1. ilikechicken123's Avatar
    I'm porting a ROM that's really cool. I think a lot of people will like it but I'm having problems. The build.prop, updater-script, and kernel are really confusing.
    I'm following this guide: CLICK TO SEE THE PORTING GUIDE I'M USING.
    It would help me tons if you helped me out. Here are my problems.
    1: Where exactly is the kernel? Is it the boot.img at the root of the rom zip (not in a subfolder) because I replaced it on the ported rom with the file used on the base rom.
    2: I skipped where it says this:
    Take note of the added set_perms & set_perm_recursives that PORTED added. Then replace all set_perm and set_perm_recursive from BASE to PORTED. Put back in the noted set_perms & set_perm_recursive you wrote down, to PORTED's updater-script
    Because I have no idea what it's talking about.
    3: I'm porting a rom originally made for the Samsung Galaxy Ace. So do I need to do the stuff where it says 'Porting from a different Manufacturer' ? And if I do, How exactly do I do the steps it mentioned?
    4: Besides not understanding fully the top steps, I flashed it anyway. It didn't flash. I got this error:
    Installing update...
    assert failed: getprop("ro.product.device") == "cooper" || getprop("ro.build.product") == "cooper" || getprop("ro.product.board") == "cooper" || getprop("ro.product.device") == "GT-S5830" || getprop("ro.build.product") == "GT-S5830" || getprop("ro.product.board") == "GT-S5830"
    E: Error in sdcard/PortedRom.zip (status 7) installation aborted.
    Thank you so much guys, I'd really appreciate it.
    09-05-2012 09:43 PM
  2. sellers86's Avatar
    2: I skipped where it says this: Because I have no idea what it's talking about.
    You get that error because the updater script is telling the recovery that your phone is the "cooper" which I'm guessing is galaxy ace. To get rid of that flashing error, remove everything before the first semi colon (including the semi colon) in META-INF/com/Google/android/updater-script
    09-05-2012 09:56 PM
  3. ThatGuyLurkin's Avatar
    In a rom.zip, you only want to mess with what's in the /system partition. Sometimes Data partition as well depending on what's in there.
    What are you porting? Is it based on stock? Or CM?
    09-05-2012 11:06 PM
  4. ilikechicken123's Avatar
    Thanks. I'll do it after school.
    09-06-2012 07:14 AM
  5. ilikechicken123's Avatar
    Really? Ugh. youre telling me i did everything wrong?
    Its a Galaxy Ace ROM based off CM7
    09-06-2012 07:16 AM
  6. jonny5449's Avatar
    I had status 7 error too removed to first semi c. And got status 6 anyone wanna help? Link me to rom your porting I can prolly help
    Sent from my LG-LS670 using Tapatalk 2
    09-06-2012 07:20 AM
  7. ThatGuyLurkin's Avatar
    Replace Apps, Media, and Framework, to get it booted, and if it has tweaks within, you have to get libs. If you get force cloae messages, then libs are missing.
    In recovery, do you get a Getprop error? Or Status 7 error?
    09-06-2012 09:03 AM
  8. sellers86's Avatar
    Assert get prop is what the op states.
    09-06-2012 10:14 AM
  9. clodfelterac's Avatar
    replace entire meta folder from base to port... replace build.prop from base to port... (noting differences and adjusting if needed)...
    09-06-2012 02:33 PM
  10. ThatGuyLurkin's Avatar
    Unless you ported backwards using the wrong zip. :P
    09-06-2012 03:26 PM
  11. ilikechicken123's Avatar
    I get both /:
    09-06-2012 05:17 PM
  12. ThatGuyLurkin's Avatar
    09-06-2012 05:35 PM
  13. ilikechicken123's Avatar
    this: [Rom] CM 7.2 - SIII MOD v2 | Update 24.08.2012 | Link Added - xda-developers
    09-06-2012 05:54 PM
  14. TauSigmaNova's Avatar
    Oh, I considered porting that and the AceSII Rom at one point. Good luck with it, It might be tough, expecially since I think it's still Touchwiz based, at least partially.
    09-06-2012 06:13 PM
  15. ilikechicken123's Avatar
    SUCCESSFULLY PORTED! Thank you soo much guys. You all are getting thanked in the post. I'm not sure why but not everything is themed like in the original post. Probably because I used mirage as base? I'm not sure. If anyone wants to donate their help, I'll be so appreciative.
    09-06-2012 06:26 PM
  16. ThatGuyLurkin's Avatar
    Loool. I ported this 3 days ago too
    I could've shared :P
    09-06-2012 06:30 PM
  17. ilikechicken123's Avatar
    Really? aww. Well, if my bugs aren't bugs for yours, I could use your help on why it's messed up -.-
    09-06-2012 06:58 PM
