Results 1 to 7 of 7
- 09-06-2012, 12:46 PM
Thread Author #1
Boot animation and sound
So I made a boot animation that I am pretty happy with, now I have loaded my sound and it's working but the sound cuts off halfway through the animation.
Is there a way to lengthen my sound, the mp3 is about 30 seconds and it cuts off at about 13
Thanks for the help
Sent from my VM670 - 09-06-2012, 01:33 PM #2
That's because after it cuts off, the System is booted. At one point in the bootanimation, you can cut the screen off while its booting.
In ny eyes, No. But you can cut the best part out of it?
Sent from my LG-VM670 using Tapatalk 2 - 09-06-2012, 02:00 PM
Thread Author #3
- 09-07-2012, 12:41 PM
Thread Author #4
Is there anyone reading that has experience making boot animations?
I've made another and it is just an android bouncing around
Problem I'm having is it is a black background but every sec or so it flashes white which doesn't look bad, but nowhere is there a white screen in what I have put together.
Could it have to do with frame rate? What's the highest rate I can use? I am at 30 fps now
Sent from my LG-VM670 using Android Central Forums - 09-07-2012, 01:55 PM
Thread Author #5
- 01-03-2013, 06:53 PM #6
- 01-04-2013, 05:19 AM
Thread Author #7
Reply
