /sys/kernel/fast_charge/force_fast_charge: directory nonexistent"
Well, when in doubt I'm messaging the creator of the patch :p
Reactions: bigsupersquid
sammyz
825
190
Well, I'm gonna try for my phone (MS690) when it works correctly I'll upload source and try to patch VM670 as well, or if you get VM670 patched correctly I'll patch MS690 the same way and give credit to you jawz, and the original guy who made the patch.
whiteflash
i ha ve same problem : sh: cannot create /sys/kernel/fast_charge/force_fast_charge: No such file or directory
you have find a solution?
sammyz
825
190
Where's the source at for the working mod??? I wanna do this for some OM kernels :D
sammyz
825
190
When I click here's the commit, it takes me straight to github homepage....I'm on tapa so idk what the problem is...
sammyz
825
190
I get this error while building:
Code:
drivers/built-in.o: In function `usb_chg_detect':
lowmemorykiller.c:(.text+0x6f124): undefined reference to `force_fast_charge'
make: *** [.tmp_vmlinux1] Error 1
any idea?
and this is almost the end of the building process :(
ThatGuyLurkin
2,155
665
Im a bit lost. I flashed it a couple days ago, everything's still milky smooth on GingerDX. But, this patch, is always on? And does it only work via USB?
fallingOutOfLoveWfithTech
