When I click here's the commit, it takes me straight to github homepage....I'm on tapa so idk what the problem is...
Sent from my LG-LW690 using Tapatalk 2
I have no idea. Maybe it's this site update but it works from my laptop.
I get this error while building:
Code:
drivers/built-in.o: In function `usb_chg_detect':
lowmemorykiller.c:(.text+0x6f124): undefined reference to `force_fast_charge'
make: *** [.tmp_vmlinux1] Error 1
any idea?
and this is almost the end of the building process
I remember seeing that error msg at some point during the development of the patch though I can't remember what I did to fix it. If I can remember I'll report back.
Im a bit lost. I flashed it a couple days ago, everything's still milky smooth on GingerDX. But, this patch, is always on? And does it only work via USB?
See the OP:
To toggle fast charging from terminal you'd need to issue the command:
on:
echo 1 > /sys/kernel/fast_charge/force_fast_charge
and off:
echo 0 > /sys/kernel/fast_charge/force_fast_charge
Just wanted to say thanks for this, flashed the kernel on my OV running MiRaGe-CM7.2-IHO, phone no longer slowly runs down after reaching 100% charge. Also no longer experiencing the slow battery drain on long trips while using it with navigation apps or tethering in the car.
If you're using the jawz101 kernel it isn't because of this mod. There's a lot of other changes compared to mrg's kernel
I couldn't tell you which one is helping in that regard but I'm glad there's something going on cool with it. Thanks for the feedback!
has this zip been updated since the last post on this thread? anyone running this flashable on quattrimus as well?
See the kernel version in the about section on your phone's settings menu. If the date matches with the latest date on github for my kernel it's the latest I've posted.
any major issues with any ics roms?
Unless someone ports it for one of the ICS kernels. It should work if properly ported. I know the aokp builds already have fast charging built in.
